Safeline
09-30-2006, 08:58
Safeline
Does anyone know where the actual Safeline device is located in a
78FC? What does it look like? I tried to find something on the net but all I find is Safeline metal detectors. Gardner 78FC33 |
09-30-2006, 09:20
Safeline
Gardner- look on top of your change over master switch.
Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-30-2006, 13:32
Safeline
Gardner, regarding your Safeline. The Safeline in my coach is behind the door
that is opened from the front of the bus, the door that has the headlight. On my coach the Safeline plugs into the two electrical outlets that are just below seat level on the wall next to the driver. To find the Safeline box, just follow the two cords. In addition there are two switches mounted in small gray boxes near or on the master switch box in the compartment as you go in the entrance door. The Safeline in my coach almost looks like an afterthought or add on. Your system might not be the same or may vary. Steve Anderson 1979 FC 35 Poulsbo, Wa. [Non-text portions of this message have been removed] |
10-01-2006, 02:11
Safeline
Thanks guys. When it stops raining I will go out and check. I opened
up the front yesterday but didn't find anything. It's probably by the changeover switch. I was thinking that if it is toast, I could simply employ two relays (one 110 vac coil [connected at the changeover input side] and one 12 vdc coil [connected to the ingition]) and wire the point sets in series. If both relays are active a light or buzzer would be activated. I can't imagine why anything more complicated would be needed. I only have a 50 amp shore line connector so all shore lines are wired to feed both phases so I don't need to worry about which phase is active. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Does anyone know where the actual Safeline device is located in a > 78FC? What does it look like? I tried to find something on the net but > all I find is Safeline metal detectors. > > Gardner > 78FC33 > |
