Cat 3208TA (non ATAAC) ratings
01-12-2007, 15:08
Hello,
Does anyone know exactly the HP (@ RPM) and torque (lb-ft @ RPM) ratings for
the 3208TA (non ATAAC) engines? There are versions rated 250 (don't confuse with
the 3208T version) and 280 HP (presumably at 2600 RPM for both) and maybe even a
300 HP version (2800 RPM).
Blue Bird used the 250 HP version in the 1985 and '86 model years of their
Wanderlodge FC series motorhomes.
~Ben (bene71281)
01-13-2007, 04:31
Ben: My Blue Box has the original Cat brochure on the ATAAC engine
300HP @2800, 743 lb. ft. of torque @ 1600, 1450 lbs. dry, approved
for RV's up to 36,000 GVW. For all you owners of 250 HP 3208's there is
one caveat: Brochure states: Not recommended for sustained, high
mileage, on-highway use.
Bruce
1988 FC35
"La Reina Gitana"
01-13-2007, 04:47
That's why you keep an eye on the crank shaft bearings.
MH
Sent: Saturday, January 13, 2007 10:31 AM
Subject: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings
Bruce
1988 FC35
"La Reina Gitana"
01-13-2007, 12:39
Mike Will an oil analysis tell you the bearing condition or do you need to
drop the pan?
Don
89 SP 36'
Butler, PA
MH
Bruce
1988 FC35
"La Reina Gitana"
________________________________________________________________________
Check out the new AOL. Most comprehensive set of free safety and security
tools, free access to millions of high-quality videos from across the web, free
AOL Mail and more.
01-13-2007, 12:49
Oil analysis is a good thing, keeps an eye on the head gaskets. I'm of the
opinion that by the time analysis shows excess metal, it's too late. It's a
better strategy to physically check the bearings at 100/125k miles. It's an
easy job compared to dealing with a bearing failure.
MH
Sent: Saturday, January 13, 2007 6:39 PM
Subject: Re: [WanderlodgeForum] Re: Cat 3208TA (non ATAAC) ratings
drop the pan?
Don
89 SP 36'
Butler, PA
MH
Bruce
1988 FC35
"La Reina Gitana"
AOL Mail and more.
01-14-2007, 14:33
Thanks Mike I'll keep that in mind next time in the shop. I'm still under
100K.
Don
89 SP 36'
Butler, PA At the Birds Nest on my way to FL
-----Original Message-----
Sent: Sat, 13 Jan 2007 7:49 PM
better strategy to physically check the bearings at 100/125k miles. It's an easy
MH
Mike Will an oil analysis tell you the bearing condition or do you need to drop
the pan?
Don
89 SP 36'
Butler, PA
MH
Bruce
1988 FC35
"La Reina Gitana"
Check out the new AOL. Most comprehensive set of free safety and security tools,
free access to millions of high-quality videos from across the web, free AOL
Mail and more.
AOL Mail and more.
01-14-2007, 17:39
Helloo Mike, A mutual friend mentioned that you may have owned a 1977 FC31, with
a 534 C.I. gas engine. If you did, would you drop me a line @
gnburke@... .... I have a couple questions concerning the 100 gal.
tank, and the engine. TIA, George Burke, 1977 FC31SB In now warm sunny N.C., at
least until Tues.
Sent: Saturday, January 13, 2007 7:49 PM
MH
drop the pan?
Don
89 SP 36'
Butler, PA
MH
Bruce
1988 FC35
"La Reina Gitana"
AOL Mail and more.
