(No subject)
04-28-2005, 14:34
(No subject)
really need to get this rear main seal fixed. Does anyone know of a good
place in Wash (preferably close to Seattle) they would entrust with a bigger job like that? Thanks Al S. '81 31' FC Coos bay [Non-text portions of this message have been removed] |
07-30-2005, 02:26
(No subject)
Bruce; I just replaced the exhauste mqnifold on my 91 8V92 , one of the ears
was broken off. I had an used manifold so it was not much of an expense. I don't know what the torque setting is. Dave 1991 WLPT0 & 82 FC 35 >From: "Bruce Johnson" <bjsc4363@...> >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] 8v92 exhaust >Date: Thu, 28 Jul 2005 12:44:57 -0000 > [Non-text portions of this message have been removed] |
10-17-2006, 03:49
(No subject)
This is just going to be a quick note to let you all know
that we have started our maiden voyage. We drove from Terrace, B.C. to Archer Florida in 6 days. After installing new tires, doing some more minor maintenance on the coach, and purchased a new car hauler we are on our way. Presently we are in Texas and having put almost 1,500 miles under our belts, this is an awesome coach to drive. Here are some facts from this coach: Turbo boost 11psi Turbo pyro 850F, engine oil temp 200, transmission oil temp 200, engine oil pressure 75, engine water temp 195, charging 60 amps, engine shifts 2200-2400 rpm, We had a problem with generator, and it was caused by not enough voltage to the field, (battery voltage only 10 volts, once plugged into shore it went back to 13.6volts) will have to check into this later. Otherwise all things going smoothly. See you guys and gals in Buellton. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada [Non-text portions of this message have been removed] |
01-09-2007, 03:48
(No subject)
Congratulations Don. We'll see you soon at QZ. We leave Sunday from
Dallas and will stop a couple days in Phoenix for a little golf and visits. Let me know if You need anything picked up in Phoenix while I'm there. I assume you are just south of the tent. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > We picked up our new-to-us 90 PT40 today, and drove it back from Phoenix to Quartzsite. Swapping out starts tomorrow with the major task of moving satellite dishes, although I'm only going to move 2 of the 3, I think (yes, I have 3 now ![]() already up there, but it means there will still be 3. > > First couple of things: > > I suspect I may have some 12vdc issues, but I'm not sure - it will take some investigating. The dash DC voltage did not go over 13 volts. The previous owner installed a 2000 watt Prosine, and its display said that there was battery overheating. Neither alternator showed much amperage at all. > > At the back, upper right by the bulk oil gauge, is a blower fan. intake points at back grill, output goes through a hose to a long rectangular box against the top of the engine compartment at the extreme back. Did not see where the air could go after that. It was running after shut down. What is it? > > > Don Bradner > 90 PT40 without-a-name so far > |
05-04-2007, 10:18
(No subject)
For what it's worth,
All the years I owned my 84FC and 86Newell, I was constantly told that diesel fuel additives were totally unnecessary for Cat and Detroit engines. I presume the same for Cummins. But with the new Ultra Low Sulfur Diesel Fuel, I'll pass along what I recently heard from a big truck mechanic. He said the long term damage done but less-lubrication in the fuel would show up as premature friction-wear on internal parts and reduced performance from the fuel injectors. And since it would take place over a long period of time, it's something we probably wouldn't detect until too late. He recommended Power Service Diesel Kleen (summer) and Diesel Fuel Additive (winter) at roughly one quart per 100 gallons or 96 ounces per 300 gallons. Both sizes are now available at WalMart, which, by the way is slowly adding to its RV supplies. I don't know whether they carry the other brand, Howes (I didn't notice it). It was nice not to have to drive out of town to a truck stop to get it. Brad Barton 00LXiDFW bbartonwx@... _________________________________________________________________ Need a break? Find your escape route with Live Search Maps. http://maps.live.com/default.aspx?ss=Res...=33.8\ 32922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=\ 1&FORM=MGAC01 |
05-06-2007, 03:25
(No subject)
If any of you are looking for a very nice PT 40 i have a 1983 for sale. The
coach is located in NC. Contact me for details and pictures Fred Brown Southern Pines , NC. [Non-text portions of this message have been removed] |
06-07-2007, 15:46
(No subject)
Leroy and JEH
I would sincerely appreciate you keeping your opinions and your two cents worth to your selves when it comes to something you know absolutely nothing about, and that is me, my coach, and the buyer OR our agreements or how I choose to conduct MY business. Tom Meservey, USN (Ret) --------------------------------- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. [Non-text portions of this message have been removed] |
08-11-2007, 13:54
(No subject)
Hi Guys and Gals,
While going over the Bus today for some maintenance, I found that the generator injection pump was leaking from the throttle post and underneath at the rear of the pump... Can this be fixed without a major overhaul of the pump??? Also, would I be able to do it myself??? TIA Sea Ya Larry NYC 84 35FCSB ________________________________________________________________________________\ ____ Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. http://autos.yahoo.com/green_center/ [Non-text portions of this message have been removed] |
10-22-2007, 14:31
(No subject)
Barbara and I woould like to express our sympathys to both thw Morris
and Jensen families. What a tragic turn of events. Please everyone be careful out there and live every day to the fullest. Mike & Barbara McMahan 96 PT42 |
11-30-2007, 03:35
(No subject)
Hope everyone arrived safely! Have a WONDERFUL time! Sure wish we were there!
Would love to see some pics on the forum. Betsy & George Bush 83fc31 ________________________________________________________________________________\ ____ Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs [Non-text portions of this message have been removed] |
