Leaking fresh water tank
04-18-2007, 08:09
Art I had a leak in my water filter under the bed last year. When I
winterized I blew out the lines then put pink stuff in from the pump. It didn't get to the water filter. It had a real fine leak under pressure. It was hard to see. Don 89 SP 36' Butler, PA Art, just curious but do you have a hot water tank under your bed? On 18/04/07, amweath <_amweatherly@amweatherly_ (mailto:amweatherly@...) > wrote: > > Being as how the fresh water tank was empty, I thought I'd sanitize > it using the method described in the Bluebird manual. On entering the > coach the next morning I found the carpet on the right side of the bed > wet.Am I in big trouble? I've removed the mattress and the plywood > covering. It doesn't look like any of the plumbing is leaking. The next > step is to try and lift the tank out (it has been drained).Has anyone > done this? I'm wondering how much of the bed frame has to be taken > apart. Can these tanks be patched? > > Art Weatherly > Riverside Ca > '85 PT 36. > ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-18-2007, 09:23
it using the method described in the Bluebird manual. On entering the coach the next morning I found the carpet on the right side of the bed wet.Am I in big trouble? I've removed the mattress and the plywood covering. It doesn't look like any of the plumbing is leaking. The next step is to try and lift the tank out (it has been drained).Has anyone done this? I'm wondering how much of the bed frame has to be taken apart. Can these tanks be patched? Art Weatherly Riverside Ca '85 PT 36. |
04-18-2007, 10:04
On 18/04/07, amweath > > Being as how the fresh water tank was empty, I thought I'd sanitize > it using the method described in the Bluebird manual. On entering the > coach the next morning I found the carpet on the right side of the bed > wet.Am I in big trouble? I've removed the mattress and the plywood > covering. It doesn't look like any of the plumbing is leaking. The next > step is to try and lift the tank out (it has been drained).Has anyone > done this? I'm wondering how much of the bed frame has to be taken > apart. Can these tanks be patched? > > Art Weatherly > Riverside Ca > '85 PT 36. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
04-18-2007, 12:32
The hot water tank is not under the part I've uncovered (the rear 2 feet of the
bed still has its plywood cover. Art Weatherly Riverside Ca. '85 PT 36 ----- Original Message ----- From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 18, 2007 3:04 PM Subject: [SPAM] Re: [WanderlodgeForum] Leaking fresh water tank Art, just curious but do you have a hot water tank under your bed? On 18/04/07, amweath > > Being as how the fresh water tank was empty, I thought I'd sanitize > it using the method described in the Bluebird manual. On entering the > coach the next morning I found the carpet on the right side of the bed > wet.Am I in big trouble? I've removed the mattress and the plywood > covering. It doesn't look like any of the plumbing is leaking. The next > step is to try and lift the tank out (it has been drained).Has anyone > done this? I'm wondering how much of the bed frame has to be taken > apart. Can these tanks be patched? > > Art Weatherly > Riverside Ca > '85 PT 36. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
04-18-2007, 14:21
Art,
When you filled the water tank, did you fill it to the full reading on the water tank gauge and stop filling there, or did you fill it to running out of the overflow? The water heater is most likely under the area you have not removed the plywood. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Art Weatherly wrote: > The hot water tank is not under the part I've uncovered (the rear 2 > feet of the bed still has its plywood cover. > > Art Weatherly > Riverside Ca. > '85 PT 36 > ----- Original Message ----- > From: Rob Robinson > To: WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, April 18, 2007 3:04 PM > Subject: [SPAM] Re: [WanderlodgeForum] Leaking fresh water tank > > Art, just curious but do you have a hot water tank under your bed? > > On 18/04/07, amweath > > > > Being as how the fresh water tank was empty, I thought I'd sanitize > > it using the method described in the Bluebird manual. On entering the > > coach the next morning I found the carpet on the right side of the bed > > wet.Am I in big trouble? I've removed the mattress and the plywood > > covering. It doesn't look like any of the plumbing is leaking. The next > > step is to try and lift the tank out (it has been drained).Has anyone > > done this? I'm wondering how much of the bed frame has to be taken > > apart. Can these tanks be patched? > > > > Art Weatherly > > Riverside Ca > > '85 PT 36. > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > |
04-18-2007, 14:43
If you filled it full, the overflow tube may leak at the connection to
the top of the tank. BIll 88 FC --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > Being as how the fresh water tank was empty, I thought I'd sanitize > it using the method described in the Bluebird manual. On entering the > coach the next morning I found the carpet on the right side of the bed > wet.Am I in big trouble? I've removed the mattress and the plywood > covering. It doesn't look like any of the plumbing is leaking. The next > step is to try and lift the tank out (it has been drained).Has anyone > done this? I'm wondering how much of the bed frame has to be taken > apart. Can these tanks be patched? > > Art Weatherly > Riverside Ca > '85 PT 36. > |
