PT40 Radiator
08-08-2006, 03:21
PT40 Radiator
Am searching for a replacement radiator for my 82 PT40. The core is
failing and I plan to replace it and/or the entire assembly. Blue Bird
does not have any source or radiators available so thought someone may
have replaced the radiator. Will rebuild the fan assembly and replace
all cooling system components too while everything is out of the coach.
Any help is appreciated.
Terry Neal
82PT40
74FC34
Bozeman, Montana
08-08-2006, 05:59
PT40 Radiator
Terry any good radiator shop should be able to replace the core
and make it like new. Can you take it out or do you want them to do
it?
Godan industries is a major supplier of cores for over the road
trucks and buses.
Tom Warner
Vernon Center,NY
1985 PT 40
>Terry Neal
>82PT40
>74FC34
>Bozeman, Montana
>Yahoo! Groups Links
08-08-2006, 06:01
PT40 Radiator
Terry, I just talked to Todd Parker, owner of Parker Repair and Radiator
Service. He said to bring that to Livingston, and he will fix you right up. His
phone is 406-222-3166 115 North M St.
83 PT40
Livingston, Montana
08-08-2006, 10:30
PT40 Radiator
Thanks much for your reply Tom. The radiator is out of the coach &
when I checked it over, I decided that I wanted to replace it. I'll
give Godan a try. Maybe they can build a core for me? I will
probably increase the overall cooling capacity at the same time.
Terry Neal
82PT40
74FC34
Bozeman, MT
> it?
> trucks and buses.
> Tom Warner
> Vernon Center,NY
> 1985 PT 40
> >Terry Neal
> >82PT40
> >74FC34
> >Bozeman, Montana
08-08-2006, 13:37
PT40 Radiator
Terry
You might want to Give General Radiator a call 1-800-336-2444.
I have used them for an MCI9 as well as the wanderlodge.
Good Luck
Allen
88 WLPT40WB
Bird
may
replace
coach.
> Terry Neal
> 82PT40
> 74FC34
> Bozeman, Montana
08-08-2006, 15:13
PT40 Radiator
Terry, It may be easier to just have your local radiator shop replace the core.
I did this to my generator radiator last month and it actually was cheaper.
Using the existing brass(copper?) reservoirs and new core, I believe that the
radiator is now solid.
Alex Smith
82FC35
Tallahassee, FL
Terry Neal
82PT40
74FC34
Bozeman, Montana
Get your email and more, right on the new Yahoo.com
08-09-2006, 09:56
PT40 Radiator
Thanks much for the info Allen. I called them and talked with Jim. I
asked them to build me a new core for my radiator. Sounds like they
know their business. Said they do all the work for Chicago Transit
Authority. Good price too for a core that will add about 30-40% cooling
capacity to the old style core. Thanks again.
Terry Neal
82PT40
74FC34
Bozeman, MT
car_go_van wrote:
> Terry
> Good Luck
> Allen
> 88 WLPT40WB
> Bird
> may
> replace
> coach.
> > Terry Neal
> > 82PT40
> > 74FC34
> > Bozeman, Montana
