Large Zip Dee Awning mount/fastener pulled out from Bird Skin
05-16-2005, 10:55
How does one re-secure the lower, rear, mount... i.e. the one the
dogleg bar attaches to.... when the anchors/sleeves for the 3 screws
are stripped out???
Anyone done this? Thanks.
P.S. caused by a narrow bridge, a parked DOT truck and an err in
judgement.
05-16-2005, 11:39
move it over 1/2'' and rescrew it..randydupree93wb
Sent: Monday, May 16, 2005 6:55 PM
Subject: [WanderlodgeForum] Large Zip Dee Awning mount/fastener pulled out
from Bird Skin
are stripped out???
judgement.
Yahoo! Groups Links
05-16-2005, 13:09
You could probably secure some epoxy putty. Fill the holes and when
set, re-drill and put your screws back in.
Moderator
--- In WanderlodgeForum@yahoogroups.com, "luckyron1"
> are stripped out???
> 2000 LXI
> judgement.
05-16-2005, 13:17
Can you get behind that wall?
> > are stripped out???
> > 2000 LXI
> > judgement.
05-16-2005, 13:21
I've found JB weld does an excellent job of just what Ron is talking about. As
with any bonding agent, prep(cleaning the surface) is 75% of the battle.
Mark,
80FC35, still in PA
Moderator
> are stripped out???
> 2000 LXI
> judgement.
Yahoo! Groups Links
Yahoo! Mail Mobile
Take Yahoo! Mail with you! Check email on your mobile phone.
05-16-2005, 13:35
If they're screwed into the metal "riv-nut", then the old riv-nut can
be drilled out and a new one installed. You can also try a Helicoil
insert, large hardware stores carry them and most mechanics will know
what you are talking about.
- Jeff Miller
http://www.wanderlodge.net
> are stripped out???
> 2000 LXI
> judgement.
05-16-2005, 13:56
I have a lot of aluminum stock which I always find uses for when repairing
my 1982. I restored a 1976 GMC motorhome and had the same problem you are
experiencing,m pulled the bottom bracket off the body. I cut a piece of
1/4" aluminum(I polished it to a high luster) about 3" square and pop
riveted it to the body with an additional piece on the other side of the
body. Then I attached the awning bracket to that and its stronger then ever.
Tom
1982 FC35
Vernon Center,NY
> From: luckyron1
> out from Bird Skin
> are stripped out???
> 2000 LXI
> judgement.
