Air Steps--Resurfacing Ideas
08-06-2007, 02:25
The air steps on my '91SP are a rubber/vinyl tile that is a bit
shabby, especially the leading edge. There is a right angle piece of
aluminum serving as the edge on each step but it appears to have been
glued and re-glued in place numerous times. I'm about to re-glue it
but I know it will come off again and I'm wondering what ingenious
methods have been used to re-surface the steps. I did see a picture
on one of the forums where someone had replaced the step surface with
diamond plate shiny steel. I think I would like some practical and
durable tile-type surface with a leading edge that will last. Any
help welcome.
Austin
'91SP
08-06-2007, 04:11
Sent: Monday, August 06, 2007 9:25 AM
Subject: [WanderlodgeForum] Air Steps--Resurfacing Ideas
The last time I resurface mine I used a non skid that comes
8"x 18" sheets.I purchase it from home depot.
Bob Loomas 1985 PT 36
help welcome.
Austin
'91SP
08-06-2007, 07:24
Austin, you can install a black rubber stair tread on that step. Any large
carpet store-- not the big box stores can get you one. they come in 3, 4, and
6 foot lengths. I installed those in a number of coaches. There is a little
maintenance upkeep on the outside as with the suns rays it needs to be cleaned
often. Looks attractive on the steps especially with stainless steel risers.
83PT40
Livingston, Mt
08-07-2007, 11:10
Liz, yes they come in many colors. Trouble is-- you gotta buy a bunch to
justify the custom order.
I have a piece of outdoor carpet in a deep blue color that may do the trick,
instead of the outside tread.
83PT40
Livingston, Mt
08-07-2007, 14:25
large
3, 4, and
little
be cleaned
steel risers.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
Ernie, do you know if those rubber stair treads might come in colors
other than black?
Thanks,
Liz
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
Currently in Buena Vista, CO
all-new AOL at
08-07-2007, 22:23
If you can cut a straight line, you can buy a heavy rubber doormat from WalMart,
or even a heavy rubber automotive floormat, cut it to fit and use liquid nails
or Gorilla glue or some heavy double-stick tape to hold it on. A lot cheaper
than buying real rubber stair treads.Brad Barton 00LXiDFW bbartonwx@...
To: WanderlodgeForum@...: erniecarpet@...: Tue, 7 Aug
2007 23:10:23 -0400Subject: Re: [WanderlodgeForum] Re: Air Steps--Resurfacing
Ideas
Liz, yes they come in many colors. Trouble is-- you gotta buy a bunch to justify
the custom order.I have a piece of outdoor carpet in a deep blue color that may
do the trick, instead of the outside tread. Ernie Ekberg83PT40Livingston,
Mt************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour[Non-text portions of this message
have been removed]
Learn. Laugh. Share. Reallivemoms is right place!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
08-08-2007, 01:37
-I replaced mine with a plastic grass like door mat.They come in
colors I used a gray one.Cut to fit step, remove the "grass" from the
edge glue to step and replace the aluminum edge.A good place to wipe
your shoes .
Mario 1985FC in Marthas Vineyard without the Bird
-- In WanderlodgeForum@yahoogroups.com, "ajgibb2002"
> help welcome.
> Austin
> '91SP
08-08-2007, 02:01
To: wanderlodgeforum@yahoogroups.com
Sent: Wednesday, August 08, 2007 5:23 AM
Subject: RE: [WanderlodgeForum] Re: Air Steps--Resurfacing Ideas
the problem with rubber it sweats from the underside and
cause corrosion.Rubber back carpet cause mine to corrode bad.
WalMart, or even a heavy rubber automotive floormat, cut it to fit and use
liquid nails or Gorilla glue or some heavy double-stick tape to hold it on. A
lot cheaper than buying real rubber stair treads.Brad Barton 00LXiDFW
bbartonwx@...
Ideas
justify the custom order.I have a piece of outdoor carpet in a deep blue color
that may do the trick, instead of the outside tread. Ernie
Ekberg83PT40Livingston, Mt************************************** Get a sneak
peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour[Non-text
