Air horns
10-11-2005, 12:59
Air horns
Hi again all,
I have Buell air horns on my coach. I talked to Dave, a tech rep there, and my horns are not tunable. I initially called him about getting the horns re-chromed (they are looking a little ratty after 25 years), they would do it for $295.00 for the pair, new horns are about $560.00 a pair. So I will have to think long and hard about getting them re-chromed. Another option would be is to go to a "truck graveyard" and see if it could get used ones that would fit. The folks at Buell were really helpful, but no idea why one horn will work and the other one won't. Tom Meservey, USN (Ret) '81FC33' toot-toot [Non-text portions of this message have been removed] |
08-21-2006, 02:48
Air horns
My 86PT has airhorns manufactured by Grover...give them a call...they might
have parts or help in finding what you need.. Their website is: _www.groverproducts.com_ (http://www.groverproducts.com) Good luck.... Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] |
08-21-2006, 06:22
Air horns
Does anyone have any idea where or if there are parts for the Jabsco air horns?
They are apparently no longer made by Jabsco. I called my local marine store with a number for the service kit listed on the sheet that came with BB. No luck, not listed at all. The service kit includes a spring and a diaphragm. I looked around on the internet and couldn't find where they may had been bought and now produced by another company. Anyone have any suggestions? Thanx Dick Hayden - '87 PT 38 - Lake Stevens, WA [Non-text portions of this message have been removed] |
08-21-2006, 07:24
Air horns
Thanks Kevin,
I just discovered that I also have Grover horns. The product sheet in the Blue Box indicated Jabsco and I was just going by that. Then I climbed up there and dissembled the non working horn and discovered it was a Grover. I tried to call them but it must have been lunch hour. I'll try again later. My problem now seems to be a sticking relay. They blow for quite a long time. My wife discovered that hitting the steering wheel would make them stop which probably means that the relay is close enough to the steering column to be jarred by hitting the wheel. Oh well, I'll keep looking. My guess is that Grover may have made air horns for Jabsco at one time and don't now. Years ago I installed Jabsco horns on several boats including my own. But, that was a long time ago in another life. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 11:48 AM Subject: Re: [WanderlodgeForum] Air horns My 86PT has airhorns manufactured by Grover...give them a call...they might have parts or help in finding what you need.. Their website is: _www.groverproducts.com_ (http://www.groverproducts.com<http://www.groverproducts.com/>) Good luck.... Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-21-2006, 07:43
Air horns
--- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
> > Does anyone have any idea where or if there are parts for the Jabsco air horns? They are apparently no longer made by Jabsco. I called my local marine store with a number for the service kit listed on the sheet that came with BB. No luck, not listed at all. The service kit includes a spring and a diaphragm. I looked around on the internet and couldn't find where they may had been bought and now produced by another company. Anyone have any suggestions? > > Thanx > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > [Non-text portions of this message have been removed] > Dick, do your search for ITT-Jabsco. ITT bought them out several years ago, but Jabsco is still a division. Maybe you will have some luck that way. George McMahan, Lubbock, Texas, 36 450 LXi |
08-21-2006, 07:50
Air horns
PS - I'm not so smart alter all - NO RELAY. Now what? Both horns stay on after
button or foot switch is released and bumping the steering wheel stops them. Any suggestions? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 12:24 PM Subject: Re: [WanderlodgeForum] Air horns Thanks Kevin, I just discovered that I also have Grover horns. The product sheet in the Blue Box indicated Jabsco and I was just going by that. Then I climbed up there and dissembled the non working horn and discovered it was a Grover. I tried to call them but it must have been lunch hour. I'll try again later. My problem now seems to be a sticking relay. They blow for quite a long time. My wife discovered that hitting the steering wheel would make them stop which probably means that the relay is close enough to the steering column to be jarred by hitting the wheel. Oh well, I'll keep looking. My guess is that Grover may have made air horns for Jabsco at one time and don't now. Years ago I installed Jabsco horns on several boats including my own. But, that was a long time ago in another life. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 11:48 AM Subject: Re: [WanderlodgeForum] Air horns My 86PT has airhorns manufactured by Grover...give them a call...they might have parts or help in finding what you need.. Their website is: _www.groverproducts.com_ (http://www.groverproducts.com<http://www.groverproducts.com/><http://wwwgroverp\ roducts.com/<http://www.groverproducts.com/>>) Good luck.... Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-21-2006, 08:43
Air horns
Dick:
