Corian tabletop
07-16-2007, 04:34
Corian tabletop
My corian tabletop mysteriously developed 2 sharp edged cracks while
I was parked with the levelers down. I realize that it should be replaced by a professional but I wonder if anything I did contributed to the cracking. Also, what should I expect to pay for the job? Chuck Harrison Akron, Ohio 90SP36 |
07-16-2007, 04:44
Corian tabletop
I've been warned about putting very hot items on corian; i.e.,
pots and pans - always use a trivet of some sort. Is it possible that heat caused the cracks? David Brady '02 LXi, Smokey NC williamcharrison wrote: > > My corian tabletop mysteriously developed 2 sharp edged cracks while > I was parked with the levelers down. I realize that it should be > replaced by a professional but I wonder if anything I did contributed > to the cracking. Also, what should I expect to pay for the job? > > Chuck Harrison > Akron, Ohio > 90SP36 > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.6/902 - Release Date: 7/15/2007 2:21 PM > [Non-text portions of this message have been removed] |
07-16-2007, 04:56
Corian tabletop
Chuck,
Corian can, in many cases, be repaired invisibly. During the early 90's BB used some 1/4" Corian glued to plywood. While the two materials expand and contract about the same with changes in temperature, the best bet is to use 1/2" Corian over support strips. If your table top can be unscrewed from underneath, I would take it to a kitchen design/installation dealer that specializes in Corian. They can probably repair it to good as new condition. Cost of repair will be much less than a new one which will also vary greatly depending on how the edge was/is styled and built. Rich D. '99LXi43' CT ('90PT40' ![]() --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > I've been warned about putting very hot items on corian; i.e., > pots and pans - always use a trivet of some sort. Is it possible > that heat caused the cracks? > > David Brady > '02 LXi, Smokey > NC > > williamcharrison wrote: > > > > My corian tabletop mysteriously developed 2 sharp edged cracks while > > I was parked with the levelers down. I realize that it should be > > replaced by a professional but I wonder if anything I did contributed > > to the cracking. Also, what should I expect to pay for the job? > > > > Chuck Harrison > > Akron, Ohio > > 90SP36 > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.6/902 - Release Date: 7/15/2007 2:21 PM > > > > > > [Non-text portions of this message have been removed] > |
07-30-2007, 03:34
Corian tabletop
Anyone have any experience with cracking of the corian on the dining
room table? Mine has cracked in two places and I was told by the local table and counter shop that it can't be repaired because part of it has lifted (with razor sharp edges). Chuck harrison Akron, Ohio 90SP36 |
07-30-2007, 05:41
Corian tabletop
>Chuck-- on my 89, I havent had it crack. It is very heavy.My sp36 dining table was not convertable to a bed, so I did a conversion my self.I was worried about it cracking when laid down between seats so I use a step stool under it just in case. Now I have my sofa and table for sleepers. Does yours convert to a bed? > Anyone have any experience with cracking of the corian on the dining > room table? Mine has cracked in two places and I was told by the local > table and counter shop that it can't be repaired because part of it has > lifted (with razor sharp edges). > > Chuck harrison > Akron, Ohio > 90SP36 > |
07-31-2007, 01:14
Corian tabletop
Hi Ed,
No, it does not convert to a bed. -- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > >Chuck-- on my 89, I havent had it crack. It is very heavy.My sp36 > dining table was not convertable to a bed, so I did a conversion my > self.I was worried about it cracking when laid down between seats so I > use a step stool under it just in case. Now I have my sofa and table > for sleepers. Does yours convert to a bed? > > Anyone have any experience with cracking of the corian on the dining > > room table? Mine has cracked in two places and I was told by the > local > > table and counter shop that it can't be repaired because part of it > has > > lifted (with razor sharp edges). > > > > Chuck harrison > > Akron, Ohio > > 90SP36 > > > |
08-05-2007, 04:30
Corian tabletop
Hi Chuck,
What color is the top. Let me know. I may have the color you need in my shop. We are certified Corian fabricators and installers. Raymond Jordan Foretravel Maryland ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-05-2007, 08:08
Corian tabletop
Been gone to California for a week or so. I did not see a response to you
question. Corian will not crack unless it is unstable and moving around. The only repair is a new one and figure out why the original broke. Leroy Eckert 1990 WB-40"Smoke N Mirrors Niceville, FL Love that Texas Hill Country around the Comfort area. ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 30, 2007 10:34 AM Subject: [WanderlodgeForum] Corian tabletop Anyone have any experience with cracking of the corian on the dining room table? Mine has cracked in two places and I was told by the local table and counter shop that it can't be repaired because part of it has lifted (with razor sharp edges). Chuck harrison Akron, Ohio 90SP36 [Non-text portions of this message have been removed] |
08-06-2007, 01:56
Corian tabletop
It is an off-white, if I had to guess I would say bone.
--- In WanderlodgeForum@yahoogroups.com, RTJ49@... wrote: > > Hi Chuck, > What color is the top. Let me know. I may have the color you need in my > shop. We are certified Corian fabricators and installers. > > Raymond Jordan > Foretravel > Maryland > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > |
08-25-2007, 09:25
Corian tabletop
I never got a reply from you. I am a terrible judge of color but
I know it is off white. Chuck harrison Akron, Ohio 90WLSP36 --- In WanderlodgeForum@yahoogroups.com, RTJ49@... wrote: > > Hi Chuck, > What color is the top. Let me know. I may have the color you need in my > shop. We are certified Corian fabricators and installers. > > Raymond Jordan > Foretravel > Maryland > > > > ************************************** Get a sneak peek of the all- new AOL at > http://discover.aol.com/memed/aolcom30tour > > > [Non-text portions of this message have been removed] > |
