Check engine light
01-01-2007, 15:47
Check engine light
Reduced speed limit implies a low fluid level reading and not a
damage report. Is the puke sight glass clean???? put a wrench on it and take it out to see if it is truly full or just add 1/2 gallon to it. Tach may be a completly seperate issue. dont rule out that possibility. Dan gave good advice on cleaning things and looking for worn insulation or carbon marks on wires Seedsman? are you an Agronomist? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > 1991 8V92 DDEC II. "Check engine" light does not go out after 5 seconds > when ignition turned on ... tachometer inoperative. Engine runs fine > but speed restricted to 37 mph (computer I assume). Problem is > intermittent. After coach sits a few hours when the ignition switch is > turned on both the "stop engine" & "check engine" lights will go out > (normal sequence) & tach works & engine operation & speed are normal. > Then when switched off & re-started only the "check engine" light comes > on constantly ... "stop engine" light never comes on ... tach inop ... > speed restricted. > > I am suspect of a ground problem but don't have a clue where to start > the search. I'm also suspect of the DDEC II unit but want it to be > something much more simple ($$$$). > > All fluids normal, no noises, leaks, or performance issues when "check > engine" light is off ... but as you can imagine ... 37 mph is very > restrictive for most travels. > > Steve & Kathy Enfinger > '91 WBSA PT40 > |
01-02-2007, 00:55
Check engine light
Steve,
I assume that you have also changed your fuel filters. If they are clogged this will cause a no power situation. I have two the Raycor and a spin on....just a thought Jim Riordan 88WLWB XXV Stuart, Fl. Gregory OConnor Reduced speed limit implies a low fluid level reading and not a damage report. Is the puke sight glass clean???? put a wrench on it and take it out to see if it is truly full or just add 1/2 gallon to it. Tach may be a completly seperate issue. dont rule out that possibility. Dan gave good advice on cleaning things and looking for worn insulation or carbon marks on wires Seedsman? are you an Agronomist? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Steve & Kathy Enfinger" > > 1991 8V92 DDEC II. "Check engine" light does not go out after 5 seconds > when ignition turned on ... tachometer inoperative. Engine runs fine > but speed restricted to 37 mph (computer I assume). Problem is > intermittent. After coach sits a few hours when the ignition switch is > turned on both the "stop engine" & "check engine" lights will go out > (normal sequence) & tach works & engine operation & speed are normal. > Then when switched off & re-started only the "check engine" light comes > on constantly ... "stop engine" light never comes on ... tach inop ... > speed restricted. > > I am suspect of a ground problem but don't have a clue where to start > the search. I'm also suspect of the DDEC II unit but want it to be > something much more simple ($$$$). > > All fluids normal, no noises, leaks, or performance issues when "check > engine" light is off ... but as you can imagine ... 37 mph is very > restrictive for most travels. > > Steve & Kathy Enfinger > '91 WBSA PT40 > --------------------------------- Everyone is raving about the all-new Yahoo! Mail beta. [Non-text portions of this message have been removed] |
05-20-2009, 15:19
Check engine light
Dan,
My tranny took 7 gallons, the last time I changed it. There was still fluid in the lines and the cooler, as I did not flush it. I don't know if it makes a difference if it's a 4 or 5 speed. Also, you can read your own code, look next to the shift pad. Steve Gureasko 90WBWL401/2 Jus Chillin Ponchatoula, La. Just a short piece down the road from you. |
05-20-2009, 16:54
Check engine light
Steve, I have a four speed HTB741 and my book says 16 quarts including filter and cooler. When we checked it the fluid would not touch the stick so we added half a gallon to bring it up to the add cold line. The service tech said I don't care what the book says, the dip stick doesn't lie. Still I don't like it when there is an unexplained difference. I also noticed a warning the the owner's manual not to leave the transmission in drive for more than five minutes while stationary because of heat damage. I can see how that could happen in a traffic jam. Five minutes is not so long.
05-21-2009, 00:40
Check engine light
Hi Dan. As someone who hopes to join this merry band of Wanderlodge owners
someday, the maintenance things really interest me. I was able to find a "Mechanic's Tips" pamphlet for the 700 series transmissions. It on page 13 says a severely low level will cause your condition. The lowest fluid capacity it lists is 30 quarts. Hope this helps. http://www.allisontransmission.com/servl...bs&Fi\ leToGet=MT1958EN.pdf Bob McLaughlin Homosassa, Fl --- In WanderlodgeForum@yahoogroups.com, "Dan" > > Steve, I have a four speed HTB741 and my book says 16 quarts including filter and cooler. When we checked it the fluid would not touch the stick so we added half a gallon to bring it up to the add cold line. The service tech said I don't care what the book says, the dip stick doesn't lie. Still I don't like it when there is an unexplained difference. I also noticed a warning the the owner's manual not to leave the transmission in drive for more than five minutes while stationary because of heat damage. I can see how that could happen in a traffic jam. Five minutes is not so long. > > ----- Original Message ----- > From: patticake592000 > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 20, 2009 10:19 PM > Subject: [WanderlodgeForum] Re: Re: Check Engine Light > > > > > > Dan, > My tranny took 7 gallons, the last time I changed it. There was still > fluid in the lines and the cooler, as I did not flush it. > I don't know if it makes a difference if it's a 4 or 5 speed. > Also, you can read your own code, look next to the shift pad. > Steve Gureasko > 90WBWL401/2 Jus Chillin > Ponchatoula, La. Just a short piece down the road from you. > > > > > > > ------------------------------------------------------------------------------ > > > > No virus found in this incoming message. > Checked by AVG - http://www.avg.com > Version: 8.5.339 / Virus Database: 270.12.36/2125 - Release Date: 05/20/09 18:03:00 > |
05-21-2009, 04:40
Check engine light
Steve, you are correct. I had to add 2.5 gallons when I checked it hot. I don't understand why the manual says 16 quarts when the real number is 28 quarts. Anyway, thanks for your help and everyone else who replied.
Dan Williams,88wv38,Jackson,MS
05-22-2009, 08:25
Check engine light
