Checker cab as a tow car?
05-03-2005, 22:31
Anyone out there know if the Checker cab can be flat towed?
Mel MEllinger 85PT36 Fort Lauderdale |
05-03-2005, 23:48
--- In WanderlodgeForum@yahoogroups.com, "offngo" <melmellinger@m...>
wrote: > Anyone out there know if the Checker cab can be flat towed? > > Mel MEllinger > 85PT36 > Fort Lauderdale only if it has a standard transmission. an automatic would be the same as any other car. Harvey |
05-04-2005, 00:09
If it has the turbo 350 or 400 Transmission or a powerglide 2 speed
you have to install a driveshaft disconnect Stephen Cape0001 77fc35 --- In WanderlodgeForum@yahoogroups.com, "offngo" <melmellinger@m...> wrote: > Anyone out there know if the Checker cab can be flat towed? > > Mel MEllinger > 85PT36 > Fort Lauderdale |
05-04-2005, 02:42
I think the Checker used GM small block engines and 350/400
transmissions for many years. If the Checker you have in mind uses this drivetrain, then the towing requirements should be the same as a GM vehicle of the same period. If the Checker front end will track 4-down (not a given) then the worst case setup would be an auxillary transmission oil pump or a driveline disconnect. Bob Griesel --- In WanderlodgeForum@yahoogroups.com, "offngo" <melmellinger@m...> wrote: > Anyone out there know if the Checker cab can be flat towed? > > Mel MEllinger > 85PT36 > Fort Lauderdale |