I don't have my diagrams in front of me but following the theory that air horns do not blow without air , I would look for a valve that transfers coach air to the horns. See how it is configured. It must have input and output air and at least two wires, one for the foot switch and one for the horn button. Track the wires back and go from there. Sounds like something is holding the valve open, or if it's near the wheel after you whack it the valve closes. That would indicate internal valve problems. Mine has another switch that changes the wheel horn button from air to electric. The foot air horn remains operating on air so I can play them together. Hope this guess helps you. Leroy Eckert 1990WB40 Niceville, FL ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 2:50 PM Subject: Re: [WanderlodgeForum] Air horns PS - I'm not so smart alter all - NO RELAY. Now what? Both horns stay on after button or foot switch is released and bumping the steering wheel stops them. Any suggestions? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 12:24 PM Subject: Re: [WanderlodgeForum] Air horns Thanks Kevin, I just discovered that I also have Grover horns. The product sheet in the Blue Box indicated Jabsco and I was just going by that. Then I climbed up there and dissembled the non working horn and discovered it was a Grover. I tried to call them but it must have been lunch hour. I'll try again later. My problem now seems to be a sticking relay. They blow for quite a long time. My wife discovered that hitting the steering wheel would make them stop which probably means that the relay is close enough to the steering column to be jarred by hitting the wheel. Oh well, I'll keep looking. My guess is that Grover may have made air horns for Jabsco at one time and don't now. Years ago I installed Jabsco horns on several boats including my own. But, that was a long time ago in another life. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 11:48 AM Subject: Re: [WanderlodgeForum] Air horns My 86PT has airhorns manufactured by Grover...give them a call...they might have parts or help in finding what you need.. Their website is: _www.groverproducts.com_ (http://www.groverproducts.com<http://www.groverproducts.com/><http://wwwgroverp\ roducts.com/<http://www.groverproducts.com/>>) Good luck.... Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-21-2006, 09:13
Air horns
Thanks for the reply Leroy. It seems that the dash switch might be going bad.
When it is in the "air horn" position it sticks on for varying amounts of time. When the dash switch is in the "electric horn" position, everything seems to be normal. No prolonged blasts. Maybe something is touching the switch terminal and giving it a resistance ground or the switch itself is dirty inside and by tapping the wheel it vibrates it and moves away and stops the air horn. Strange though that it wouldn't do the same thing when the electric horn is used. Anyway, everything works properly when the switch is in the electric position and I can still use the air horn using the foot switch. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 1:43 PM Subject: Re: [WanderlodgeForum] Air horns Dick: I don't have my diagrams in front of me but following the theory that air horns do not blow without air , I would look for a valve that transfers coach air to the horns. See how it is configured. It must have input and output air and at least two wires, one for the foot switch and one for the horn button. Track the wires back and go from there. Sounds like something is holding the valve open, or if it's near the wheel after you whack it the valve closes. That would indicate internal valve problems. Mine has another switch that changes the wheel horn button from air to electric. The foot air horn remains operating on air so I can play them together. Hope this guess helps you. Leroy Eckert 1990WB40 Niceville, FL ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 2:50 PM Subject: Re: [WanderlodgeForum] Air horns PS - I'm not so smart alter all - NO RELAY. Now what? Both horns stay on after button or foot switch is released and bumping the steering wheel stops them. Any suggestions? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 12:24 PM Subject: Re: [WanderlodgeForum] Air horns Thanks Kevin, I just discovered that I also have Grover horns. The product sheet in the Blue Box indicated Jabsco and I was just going by that. Then I climbed up there and dissembled the non working horn and discovered it was a Grover. I tried to call them but it must have been lunch hour. I'll try again later. My problem now seems to be a sticking relay. They blow for quite a long time. My wife discovered that hitting the steering wheel would make them stop which probably means that the relay is close enough to the steering column to be jarred by hitting the wheel. Oh well, I'll keep looking. My guess is that Grover may have made air horns for Jabsco at one time and don't now. Years ago I installed Jabsco horns on several boats including my own. But, that was a long time ago in another life. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 11:48 AM Subject: Re: [WanderlodgeForum] Air horns My 86PT has airhorns manufactured by Grover...give them a call...they might have parts or help in finding what you need.. Their website is: _www.groverproducts.com_ (http://www.groverproducts.com<http://www.groverproducts.com/><http://wwwgroverp\ roducts.com/<http://www.groverproducts.com/>><http://wwwgroverproducts.com/ cts.com/>>>) Good luck.... Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-21-2006, 09:36
Air horns
I did that George with negative results. Jabsco no longer carries air horns.
