update on Do Not Shift Light.
06-12-2006, 09:15
Rick, did you get it fixed? what was the cause and correction?
Thankd
94pt ( with blinking DNS light)
Romoland Ca
--- In WanderlodgeForum@yahoogroups.com, "trautoranch"
> Thanks to all of you for the information. I have found a tech to
come
> to our place for $50.00 service and $50.00 per hr. labor plus parts.
> Kindest Regards,
> Rick & Terri Mcintire
> 86PT38 Patillo,Tx. (west of Ft.Worth,TX)
> --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor"
> > Call A to Z Bus sales in Colton Ca 951-781-7188 their allison tec
> may
> > help you out. $350. sounds steep. Where are you at?
> > Gregory O'Connor
> > 94pt Romoland,CA
> > @yahoogroups.com, "trautoranch" wrote:
> > > Kevin, I have been talking to Allison and several of the
dealers.
> I
> > > have did everything they have told me to do. I did talk to one
> that
> > > said they would send someone out. They are going to charge me
> > $350.00
> > > for service call plus $75.00 labor and driving time also. If
they
> > > don't have the right parts they will have to come back out
again.
> > > Might have to go that way because we are full timing it right
now
> > and
> > > need to find a place to stay if they tow it in.
> > > Best Regards,
> > > Rick Mcintire
> > > 86PT38 Patillo,Tx
> > > -- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote:
> > > > Hi Rick,
> > > > Have you called several Allison dealers/service centers and
> asked
> > > for their
> > > > advice? Maybe you could consider calling a mobile service
> > > mechanic, if there
> > > > is no other choice other than towing. Perhaps the Allison
> dealer
> > > in your
> > > > area could make a recommendation regarding a mobile
mechanic.
> > > Just some
> > > > thoughts....
> > > > Kevin McKeown
> > > > Yorba Linda, CA
> > > > 1986 38' PT
> > > > [Non-text portions of this message have been removed]
06-13-2006, 02:34
Greg, We checked the ecm for transmission and found it had a bad chip
in it. It is at the repair shop now and hope to have it back today.
Hope this solves the problem. Will let you know the outcome.
Best Regards,
Rick Mcintire
86PT38 Patillo,Tx.
Just replaced the converter/charger yesterday.
> Rick, did your problem fix? what was the cause??
> Greg, driving with do not shift blinking on and off
> 94 ptRomoland Ca
come
> > Kindest Regards,
