Leaking pump
06-03-2006, 04:13
Leaking pump
My education starts to get going...
I have a pump that's leaking a small bit of water.
It's labeled Shurflow Diaphragm Pump and has the number 2088-422-8055
on it. (It's positioned just below a very similar pump with
2088-423-8055.) The pump is located in the curb-side "toolbox"
compartment near the clean water drain valve.
Does anyone know what this pump is and if it can be rebuilt or if it
must it be replaced? (And where can I get parts?)
BTW, the coach has been sitting for about a week (with external
power) and the water pump is off. I'm surprised that there's enough
pressure for a leak ... but I expect to be surprised by many
Wanderlodge things as the learning process proceeds.
Thanks.
Pete Masterson
aeonix1@...
'95 WBDA 4203
Formerly "George's coach"
El Sobrante CA
06-03-2006, 05:51
Leaking pump
Pete:
That is one of your fresh water pumps replacement is cheaper than putting a
new pump head on it. In your bath cabinet you should have an A B Both
switch you can run both pumps or each separately. That pump is a low GPM
unit and I have been replacing them with the higher pressure 65psi @ 4.5
GPM pumps.
Ralph
>Thanks.
>Pete Masterson
>aeonix1@...
>'95 WBDA 4203
>El Sobrante CA
>Yahoo! Groups Links
Safe travels,
