Genset regulator
06-04-2008, 14:01
Genset regulator
Greg
The box that houses the regulator and the circuit brakers and reset switch is insulated with rubber mounts and plenty of air space inside the box.Moving the regulator elswhere might be a good idea, but I don't know where.It sits about 10 inches from the back of the motor with room around it.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
06-04-2008, 14:13
Genset regulator
Fred
When I had my generator replaced at Power Tech last fall, they
replaced my regulator but they modified the mounting. The tech said
that they are now mounting them on long machine screws and three nuts
per screw. The regulator is mounted with about one inch space between
the back of the regulator and the box side. It seems like a
reasonable modification to keep air circulating around the unit.
Larry Kehler
1994 PT-40WBDA "BAM"
St Louis
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Greg
> Fred & Jeanne Hulse
> Morristown Arizona
06-04-2008, 14:33
Genset regulator
Larry
That is a good thought,I still have time to do that which I wil.
Thanks
Fred & Jeanne Hulse
Morristown Arizona
