Driving Light Air piston
10-23-2006, 09:17
Alan, this is one item that has not been addressed. I'm glad you brought it
up. Hopefully we will get some response. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
10-23-2006, 10:20
Alan there is a switch that the light has to touch to turn the light on. The
light can be adjusted to hit it. If the cylinder is bad it is a Clippard. Mine is an SDR-20-3 & I got two new ones for sixty dollars for both. That made mine work fine after I adjusted them to come the whole way down. I don't think you can repair them. Don 89 SP 36' Butler, PA : One of my driving lights is slow to lower and then doesn't go quite all the way down (hence it won't come on until i push it into place). I was trying to find a post on working on those air pistons (... What are they called?). Can I repair or rebuild it? Thanks, Alan 87FC35 [Non-text portions of this message have been removed] |
10-23-2006, 12:40
all the way down (hence it won't come on until i push it into place). I was trying to find a post on working on those air pistons (... What are they called?). Can I repair or rebuild it? Thanks, Alan 87FC35 ps.. Just installed my headlight/bosch relay upgrade. I"m looking forward to trying it this weekend. |
