unwinterizine
04-18-2005, 14:35
unwinterizine
I put potable water in tank, opened the kitchen & bathroom sink
facuets. When I turn the pump on, i'm not getting any water or even
gurgling air. I'm not sure how long I can let pump run dry or if I
need and there is a way to prime the pump.
Mark
80FC35
04-18-2005, 14:41
unwinterizine
Should be self-priming, ... is an '80 under the galley sink? If so,
remove the pegboard behind/below the sink, find the pump. Careful,
the original pump is belt-drive and it will bite. You can disconnect
the lines to see if water is making it to the pump, might be a stuck
check valve or other on the suction side (had that before).
The original pump will run dry, should self-prime. If it doesn't, you
can buy a new pump/valve body from BB (Par pump) for relatively
little $$, or replace with shur-flo or equivalent.
- Jeff Miller
http://www.wanderlodge.net
> Mark
> 80FC35
04-18-2005, 15:40
unwinterizine
> Mark
> 80FC35
Mark, you did turn your tank fill switch off didn't you? The pump won't
pump water with it on the fil position. I've got the over 50 sydrome.
Been there, done that more than once.
Sid Clark in Dallas-91WBSA40
04-18-2005, 17:42
unwinterizine
Sid, don't think there is a tank fill switch on my 80. I have two water
connections in the connection box. One is for city service and the other is for
filling the tank.
Mark
> Mark
> 80FC35
Yahoo! Groups Links
To visit your group on the web, go to:
Do You Yahoo!?
http://mail.yahoo.com
04-18-2005, 18:11
unwinterizine
No the 80 I have is under the far forward part of the bathroom vanity.
Mark
ps. I bet Randy will be glad to know I found the bathroom Smile
- Jeff Miller
> Mark
> 80FC35
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
04-18-2005, 22:32
unwinterizine
Mark,
If all else fails, loosen or remove the hose that goes into the
inlet side of your pump and let a bit of water run out. These pumps
a supposed to be self priming but perhaps a bit of encouragement may
help.
Good luck,
John Stiles
1980 33FC
"My Navion"
even
> Mark
> 80FC35
04-19-2005, 02:36
unwinterizine
> Mark
> 80FC35
Hi Mark,
just something I did (forget to turn the breaker on in the closet??)
a simple thought
Rose Mary
82 FC 33
04-19-2005, 09:06
unwinterizine
When I had this problem with my 88fc, it was the pump. It gave the appearance of
"lost prime"...I could actually suck water into the lines and get it going
sometimes.
I bought a pump at west marine. It took less than an hur to install.
The old pump looked like it came direct from Edisons lab.
mark walk
88fc
socal
> Mark
> 80FC35
04-19-2005, 09:32
unwinterizine
Mark, I had the JABSCO pump in my 73FC go bad, so I removed it and
took it to Jabsco in Costa Mesa, and they exchanged it for a new unit,
no charge.---- Where in SoCal are you?
Jack Smith
1973FC31
Lake Forest
SoCal
appearance of
going sometimes.
> mark walk
> 88fc
> socal
> > Mark
> > 80FC35
04-20-2005, 03:21
unwinterizine
jack,
My 88fc is currently parked long term at Malibu rv....put it there after our
last trip,
and now I spend more time there than our place in Woodland Hills.
mark
88fc
socal
--- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
> Jack Smith
> 1973FC31
> Lake Forest
> SoCal
> appearance of
> going sometimes.
> > mark walk
> > 88fc
> > socal
> > > Mark
> > > 80FC35
