FAN BLADE FOR AIR CONDITIONER
11-10-2006, 11:06
I am tryng to bring my dash air back to life on my 1983 FC-35 SB
When i got the condenser installed and engergized i discovered that
the white plastic fan Blade on one motor is broken. I have called blue
bird, they don't carry them any longer. does anyone know when to get
one.??
re brake 1983 FC-35 SB "Sagecoach"
11-10-2006, 12:12
Consider replacing the condenser with a 134a compatible unit. I used Red Dot.
Make sure you replace the receiver dryer and expansion valve. I got to do mine
twice because I didn't do the e/valve the first time, got clogged with debris.
Randy Dupree helped me out a good a bit on the rework and it's still working
fine.
MH
Sent: Friday, November 10, 2006 5:06 PM
Subject: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER
one.??
11-10-2006, 14:52
Mike,
Please provide the Red Dot parts and part numbers that you used. Thanks.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
fine.
>MH
11-11-2006, 00:01
Thanks mike: as i work at a CAT shop we will try the upgrade first, but i know
where to proceed if it fails
> From: Curt Sprenger
> Date: 2006/11/10 Fri PM 09:52:45 EST
> Subject: Re: [WanderlodgeForum] FAN BLADE FOR AIR CONDITIONER
> Mike,
Dot. Make sure you replace the receiver dryer and expansion valve. I got to do
mine twice because I didn't do the e/valve the first time, got clogged with
debris.
fine.
> >MH
11-11-2006, 06:31
I can't find the receipt, I found it on the Red Dot website, located a local
dealer and had them get it for me. The one I chose has two fans on top is
roughly 3 times the capacity of the original R 12 unit. 134 needs more
condensor.
MH
Sent: Friday, November 10, 2006 8:52 PM
Mike,
fine.
>MH
11-11-2006, 11:02
Mike,
Check this link. http://www.tknw.com/Products/RedDot/Condensers.asp
Any of the two fan units look like what you used?
condensor.
>MH
> From: Curt Sprenger
> Mike,
debris.
fine.
> >MH
>Yahoo! Groups Links
11-11-2006, 13:14
6260 is the one.
MH
Sent: Saturday, November 11, 2006 5:02 PM
Mike,
condensor.
>MH
> From: Curt Sprenger
> Mike,
debris.
working fine.
> >MH
>Yahoo! Groups Links
