Trojan T-105
09-05-2007, 10:14
Trojan T-105
You're right, clocks, alarms and the 12vdc that goes to your refer. Those are
small and necessary. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: bloomas To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 05, 2007 1:41 PM Subject: Re: [WanderlodgeForum] Trojan T-105 ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 05, 2007 1:19 PM Subject: Re: [WanderlodgeForum] Trojan T-105 Thanks Dick Going to check mine out today.So far the only draw I have been able to fiend are the clocks. Bob Loomas 1985 PT 36 John, I have looked into the T-125's several times in the past years and have determined, at least for my purposes, that they just aren't cost effective. The cost per ah for the T-105 is the best deal I can find in a Trojan battery, even when comparing with the L-16. Now, if cost isn't an issue and/or one needs more ah and doesn't have the space to add enough T-105 batteries to meet the requirements, then I definitely would consider the T-125's or ever the L-16's. Just to give you an idea of our arrangement - we have 6, T-105 batteries and they are very adequate for our needs. We boon-dock for 5 months every winter. There are 5 solar panels on the roof (totaling about 460 watts and actually that's too many). We use the generator whenever ac power is needed for something that the inverter can't handle (i.e. air conditioners.) Off topic but related, I discovered a 4 amp, or so, draw that was not needed and will disconnect it when we will be boon-docking. That should make it even better than the last few years. The draw was the Sporlan Summer valve (bottom Sporlan valve) in the engine compartment. As originally wired by BB, that valve stays on when you are parked. I have no idea why it was that way. You always hear of "phantom" currents in our birds and this is the biggest single draw I have found. After turning the "A/T" switch off, the spot lights switch to left position and disconnecting a few relays that were always on and no longer needed, I think that I have reduced the phantom current to near zero. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: John Stiles To: wanderlodgeforum@yahoogroups.com Sent: Wednesday, September 05, 2007 3:38 AM Subject: [WanderlodgeForum] Trojan T-105 I have read several posts fairly recently where someone mentions Trojan T-105 batteries. If you are replacing your batteries and plan on staying with the T-105, take a look at the T-125 instead. Its the same foot print, fits in an FC easily and has greater AH ratings..... John Stiles 1980 33FC "My Navion" [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-05-2007, 10:16
Trojan T-105
I have not checked that Ernie. I will.
Thanx Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 05, 2007 1:34 PM Subject: Re: [WanderlodgeForum] Re: Trojan T-105 In the early birds, the step solenoid is always hot- another phantom draw. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour<http://discover.aol.com/memed/aolcom3\ 0tour> [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-05-2007, 10:23
Trojan T-105
Sure. As you're looking at the engine from the rear it is on the left side low
and in front of the reservoir for the steering on top of the rear frame. On mine there two Sporlan valves, one above the other. It's the bottom one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 05, 2007 2:30 PM Subject: Re: [WanderlodgeForum] Re: Trojan T-105 Dick can you elaborate on where in the engine compartment this valve is located. On 05/09/07, Richard Hayden > > John, > I only wish I could figure our why the valve is even needed at all. And > then to leave it in an on state when parked just does not make sense. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: John Stiles > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, September 05, 2007 12:53 PM > Subject: [WanderlodgeForum] Re: Trojan T-105 > > Way to go! I think you are the first that I recall who has pin > pointed this as a battery drain. Thanks! > > John Stiles > 1980 33FC > "My Navion" > > --- In WanderlodgeForum@yahoogroups.com > > "Richard Hayden" > > > > > > Off topic but related, I discovered a 4 amp, or so, draw that was > not needed and will disconnect it when we will be boon-docking. That > should make it even better than the last few years. The draw was the > Sporlan Summer valve (bottom Sporlan valve) in the engine > compartment. As originally wired by BB, that valve stays on when you > are parked. I have no idea why it was that way. You always hear > of "phantom" currents in our birds and this is the biggest single > draw I have found. After turning the "A/T" switch off, the spot > lights switch to left position and disconnecting a few relays that > were always on and no longer needed, I think that I have reduced the > phantom current to near zero. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-05-2007, 10:32
Trojan T-105
Thank you Dick. I guess the best way to find out why this valve is powered
is to disconnect the power and see what doesn't work. I agree it seems strange to have the valve powered on. On 05/09/07, Richard Hayden > > Sure. As you're looking at the engine from the rear it is on the left > side low and in front of the reservoir for the steering on top of the rear > frame. On mine there two Sporlan valves, one above the other. It's the > bottom one. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Rob Robinson > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, September 05, 2007 2:30 PM > Subject: Re: [WanderlodgeForum] Re: Trojan T-105 > > Dick can you elaborate on where in the engine compartment this valve is > located. > > On 05/09/07, Richard Hayden > > > > John, > > I only wish I could figure our why the valve is even needed at all. And > > then to leave it in an on state when parked just does not make sense. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > > From: John Stiles > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Sent: Wednesday, September 05, 2007 12:53 PM > > Subject: [WanderlodgeForum] Re: Trojan T-105 > > > > Way to go! I think you are the first that I recall who has pin > > pointed this as a battery drain. Thanks! > > > > John Stiles > > 1980 33FC > > "My Navion" > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > "Richard Hayden" > > > > > > > > > > Off topic but related, I discovered a 4 amp, or so, draw that was > > not needed and will disconnect it when we will be boon-docking. That > > should make it even better than the last few years. The draw was the > > Sporlan Summer valve (bottom Sporlan valve) in the engine > > compartment. As originally wired by BB, that valve stays on when you > > are parked. I have no idea why it was that way. You always hear > > of "phantom" currents in our birds and this is the biggest single > > draw I have found. After turning the "A/T" switch off, the spot > > lights switch to left position and disconnecting a few relays that > > were always on and no longer needed, I think that I have reduced the > > phantom current to near zero. > > > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
