chassis heater problem
11-15-2007, 04:36
Robert, I assume you have the front chassis thermostat set to a warmer temp.
And you have the winter/summer switch, the front heat switch to on.and the
aux pump switched to on.
83PT40
************************************** See what's new at http://www.aol.com
11-15-2007, 04:39
Oh- and you can visually check your small water pumps to see that they are
moving- thus insuring coolant movement.
83PT40
11-15-2007, 06:33
I have been trying to figure this situation out for several days now
and cant seem to solve it. The chassis heater under the sofa up front
and the dash heaters do not blow hot air, All the other ones work
great. This morning I replaced the two sporlan valves in the back
with manual valves to make sure they werent the problem and they
werent. The auxillary pump works and runs but is it possible that it
is not working good enough? I thought that there may be air in the
lines up front so I installed a valve with a female hose connector in
the wheelwell under the sofa chassis heater. There was a lot of
coolant in that line and it was quite a mess to put it on. I did put
hose pressure on after I installed it and it quickly started to
overflow out of the coolannt cap that was removed. I located a small
bleed screw on the line below the dash heater and coolant sprayed out
of it as soon as I loosened it.
What should I do, im sure puzzled. Should I put another t in
somewhere with a valve on either side and then hook the hose to it
and shut one side then the other to clear any possible blocks, or am
I overlooking some component.
Robert Rahn
88 pt 40
warner robins ga
11-15-2007, 08:14
Robert,
Our front radiator FC has three Sporlan valves, and two gate valves,
although the drawing shows three gate valves.
Your rear radiator is probably plumbed different,
But my guess is: you have not found all the valves , look for
another Sporlan valve (maybe up front, near the cold heater) and
another gate valve.
Do you have a front heater switch on the dash??????
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn"
now
front
it
in
put
small
out
am
> Robert Rahn
> 88 pt 40
> warner robins ga
11-15-2007, 10:43
>The water pump is definately working and I cant find any more valves
other than the two sporlin valves and the five red handle valves. I
wish I had some sort of map showing where everything was going. I can
feel the lines up front and they are cold for sure and the ones in the
real are warm.
they are
> Ernie Ekberg
> 83PT40
> Weatherford, Tx
http://www.aol.com
11-15-2007, 20:31
Robert, maybe I should have been a little bit more clear on the pumps I was
referring too. I did not mean the engine water pump, rather the 2 small
booster pumps located by the sporlan valves. On mine, you can see the shaft
rotation when they are in operation.
83PT40
11-16-2007, 02:24
Robert,
It took me two years to figure out that one of the gate valves was not
opening- even though the handle was turning. My guess is that the gate
valve controlling flow to or from the front loop is closed-
permanently. I know I hated to do it, but eventually you should check
to make sure that the threads are not stripped in the gate on the
valves. Most of the innards can be removed without pulling the hoses
off. You just have to hold the body firmly with a large wrench while
unscrewing the valve shaft and gate assembly.
Shane Fedeli
85PT40
Hershey, PA
> Robert Rahn
> 88 pt 40
> warner robins ga
11-16-2007, 05:24
Shane that is great news becaus the valve that seems to remain cold
is the one next to the transmission dipstick and looks to be very
difficult to remove. Is that the one that went bad on yours? RObert
-- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...>
> Robert,
not
gate
check
> Shane Fedeli
> 85PT40
> Hershey, PA
now
front
it
connector in
put
small
out
it
am
> > Robert Rahn
> > 88 pt 40
> > warner robins ga
11-16-2007, 05:30
Robert,
I have switch[s] on the dash that must be own for the front heaters to work.
Howard Truitt, Camilla, Ga. 86 PT40
Sent: Thursday, November 15, 2007 1:33 PM
Subject: [WanderlodgeForum] chassis heater problem
Robert Rahn
88 pt 40
warner robins ga
Checked by AVG Free Edition.
Version: 7.5.486 / Virus Database: 269.15.34/1134 - Release Date: 11/16/2007
9:52 AM
11-16-2007, 22:22
Robert-
It was the valve that closes the line coming out of the water pump
body. I would have never known, had I not pulled the water pump and
replaced it this past summer. The gate valves are made to service, and
the cap around the shaft has threads and can be spun off- allowing you
to remove the gate altogether. Removing the whole valve assembly would
be nearly impossible without removing the water pump. Just be ready to
stuff a rag or some putty in the hole to keep the coolant from
draining while you shop around for a replacement gate. A large
plumbing supply house should be able to get you one.
-Shane
> -- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@>
> > Robert,
> not
> gate
> check
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