However, I discovered that I have Grover horns. (I suspect that Grover made air horns for Jabsco at some time in the past). Grover does have repair kits and I will order them as soon as I can get a response from them. I only hope they are the same. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: gmktm450 To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 12:43 PM Subject: [WanderlodgeForum] Re: Air horns --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > Does anyone have any idea where or if there are parts for the Jabsco air horns? They are apparently no longer made by Jabsco. I called my local marine store with a number for the service kit listed on the sheet that came with BB. No luck, not listed at all. The service kit includes a spring and a diaphragm. I looked around on the internet and couldn't find where they may had been bought and now produced by another company. Anyone have any suggestions? > > Thanx > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > [Non-text portions of this message have been removed] > Dick, do your search for ITT-Jabsco. ITT bought them out several years ago, but Jabsco is still a division. Maybe you will have some luck that way. George McMahan, Lubbock, Texas, 36 450 LXi [Non-text portions of this message have been removed] |
08-21-2006, 10:15
Air horns
Dick:
Ok, it's not the air transfer valve because the foot air horn works properly. I wouldn't think it's in the horn button because the electric horn works properly. Hummm, I'm trying to come up with a reason why it would be the selector switch because it its on or off. Sounds like it may be something in between. Wish I had my diagrams here. Leroy Eckert 1990 WB40 Niceville, FL Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 4:13 PM Subject: Re: [WanderlodgeForum] Air horns Thanks for the reply Leroy. It seems that the dash switch might be going bad. When it is in the "air horn" position it sticks on for varying amounts of time. When the dash switch is in the "electric horn" position, everything seems to be normal. No prolonged blasts. Maybe something is touching the switch terminal and giving it a resistance ground or the switch itself is dirty inside and by tapping the wheel it vibrates it and moves away and stops the air horn. Strange though that it wouldn't do the same thing when the electric horn is used. Anyway, everything works properly when the switch is in the electric position and I can still use the air horn using the foot switch. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 1:43 PM Subject: Re: [WanderlodgeForum] Air horns Dick: I don't have my diagrams in front of me but following the theory that air horns do not blow without air , I would look for a valve that transfers coach air to the horns. See how it is configured. It must have input and output air and at least two wires, one for the foot switch and one for the horn button. Track the wires back and go from there. Sounds like something is holding the valve open, or if it's near the wheel after you whack it the valve closes. That would indicate internal valve problems. Mine has another switch that changes the wheel horn button from air to electric. The foot air horn remains operating on air so I can play them together. Hope this guess helps you. Leroy Eckert 1990WB40 Niceville, FL ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 2:50 PM Subject: Re: [WanderlodgeForum] Air horns PS - I'm not so smart alter all - NO RELAY. Now what? Both horns stay on after button or foot switch is released and bumping the steering wheel stops them. Any suggestions? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 12:24 PM Subject: Re: [WanderlodgeForum] Air horns Thanks Kevin, I just discovered that I also have Grover horns. The product sheet in the Blue Box indicated Jabsco and I was just going by that. Then I climbed up there and dissembled the non working horn and discovered it was a Grover. I tried to call them but it must have been lunch hour. I'll try again later. My problem now seems to be a sticking relay. They blow for quite a long time. My wife discovered that hitting the steering wheel would make them stop which probably means that the relay is close enough to the steering column to be jarred by hitting the wheel. Oh well, I'll keep looking. My guess is that Grover may have made air horns for Jabsco at one time and don't now. Years ago I installed Jabsco horns on several boats including my own. But, that was a long time ago in another life. Thanx again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 11:48 AM Subject: Re: [WanderlodgeForum] Air horns My 86PT has airhorns manufactured by Grover...give them a call...they might have parts or help in finding what you need.. Their website is: _www.groverproducts.com_ (http://www.groverproducts.com<http://www.groverproducts.com/><http://wwwgroverp\ roducts.com/<http://www.groverproducts.com/>><http://wwwgroverproducts.com/ cts.com/>>>) Good luck.... Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
