Air compressor and "that hose"
12-26-2007, 17:36
Rob,
I'm not sure who it was that made the additional access hole. But, the good thing is to know it has been done before. I'm thinking it was done on a PT38. I believe the 40' + units have a slightly different frame/cross frame arrangement in that area. I've mentioned before to Randy that his skinny guy (worker) would have to be REAL skinny to get up beside the transmission on a 38 footer. On Dec 26, 2007 8:05 PM, Rob Robinson > Curt not sure if this is relevant but both Randy and I cut away some > plywood > to provide greater access when we were working on our alternators. After > removing the metal plate we found that we could cut away some of the > plywood > flooring closer to the passenger side outer wall. It was a square section > approx 6" X 6" > > > On 26/12/2007, Curt Sprenger > wrote: > > > > Scott, > > > > As I think about air compressor access...Someone on the sites cut a > second > > access panel to gain better access to the air compressor. Hopefully they > > will chime in here, or point us to a doc. addressing the creation of the > > second access panel. > > > > On Dec 26, 2007 7:24 PM, Curt Sprenger > > > wrote: > > > > > Scott, > > > > > > Very possible you will be that lucky; would be great. Be sure both > hoses > > > are newer or get replaced. > > > > > > Good luck! > > > > > > > > > On Dec 26, 2007 7:15 PM, Scott Forman < sforman@...<sforman%40renasant.com> > <sforman%40renasant.com>> > > wrote: > > > > > > > Thanks! This is great. I am hoping to God that I open up the hatch > > > > and see that those hoses are fresh and recent like the others on the > > > > engine...but I am sure I will not be so lucky > > > > > > > > Scott > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > "Curt Sprenger" > > > > > > > > > > > > > > > > > > Scott, > > > > > > > > > > Stick you head down in the hatch hole into the engine compartment > > > > The engine > > > > > air compressor is just forward of the cross member. Air compressor > > > > forward > > > > > hose (towards the front of the coach) runs to the curb side of the > > > > engine > > > > > block and above the starter. The rear hose runs to the manifold or > > > > head on > > > > > the curb side of the engine. Here is a link to a procedure I put > > > > together > > > > > some time ago. Check section "D". Let me know if you have any > > > > questions. > > > > > > > > > > *http://tinyurl.com/3a628w* > > > > > [Open in new window <http://tinyurl.com/3a628w>] > > > > > > > > > > > > > > > On Dec 26, 2007 3:24 PM, Rob Robinson > > > > > > > > > > > Scott there are two hoses. Hopefully Curt Sprenger will chime > > > > in here > > > > > > soon > > > > > > as he has done this job. Randy is in Bainbridge at his new house > > > > and might > > > > > > not be able to answer until later tonight. > > > > > > > > > > > > > > > > > > On 26/12/2007, Scott Forman <sforman@... > <sforman%40renasant.com>> > > > > > > wrote: > > > > > > > > > > > > > > This weekend, I am going to open up the hatch in the bedroom > in > > > > an > > > > > > > effort to look at my air compressor and the associated hose > > > > that has > > > > > > > been the topic of so much discussion around here. > > > > > > > > > > > > > > My questions is this: when I open the hatch up, where is the > > > > > > > compressor? I have only had it open once, and that was briefly > > > > just to > > > > > > > see if I could get it open. As I remeber, the exhaust pipe > > > > crosses > > > > > > > just below it and the alternator is directly below. Can > someone > > > > direct > > > > > > > me the the compressor and the hose? > > > > > > > > > > > > > > Thanks > > > > > > > Scott Forman > > > > > > > 86 PT38, 8v92 > > > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > Rob, Sue & Merlin Robinson > > > > > > 94 WLWB > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, CA > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > [Non-text portions of this message have been removed] > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-27-2007, 01:54
From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, December 26, 2007 9:46 PM Subject: Re: [WanderlodgeForum] Re: Air compressor and "that hose" When I replace mine I was able to do the job from the curb side of the coach and one fitting from under side. Bob Loomas 1985 PT36 Scott, As I think about air compressor access...Someone on the sites cut a second access panel to gain better access to the air compressor. Hopefully they will chime in here, or point us to a doc. addressing the creation of the second access panel. On Dec 26, 2007 7:24 PM, Curt Sprenger > Scott, > > Very possible you will be that lucky; would be great. Be sure both hoses > are newer or get replaced. > > Good luck! > > > On Dec 26, 2007 7:15 PM, Scott Forman < sforman@...> wrote: > > > Thanks! This is great. I am hoping to God that I open up the hatch > > and see that those hoses are fresh and recent like the others on the > > engine...but I am sure I will not be so lucky > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com > > "Curt Sprenger" > > > > > > > > > > Scott, > > > > > > Stick you head down in the hatch hole into the engine compartment > > The engine > > > air compressor is just forward of the cross member. Air compressor > > forward > > > hose (towards the front of the coach) runs to the curb side of the > > engine > > > block and above the starter. The rear hose runs to the manifold or > > head on > > > the curb side of the engine. Here is a link to a procedure I put > > together > > > some time ago. Check section "D". Let me know if you have any > > questions. > > > > > > *http://tinyurl.com/3a628w* > > > [Open in new window <http://tinyurl.com/3a628w>] > > > > > > > > > On Dec 26, 2007 3:24 PM, Rob Robinson > > > > > > > Scott there are two hoses. Hopefully Curt Sprenger will chime > > in here > > > > soon > > > > as he has done this job. Randy is in Bainbridge at his new house > > and might > > > > not be able to answer until later tonight. > > > > > > > > > > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>> > > > > wrote: > > > > > > > > > > This weekend, I am going to open up the hatch in the bedroom in > > an > > > > > effort to look at my air compressor and the associated hose > > that has > > > > > been the topic of so much discussion around here. > > > > > > > > > > My questions is this: when I open the hatch up, where is the > > > > > compressor? I have only had it open once, and that was briefly > > just to > > > > > see if I could get it open. As I remeber, the exhaust pipe > > crosses > > > > > just below it and the alternator is directly below. Can someone > > direct > > > > > me the the compressor and the hose? > > > > > > > > > > Thanks > > > > > Scott Forman > > > > > 86 PT38, 8v92 > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Rob, Sue & Merlin Robinson > > > > 94 WLWB > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
