8v92 temperature
12-10-2007, 00:05
8v92 temperature
Correction on my post. I should have said cut out instead of cut in point when
road surface temps are hot. Cut in is at the high temperature, cut out (turns the fan off) is at the lower temperature of the Alarmstat range. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Scott Forman <sforman@...> wrote: 8v92 owners...what temp does your engine run when cruising? Mine hovers around 190. When it creeps a bit past the 190 line on the gauge, I assume the fan kicks in, and it cools to just below 190 on the gauge. Then it heats back up and the process is repeated. Is this similar to other owners' experiences? Scott Forman 86 PT38 Memphis --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. [Non-text portions of this message have been removed] |
12-10-2007, 14:56
8v92 temperature
Curt: Do you know what temperature thermostats you are running in
your coach? Also what temperature is your alarmstat set to cycle the fan? I am about to have my cooling system cleaned and back-flushed. After that I will put in new alarmstat and thermostats. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Our '87 PT38 performed about the same...after new thermostats and radiator > cleaning the temp. runs about 180 and rarely climbs to 190 on the steep > grades. Oil temperature is running cooler as well. > > On Dec 9, 2007 5:49 PM, Scott Forman <sforman@...> wrote: > > > 8v92 owners...what temp does your engine run when cruising? > > > > Mine hovers around 190. When it creeps a bit past the 190 line on the > > gauge, I assume the fan kicks in, and it cools to just below 190 on the > > gauge. Then it heats back up and the process is repeated. > > > > Is this similar to other owners' experiences? > > > > Scott Forman > > 86 PT38 > > Memphis > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-10-2007, 18:12
8v92 temperature
Ron,
I'm running new 180 degree thermostats. Didn't touch the alarmastat. On Dec 10, 2007 6:56 PM, ronmarabito2002 > Curt: Do you know what temperature thermostats you are running in > your coach? Also what temperature is your alarmstat set to cycle the fan? > > I am about to have my cooling system cleaned and back-flushed. After > that I will put in new alarmstat and thermostats. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com > "Curt Sprenger" > > > > > Our '87 PT38 performed about the same...after new thermostats and > radiator > > cleaning the temp. runs about 180 and rarely climbs to 190 on the steep > > grades. Oil temperature is running cooler as well. > > > > On Dec 9, 2007 5:49 PM, Scott Forman <sforman@...> wrote: > > > > > 8v92 owners...what temp does your engine run when cruising? > > > > > > Mine hovers around 190. When it creeps a bit past the 190 line on the > > > gauge, I assume the fan kicks in, and it cools to just below 190 > on the > > > gauge. Then it heats back up and the process is repeated. > > > > > > Is this similar to other owners' experiences? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-11-2007, 07:56
8v92 temperature
Thanks Curt. Did you get your thermostats from Detroit? Those
puppies are expensive if you did. Anybody else furnish them that you know of? R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Ron, > I'm running new 180 degree thermostats. Didn't touch the alarmastat. > > On Dec 10, 2007 6:56 PM, ronmarabito2002 > > > Curt: Do you know what temperature thermostats you are running in > > your coach? Also what temperature is your alarmstat set to cycle the fan? > > > > I am about to have my cooling system cleaned and back-flushed. After > > that I will put in new alarmstat and thermostats. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com > > "Curt Sprenger" > > > > > > > > Our '87 PT38 performed about the same...after new thermostats and > > radiator > > > cleaning the temp. runs about 180 and rarely climbs to 190 on the steep > > > grades. Oil temperature is running cooler as well. > > > > > > On Dec 9, 2007 5:49 PM, Scott Forman <sforman@> wrote: > > > > > > > 8v92 owners...what temp does your engine run when cruising? > > > > > > > > Mine hovers around 190. When it creeps a bit past the 190 line on the > > > > gauge, I assume the fan kicks in, and it cools to just below 190 > > on the > > > > gauge. Then it heats back up and the process is repeated. > > > > > > > > Is this similar to other owners' experiences? > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-11-2007, 10:25
8v92 temperature
Ron,
All purchased from Detroit, thermostats $44.28 each, seals $14.20 each, gaskets $1.55 each. I'm not aware of anybody else that carries them. I think a big truck store would have them or can get them. On Dec 11, 2007 11:56 AM, ronmarabito2002 > Thanks Curt. Did you get your thermostats from Detroit? Those > puppies are expensive if you did. Anybody else furnish them that you > know of? > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com > "Curt Sprenger" > > > > > Ron, > > I'm running new 180 degree thermostats. Didn't touch the alarmastat. > > > > On Dec 10, 2007 6:56 PM, ronmarabito2002 > > > > > Curt: Do you know what temperature thermostats you are running in > > > your coach? Also what temperature is your alarmstat set to cycle > the fan? > > > > > > I am about to have my cooling system cleaned and back-flushed. After > > > that I will put in new alarmstat and thermostats. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > "Curt Sprenger" > > > > > > > > > > > Our '87 PT38 performed about the same...after new thermostats and > > > radiator > > > > cleaning the temp. runs about 180 and rarely climbs to 190 on > the steep > > > > grades. Oil temperature is running cooler as well. > > > > > > > > On Dec 9, 2007 5:49 PM, Scott Forman <sforman@> wrote: > > > > > > > > > 8v92 owners...what temp does your engine run when cruising? > > > > > > > > > > Mine hovers around 190. When it creeps a bit past the 190 line > on the > > > > > gauge, I assume the fan kicks in, and it cools to just below 190 > > > on the > > > > > gauge. Then it heats back up and the process is repeated. > > > > > > > > > > Is this similar to other owners' experiences? > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-11-2007, 11:42
