injector pump
01-03-2006, 01:45
injector pump
ebay 8027104749
12-19-2006, 07:48
injector pump
In a message dated 12/19/2006 5:29:21 P.M. Mountain Standard Time,
kerry.edwards@... writes:
_http://boatdiesel.http://boathttp://boah...rum_Forum_
(http://boatdiesel.com/Forums/index.cfm?c...orum_ID=66)
Kerry-- that site is another pay for play site. Thanks, but I don't pay to
get info. Any other options?
83PT40
Weatherford, tx
Wanderlodgeforum- freely given info, freely taken
12-19-2006, 07:49
injector pump
Thanks, Curt, i'll look into some companies in Ft Worth, that can do that.
83PT40
Weatherford, tx
12-19-2006, 10:00
injector pump
My injector pump is leaking on my genset from a fitting on the top .
Ralphs is too- no we are not twins. Anyone done a removal ? I read in
the manual for perkins that says you have to time that thing when you
put her back. that leaves me out of that picture, for sure. Ernie-
83PT40 in Texas
12-19-2006, 11:16
injector pump
Ernie if it is a rack return, can you just route it to the tank?????? I
dont know about it but CurtS is expert on spending money on a perkins
GregoryO'Connor
94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
> 83PT40 in Texas
12-19-2006, 11:31
injector pump
Ernie,
Call a diesel specialty shop, one that rebuilds diesel fuel
pumps/injectors. Ask them if they will remove, service, reinstall/time
the pump. Might be a good time to tune up the injectors too. That's what
I did. The guy had me park the bus behind his shop. He removed the pump
and injectors. I drove the bus home. A few days later he called and I
took the bus back. He rebuilt the pump and the injectors, and
reinstalled/timed the unit. Part of the timing is getting the RPMs set,
and that is done by watching the gen-set AC voltage gauge until the set
is putting out 120V. If you do this be sure the fuel lines get sealed up
or diesel fuel will get all over.
I paid $800.00, which included servicing the Racor, new spin on fuel
filter, injector seals/o-rings, etc. Not cheap, but was less than taking
the bus to a shop that would keep the bus while working on the Yanmar.
Good luck.
Curt Sprenger
Anaheim Hills, Calif.
>83PT40 in Texas
>Yahoo! Groups Links
12-19-2006, 11:33
injector pump
Greg,
YANMAR, YANMAR...Not Perkins.
Curt Sprenger
>GregoryO'Connor
>>83PT40 in Texas
>Yahoo! Groups Links
12-19-2006, 12:20
injector pump
Here's a Perkins 108 forum. While it's devoted to boats, the engine's the same
so you may
find an answer to your question there.
Kerry
82 FC 35
Denver
