Chassis Heater operation
06-13-2007, 05:21
Question concerning the chassis heaters (the ones that operate on
Engine coolant)
I have turned up the thermostat, nothing happens, does the ignition
need to be on? or does the engine need to be running and up to
temperature, another switch that needs to be on?
Still new to Blue Bird and Still learning.
Dale Cooper
84 FC
Painesville, Oh.
06-13-2007, 05:30
Engine needs to be at operating temperature, winter switch on, thermostats on,
and gate
valves in the hoses open. (They are visible in the front wheel wells or by
looking up
between the engine and wheels)
Kerry
82 FC 35
Denver
> Engine coolant)
> Dale Cooper
> 84 FC
> Painesville, Oh.
06-13-2007, 05:40
Dale,
There are power switches right next to the vents... Check to make sure they are
on and the thermostat is on and above the room temps...
HTH
Sea Ya
Larry
NYC
84 35FCSB
----- Original Message ----
Sent: Wednesday, June 13, 2007 12:21:32 PM
Subject: [WanderlodgeForum] Chassis Heater operation
Engine coolant)
Dale Cooper
84 FC
Painesville, Oh.
____
Shape Yahoo! in your own image. Join our Network Research Panel today!
http://surveylink.yahoo.com/gmrs/yahoo_p...te.asp?a=7
06-13-2007, 05:51
Sir,
Nice clear direct answer and just what I needed, Thanks very much.
Dale Cooper
To:
Sent: Wednesday, June 13, 2007 1:30 PM
Subject: [WanderlodgeForum] Re: Chassis Heater operation
> on, and gate
> looking up
> Kerry
> 82 FC 35
> Denver
>> Engine coolant)
>> Dale Cooper
>> 84 FC
>> Painesville, Oh.
> Yahoo! Groups Links
06-13-2007, 07:48
Older birds have a "winter" valve to turn on before the chassis heat
will work. (Sorry, I don't know where it is.)
Pete Masterson
aeonix1@...
El Sobrante, CA
> Engine coolant)
> Dale Cooper
> 84 FC
> Painesville, Oh.
06-13-2007, 08:13
heat
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > Engine coolant)
ignition
> > Dale Cooper
> > 84 FC
> > Painesville, Oh.
Take a look under your coach, just about where the steering gear is
located at. There should be a vlv that has a hose goes to and from.
This will be the main operational vlv to opperate the water heaters
throughout the coach. Also if your coach is like mine there is a
switch above the drivers area that controls a pump back by the water
tank (under bed). This pump helps move the water from the front of
the coach to the back and then back to the front. You should be able
to hear this pump working when you start it up by listening for it
back in your bedroom.
Jon
Rebel Bird
Bremerton Washington
