City water hook up 79 FC
09-20-2006, 11:49
Hi Guys Where is the check valve for the city water hook on a 79 FC
33' ? There is no pressure on the city side of the hook up. The pump has pressure. This is not my Bird. Its a friends & I'm ont near it. Thanks Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
09-20-2006, 16:36
Don,
I'm not sure...I know nothing about a check valve...is there a tank fill switch near the shore hose hookup? That switch could be in the wrong position. That's how it works on our '87. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. dspithaler@... wrote: >Hi Guys Where is the check valve for the city water hook on a 79 FC >33' ? There is no pressure on the city side of the hook up. The pump has >pressure. This is not my Bird. Its a friends & I'm ont near it. Thanks >Don >89 SP 36' >Butler, PA > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
09-20-2006, 17:09
Don, on my 83 the check valve is right at the water connection. I think that
some of the earlier models had separate connections for city water bypass and fill. In either case the city water bypass connection has to have a built-in/attached check valve to keep water from flowing out the connection. My water connection is at the rear driver's side. Since I have a rear bath it is in the compartment with the water heater. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.us) 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 20, 2006 11:49 PM Subject: [WanderlodgeForum] City water hook up 79 FC Hi Guys Where is the check valve for the city water hook on a 79 FC 33' ? There is no pressure on the city side of the hook up. The pump has pressure. This is not my Bird. Its a friends & I'm ont near it. Thanks Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-20-2006, 20:27
Curt The 79 FC has two fill places one for the tank & one for the city
water. No switch that I know of. My 89 SP has the switch. Don, I'm not sure...I know nothing about a check valve...is there a tank fill switch near the shore hose hookup? That switch could be in the wrong position. That's how it works on our '87. Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif. _dspithaler@..._ (mailto:dspithaler@...) wrote: >Hi Guys Where is the check valve for the city water hook on a 79 FC >33' ? There is no pressure on the city side of the hook up. The pump has >pressure. This is not my Bird. Its a friends & I'm ont near it. Thanks >Don >89 SP 36' >Butler, PA > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > [Non-text portions of this message have been removed] |
09-20-2006, 21:00
Bruce This one has the separate fill & city connections. I didn't know if
it had a sporlan valve besides the one in the city hook up. Thanks Don 89 SP 36' Butler, PA Don, on my 83 the check valve is right at the water connection. I think that some of the earlier models had separate connections for city water bypass and fill. In either case the city water bypass connection has to have a built-in/attached check valve to keep water from flowing out the connection. My water connection is at the rear driver's side. Since I have a rear bath it is in the compartment with the water heater. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.Webm 1983 WL FC35RB [Non-text portions of this message have been removed] |
09-20-2006, 22:42
David
Thanks that what I thought. Don Don, On the 78 I had, it had the 2 connections and no Sporlan valve anywhere on the whole coach. David Hollis 84 FC35 Springfield,Da --- In _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) , dspithaler@., dsp > [Non-text portions of this message have been removed] |
09-21-2006, 01:28
Don,
On the 78 I had, it had the 2 connections and no Sporlan valve anywhere on the whole coach. David Hollis 84 FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > Bruce This one has the separate fill & city connections. I didn't know if > it had a sporlan valve besides the one in the city hook up. > Thanks Don > 89 SP 36' > Butler, PA > |
09-21-2006, 12:39
Don, if you have separate connections there is no need for a sporlan valve to
direct the water flow. You may have other sporlan valves, but not one to direct water to fill the tank. Also both water connections should have a check valve either built in or right behind the water connection. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.us) 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, September 21, 2006 9:00 AM Subject: Re: [WanderlodgeForum] City water hook up 79 FC Bruce This one has the separate fill & city connections. I didn't know if it had a sporlan valve besides the one in the city hook up. Thanks Don 89 SP 36' Butler, PA Don, on my 83 the check valve is right at the water connection. I think that some of the earlier models had separate connections for city water bypass and fill. In either case the city water bypass connection has to have a built-in/attached check valve to keep water from flowing out the connection. My water connection is at the rear driver's side. Since I have a rear bath it is in the compartment with the water heater. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.Webm 1983 WL FC35RB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-21-2006, 13:48
I believe that check valve is mounted on or near the hot water tank under the
bed. Rear Corner. Steve Anderson 79FC 35 Poulsbo Wa -----Original Message----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Wed, 20 Sep 2006 8:49 PM Subject: [WanderlodgeForum] City water hook up 79 FC Hi Guys Where is the check valve for the city water hook on a 79 FC 33' ? There is no pressure on the city side of the hook up. The pump has pressure. This is not my Bird. Its a friends & I'm ont near it. Thanks Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] |
