unwinterizine
04-18-2005, 14:35
unwinterizine
I put potable water in tank, opened the kitchen & bathroom sink
facuets. When I turn the pump on, i'm not getting any water or even gurgling air. I'm not sure how long I can let pump run dry or if I need and there is a way to prime the pump. Mark 80FC35 |
04-18-2005, 14:41
unwinterizine
Should be self-priming, ... is an '80 under the galley sink? If so,
remove the pegboard behind/below the sink, find the pump. Careful, the original pump is belt-drive and it will bite. You can disconnect the lines to see if water is making it to the pump, might be a stuck check valve or other on the suction side (had that before). The original pump will run dry, should self-prime. If it doesn't, you can buy a new pump/valve body from BB (Par pump) for relatively little $$, or replace with shur-flo or equivalent. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Mark" > > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 |
04-18-2005, 15:40
unwinterizine
> > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 Mark, you did turn your tank fill switch off didn't you? The pump won't pump water with it on the fil position. I've got the over 50 sydrome. Been there, done that more than once. Sid Clark in Dallas-91WBSA40 |
04-18-2005, 17:42
unwinterizine
Sid, don't think there is a tank fill switch on my 80. I have two water
connections in the connection box. One is for city service and the other is for filling the tank. Mark Sid Clark <sidclark99@...> wrote: --- In WanderlodgeForum@yahoogroups.com, "Mark" > > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 Mark, you did turn your tank fill switch off didn't you? The pump won't pump water with it on the fil position. I've got the over 50 sydrome. Been there, done that more than once. Sid Clark in Dallas-91WBSA40 --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
04-18-2005, 18:11
unwinterizine
No the 80 I have is under the far forward part of the bathroom vanity.
Mark ps. I bet Randy will be glad to know I found the bathroom Jeff Miller Should be self-priming, ... is an '80 under the galley sink? If so, remove the pegboard behind/below the sink, find the pump. Careful, the original pump is belt-drive and it will bite. You can disconnect the lines to see if water is making it to the pump, might be a stuck check valve or other on the suction side (had that before). The original pump will run dry, should self-prime. If it doesn't, you can buy a new pump/valve body from BB (Par pump) for relatively little $$, or replace with shur-flo or equivalent. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Mark" > > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Do you Yahoo!? Yahoo! Small Business - Try our new resources site! [Non-text portions of this message have been removed] |
04-18-2005, 22:32
unwinterizine
Mark,
If all else fails, loosen or remove the hose that goes into the inlet side of your pump and let a bit of water run out. These pumps a supposed to be self priming but perhaps a bit of encouragement may help. Good luck, John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, "Mark" > > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 |
04-19-2005, 02:36
unwinterizine
> > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 Hi Mark, just something I did (forget to turn the breaker on in the closet??) a simple thought Rose Mary 82 FC 33 |
04-19-2005, 09:06
unwinterizine
When I had this problem with my 88fc, it was the pump. It gave the appearance of
"lost prime"...I could actually suck water into the lines and get it going sometimes. I bought a pump at west marine. It took less than an hur to install. The old pump looked like it came direct from Edisons lab. mark walk 88fc socal --- In WanderlodgeForum@yahoogroups.com, "Mark" > > I put potable water in tank, opened the kitchen & bathroom sink > facuets. When I turn the pump on, i'm not getting any water or even > gurgling air. I'm not sure how long I can let pump run dry or if I > need and there is a way to prime the pump. > > Mark > 80FC35 |
04-19-2005, 09:32
unwinterizine
Mark, I had the JABSCO pump in my 73FC go bad, so I removed it and
took it to Jabsco in Costa Mesa, and they exchanged it for a new unit, no charge.---- Where in SoCal are you? Jack Smith 1973FC31 Lake Forest SoCal --- In WanderlodgeForum@yahoogroups.com, "mw88fc" <mw88fc@y...> wrote: > > When I had this problem with my 88fc, it was the pump. It gave the appearance of > "lost prime"...I could actually suck water into the lines and get it going sometimes. > > I bought a pump at west marine. It took less than an hur to install. > > The old pump looked like it came direct from Edisons lab. > > mark walk > 88fc > socal > > --- In WanderlodgeForum@yahoogroups.com, "Mark" > > > > I put potable water in tank, opened the kitchen & bathroom sink > > facuets. When I turn the pump on, i'm not getting any water or even > > gurgling air. I'm not sure how long I can let pump run dry or if I > > need and there is a way to prime the pump. > > > > Mark > > 80FC35 |
04-20-2005, 03:21
unwinterizine
jack,
My 88fc is currently parked long term at Malibu rv....put it there after our last trip, and now I spend more time there than our place in Woodland Hills. mark 88fc socal --- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith" wrote: > > Mark, I had the JABSCO pump in my 73FC go bad, so I removed it and > took it to Jabsco in Costa Mesa, and they exchanged it for a new unit, > no charge.---- Where in SoCal are you? > Jack Smith > 1973FC31 > Lake Forest > SoCal > > --- In WanderlodgeForum@yahoogroups.com, "mw88fc" <mw88fc@y...> wrote: > > > > When I had this problem with my 88fc, it was the pump. It gave the > appearance of > > "lost prime"...I could actually suck water into the lines and get it > going sometimes. > > > > I bought a pump at west marine. It took less than an hur to install. > > > > The old pump looked like it came direct from Edisons lab. > > > > mark walk > > 88fc > > socal > > > > --- In WanderlodgeForum@yahoogroups.com, "Mark" > > > > > > I put potable water in tank, opened the kitchen & bathroom sink > > > facuets. When I turn the pump on, i'm not getting any water or even > > > gurgling air. I'm not sure how long I can let pump run dry or if I > > > need and there is a way to prime the pump. > > > > > > Mark > > > 80FC35 |