8v92 temperature
Curt: Do you have a part number? For my S/N engine, they said I
needed #8924847 at a price of $117.57 per each. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Ron, > All purchased from Detroit, thermostats $44.28 each, seals $14.20 each, > gaskets $1.55 each. I'm not aware of anybody else that carries them. I think > a big truck store would have them or can get them. > > On Dec 11, 2007 11:56 AM, ronmarabito2002 > > > Thanks Curt. Did you get your thermostats from Detroit? Those > > puppies are expensive if you did. Anybody else furnish them that you > > know of? > > > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com > > "Curt Sprenger" > > > > > > > > Ron, > > > I'm running new 180 degree thermostats. Didn't touch the alarmastat. > > > > > > On Dec 10, 2007 6:56 PM, ronmarabito2002 > > > > > > > Curt: Do you know what temperature thermostats you are running in > > > > your coach? Also what temperature is your alarmstat set to cycle > > the fan? > > > > > > > > I am about to have my cooling system cleaned and back-flushed. After > > > > that I will put in new alarmstat and thermostats. > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > --- In > > WanderlodgeForum@yahoogroups.com > > > > > > "Curt Sprenger" > > > > > > > > > > > > > > Our '87 PT38 performed about the same...after new thermostats and > > > > radiator > > > > > cleaning the temp. runs about 180 and rarely climbs to 190 on > > the steep > > > > > grades. Oil temperature is running cooler as well. > > > > > > > > > > On Dec 9, 2007 5:49 PM, Scott Forman <sforman@> wrote: > > > > > > > > > > > 8v92 owners...what temp does your engine run when cruising? > > > > > > > > > > > > Mine hovers around 190. When it creeps a bit past the 190 line > > on the > > > > > > gauge, I assume the fan kicks in, and it cools to just below 190 > > > > on the > > > > > > gauge. Then it heats back up and the process is repeated. > > > > > > > > > > > > Is this similar to other owners' experiences? > > > > > > > > > > > > Scott Forman > > > > > > 86 PT38 > > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, CA > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-11-2007, 16:23
8v92 temperature
Ron,
Part numbers...thermostats #23503825 (old part #5102651), seals #5132155 ( no old part number), gaskets #5117786 (old part #6117438). On Dec 11, 2007 3:42 PM, ronmarabito2002 > Curt: Do you have a part number? For my S/N engine, they said I > needed #8924847 at a price of $117.57 per each. > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com > "Curt Sprenger" > > > > > Ron, > > All purchased from Detroit, thermostats $44.28 each, seals $14.20 each, > > gaskets $1.55 each. I'm not aware of anybody else that carries them. > I think > > a big truck store would have them or can get them. > > > > On Dec 11, 2007 11:56 AM, ronmarabito2002 > > > > > Thanks Curt. Did you get your thermostats from Detroit? Those > > > puppies are expensive if you did. Anybody else furnish them that you > > > know of? > > > > > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > "Curt Sprenger" > > > > > > > > > > > Ron, > > > > I'm running new 180 degree thermostats. Didn't touch the alarmastat. > > > > > > > > On Dec 10, 2007 6:56 PM, ronmarabito2002 > > > > > > > > > Curt: Do you know what temperature thermostats you are running in > > > > > your coach? Also what temperature is your alarmstat set to cycle > > > the fan? > > > > > > > > > > I am about to have my cooling system cleaned and back-flushed. > After > > > > > that I will put in new alarmstat and thermostats. > > > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > --- In > > > WanderlodgeForum@yahoogroups.com > > > > > > > > "Curt Sprenger" > > > > > > > > > > > > > > > > > Our '87 PT38 performed about the same...after new > thermostats and > > > > > radiator > > > > > > cleaning the temp. runs about 180 and rarely climbs to 190 on > > > the steep > > > > > > grades. Oil temperature is running cooler as well. > > > > > > > > > > > > On Dec 9, 2007 5:49 PM, Scott Forman <sforman@> wrote: > > > > > > > > > > > > > 8v92 owners...what temp does your engine run when cruising? > > > > > > > > > > > > > > Mine hovers around 190. When it creeps a bit past the 190 line > > > on the > > > > > > > gauge, I assume the fan kicks in, and it cools to just > below 190 > > > > > on the > > > > > > > gauge. Then it heats back up and the process is repeated. > > > > > > > > > > > > > > Is this similar to other owners' experiences? > > > > > > > > > > > > > > Scott Forman > > > > > > > 86 PT38 > > > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, CA > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
