Low Air Alarm
05-07-2005, 07:28
Low Air Alarm
After finding my air leak and replacing air regulator(?), after a few
minutes I am up to 120-125 PSI on front and rear guages. Front one is
slower. Now a few months later I am getting a low air alarm and dash
light. Can anyone tell me where the sensor is or any other pertinent
info on the issue.
Glenn Shehorn
83FCRb
Kansas City Mo (Tornado Alley)
05-07-2005, 08:00
Low Air Alarm
Hi Glenn,
The 66psi sensor is located in the area aft of the curbside air tank.
If you can locate the schraeder valve fitting, follow the plumbing to
a cross shaped junction. One of the pipes from this junction should
lead you right to the sender, one pipe comes from the pump, and one
goes to a 'T' then to each front tank.
Part #'s, BB 1145853, vendor B-W #104246.
Orange wire for the buzzer and light, not associated with the direct
pressure reading of each gauge.
Gary Miller
83 FC 33
Wauwatosa, WI
--- In WanderlodgeForum@yahoogroups.com, "glenn_shehorn"
few
is
> info on the issue.
> Glenn Shehorn
> 83FCRb
05-07-2005, 10:52
Low Air Alarm
the low air alarm sending unit is located just to the front of the entry
door,slide under the coach,look up,you will see an air tank ,on the top of this
tank is the sendor,on one end,screwed into a tee or some other
fitting.randydupree93wb
Sent: Saturday, May 07, 2005 3:28 PM
Subject: [WanderlodgeForum] Low Air Alarm
info on the issue.
Glenn Shehorn
83FCRb
Yahoo! Groups Links