12-27-2007, 12:55
I was going to have mine checked when I was in Yakima, Wa. with air
problems. Tech searched around and finally found it on the passenger side frame rail. It is almost impossible to get to. A future project will be to get a new compressor and move it to a more easily accessable site. Bob Lawrence 84 PT 36 Fulltiming (presently in Peoria, Az) > This weekend, I am going to open up the hatch in the bedroom in an > effort to look at my air compressor and the associated hose that has > been the topic of so much discussion around here. > > My questions is this: when I open the hatch up, where is the > compressor? I have only had it open once, and that was briefly just to > see if I could get it open. As I remeber, the exhaust pipe crosses > just below it and the alternator is directly below. Can someone direct > me the the compressor and the hose? > > Thanks > Scott Forman > 86 PT38, 8v92 > Memphis > |
12-29-2007, 12:34
Hey Curt,
That link says "The document you requested could not be found." Any thoughts? I'd like to read that procedure, as I need to do this job myself. Thanks, -Ryan '86 PT-40 8V92 On Dec 26, 2007 7:00 PM, Curt Sprenger > > *http://tinyurl.com/3a628w* > [Open in new window <http://tinyurl.com/3a628w>] > |
12-29-2007, 12:39
I took some pictures today of my investigation, I will get them
posted with some commentary soon. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hey Curt, > > That link says "The document you requested could not be found." Any > thoughts? I'd like to read that procedure, as I need to do this job > myself. > > Thanks, > > -Ryan > '86 PT-40 8V92 > > On Dec 26, 2007 7:00 PM, Curt Sprenger > > > > *http://tinyurl.com/3a628w* > > [Open in new window <http://tinyurl.com/3a628w>] > > > |
12-29-2007, 15:21
*Ryan,
http://tinyurl.com/3bak3e . I think the tiny URLs go *away after some time. On Dec 29, 2007 4:34 PM, Ryan Wright > Hey Curt, > > That link says "The document you requested could not be found." Any > thoughts? I'd like to read that procedure, as I need to do this job > myself. > > Thanks, > > -Ryan > '86 PT-40 8V92 > > On Dec 26, 2007 7:00 PM, Curt Sprenger > wrote: > > > > *http://tinyurl.com/3a628w* > > [Open in new window <http://tinyurl.com/3a628w>] > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-30-2007, 08:01
Thanks Curt.
Scott, I appreciate your taking pictures & look forward to seeing them and reading your commentary. -Ryan On Dec 29, 2007 7:21 PM, Curt Sprenger > > *Ryan, > > http://tinyurl.com/3bak3e . I think the tiny URLs go *away after some time. |
12-30-2007, 08:53
Yes, me also. I would like to know about the exhaust clamps on your coach. They
look nice. Did you fabricate them? Mine have the lead type material inside a ring. While my hoses look substantially better than yours I intend to change them out. Does that bottom black hose go to the front of the compressor head? Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Ryan Wright Curt. Scott, I appreciate your taking pictures & look forward to seeing them and reading your commentary. -Ryan On Dec 29, 2007 7:21 PM, Curt Sprenger > > *Ryan, > > http://tinyurl.com/3bak3e . I think the tiny URLs go *away after some time. --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] |
12-30-2007, 09:20
Yes, that black (from oil & crud) hose goes to the top front of the
compressor. Of course, it is just beyond where the bulkhead is to make it tough to get to. The exhaust was replaced before I got the coach, can't speak about the clamps. Scott --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Yes, me also. I would like to know about the exhaust clamps on your coach. They look nice. Did you fabricate them? Mine have the lead type material inside a ring. > While my hoses look substantially better than yours I intend to change them out. Does that bottom black hose go to the front of the compressor head? > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > Ryan Wright Thanks Curt. > > Scott, I appreciate your taking pictures & look forward to seeing them > and reading your commentary. > > -Ryan > > On Dec 29, 2007 7:21 PM, Curt Sprenger > > > > *Ryan, > > > > http://tinyurl.com/3bak3e . I think the tiny URLs go *away after some time. > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > |
12-30-2007, 10:26
Leroy,
Try here for those clamps http://shop.ivalueinternet.com/shopdiese...n/home.htm Select exhaust hardware. The calmps look very similar. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Yes, me also. I would like to know about the exhaust clamps on your coach. They look nice. Did you fabricate them? Mine have the lead type material inside a ring. > While my hoses look substantially better than yours I intend to change them out. Does that bottom black hose go to the front of the compressor head? > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > Ryan Wright Thanks Curt. > > Scott, I appreciate your taking pictures & look forward to seeing them > and reading your commentary. > > -Ryan > > On Dec 29, 2007 7:21 PM, Curt Sprenger > > > > *Ryan, > > > > http://tinyurl.com/3bak3e . I think the tiny URLs go *away after some time. > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > |
