Radome type antenna replacement.
08-11-2006, 01:48
Has anyone on the forum replaced their radome type tv antenna and
if so, where do you get a replacement?
I took the cover off mine to check why rotating the antenna did not
affect reception and found that the foam center in the disc was
broken and the coax cable had disintegrated. The cover is also
cracked and about to fall apart.
Chuck harrison
Akron, Ohio
90SP36
08-11-2006, 04:05
Chuck,
There is someone on this forum that has access to those and I'm sure they will
chime in or someone else will give you the details. So, be patient. I wish I
could remember who it was. If you want to browse the posts maybe you will find
it mentioned.
Good Luck
Sent: Friday, August 11, 2006 6:48 AM
Subject: [WanderlodgeForum] Radome type antenna replacement.
Chuck harrison
Akron, Ohio
90SP36
08-11-2006, 05:02
I think Stephen Birtles has this part.
http://www.capeinnovation.com/
Bill 88 FC Michigan
not
> Chuck harrison
> Akron, Ohio
> 90SP36
08-11-2006, 06:15
Hi Chuck,
I recently replaced my old one with a new antenna from "Antenna Craft" that I
got from
Stephen Bertles. You can contact him at info@.... The new one
works
much better than the old. Only gripe I have on the unit was that one of the
terminal
screws was galled beyond use and the factory was no help. Otherwise fine.
Regards, Eric
84FC35SBWL2
> Chuck harrison
> Akron, Ohio
> 90SP36
