mystery tank under galley sink
06-11-2007, 13:49
My 82 FC has a blue tank under the galley sink. It is about 6" in
diameter and about a foot high. It says it is for use as a water softner tank, but i suspect it ts a whole bus water filter. It appears to be OEM bluebird.. does anyone know what it is for, and if it should be serviced? Thanks Jim |
06-11-2007, 22:25
I have a blue tank but it is not permanently fixed in the coach. It looks
like a small scuba tank. It is a water softner. It is replenished by filling it with rock salt, flushing the salt out and then hooking it up to the fresh water feed. On 11/06/07, bluebird3208 > > My 82 FC has a blue tank under the galley sink. It is about 6" in > diameter and about a foot high. It says it is for use as a water > softner tank, but i suspect it ts a whole bus water filter. It appears > to be OEM bluebird.. does anyone know what it is for, and if it should > be serviced? > > Thanks Jim > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
06-12-2007, 00:17
My 82 had a similar tank but it was grey. It had been disconnected. It is
a water softener. After sitting so long I would replace it if I was going to use it. I have seen the same unit at Camping world and in RV catalogues. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Rob Robinson Sent: Tuesday, June 12, 2007 3:26 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] mystery tank under galley sink I have a blue tank but it is not permanently fixed in the coach. It looks like a small scuba tank. It is a water softner. It is replenished by filling it with rock salt, flushing the salt out and then hooking it up to the fresh water feed. On 11/06/07, bluebird3208 > > My 82 FC has a blue tank under the galley sink. It is about 6" in > diameter and about a foot high. It says it is for use as a water > softner tank, but i suspect it ts a whole bus water filter. It appears > to be OEM bluebird.. does anyone know what it is for, and if it should > be serviced? > > Thanks Jim > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
