dump sensor light
06-13-2008, 14:38
dump sensor light
1988 WBWL
I have been trying to resolve this problem. we got under the coach today and found.. Checked all three dump indicator pressure switches front and tag switches have two electrical leads drive axle has only one lead, a question mark. we aired up suspension tested each switch individually these switches are normally closed..all showed open..however the indicator light is still on. is there a relay for this system?? I am thinking that maybe it has gone bad.. Thoughts help suggestions (reasonable) would be greatly appreciated Jim Riordan 88 WBWL XXV stuart, fl 772-260-1328 |
06-13-2008, 16:35
dump sensor light
Does the buzzer go off when the bags air up but the light stays on?
GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Jim Riordan" wrote: > > 1988 WBWL > I have been trying to resolve this problem. we got under the coach > today and found.. > > Checked all three dump indicator pressure switches front and tag > switches have two electrical leads drive axle has only one lead, a > question mark. > > we aired up suspension tested each switch individually these switches > are normally closed..all showed open..however the indicator light is > still on. is there a relay for this system?? I am thinking that maybe > it has gone bad.. > > Thoughts > > help > > suggestions (reasonable) > > would be greatly appreciated > > Jim Riordan > 88 WBWL XXV > stuart, fl > 772-260-1328 > |
06-15-2008, 13:47
dump sensor light
yup! Gregory OConnor
06-15-2008, 17:25
dump sensor light
I think the light is a part of the suspension dump relay and
indicates that the relay is asked to dump????? The buzzer indicates that the bags have dumped (a low pressure is achived). May be the relay has a fault and wont stop sending 12v to the light I tested my light and it is grounded. on and off is the introduction of 12V+. The dump fuse is sk32 near the parklight fuse "lower front load center K38?????? It is some sort of timed relay and may look different. I realy have no Idea where it is these are just some hints from the plans I have yet sent to kinko's --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > yup! > > Gregory OConnor > Does the buzzer go off when the bags air up but the light stays on? > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Jim Riordan" > wrote: > > > > 1988 WBWL > > I have been trying to resolve this problem. we got under the coach > > today and found.. > > > > Checked all three dump indicator pressure switches front and tag > > switches have two electrical leads drive axle has only one lead, a > > question mark. > > > > we aired up suspension tested each switch individually these > switches > > are normally closed..all showed open..however the indicator light > is > > still on. is there a relay for this system?? I am thinking that > maybe > > it has gone bad.. > > > > Thoughts > > > > help > > > > suggestions (reasonable) > > > > would be greatly appreciated > > > > Jim Riordan > > 88 WBWL XXV > > stuart, fl > > 772-260-1328 > > > |
06-16-2008, 14:29
dump sensor light
Greg thanks.. Jessie says.. there are three low pressure sensor switchs on my coach. one is for steering and drive axle up front axle one is for tag axle by tag axle. and another one apparently near thefront load by the generatorfan there is supposed another sensor, something to do with the brake system?? I will try to locate it tomorrow and update.. Jim Riordan Gregory OConnor
06-16-2008, 19:03
dump sensor light
The pressure switch is turning off the buzzer! If some on is in
their '88ish pt coach could you check to see what turns the light on, is it a throw of the switch to dump???? or does it only come one once the buzzer sounds???? I still think it is the relay and not a switch GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > > Greg thanks.. > > Jessie says.. there are three low pressure sensor switchs on my coach. one is for steering and drive axle up front axle one is for tag axle by tag axle. and another one apparently near the front load by the generator fan there is supposed another sensor, something to do with the brake system?? I will try to locate it tomorrow and update.. > > Jim Riordan > Gregory OConnor > I think the light is a part of the suspension dump relay and > indicates that the relay is asked to dump????? The buzzer indicates > that the bags have dumped (a low pressure is achived). May be the > relay has a fault and wont stop sending 12v to the light I tested my > light and it is grounded. on and off is the introduction of 12V+. > The dump fuse is sk32 near the parklight fuse "lower front load > center K38?????? It is some sort of timed relay and may look > different. I realy have no Idea where it is these are just some > hints from the plans I have yet sent to kinko's > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > wrote: > > > > yup! > > > > Gregory OConnor > > Does the buzzer go off when the bags air up but the > light stays on? > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "Jim Riordan" > > wrote: > > > > > > 1988 WBWL > > > I have been trying to resolve this problem. we got under the > coach > > > today and found.. > > > > > > Checked all three dump indicator pressure switches front and tag > > > switches have two electrical leads drive axle has only one lead, > a > > > question mark. > > > > > > we aired up suspension tested each switch individually these > > switches > > > are normally closed..all showed open..however the indicator > light > > is > > > still on. is there a relay for this system?? I am thinking that > > maybe > > > it has gone bad.. > > > > > > Thoughts > > > > > > help > > > > > > suggestions (reasonable) > > > > > > would be greatly appreciated > > > > > > Jim Riordan > > > 88 WBWL XXV > > > stuart, fl > > > 772-260-1328 > > > > > > |
06-17-2008, 07:37
dump sensor light
06-17-2008, 08:45
dump sensor light
Drew, Do you know which relay they replaced. Thanks, MIke Mcmahan
--- In WanderlodgeForum@yahoogroups.com, Drew May wrote: > > FYI, just had my coach at Buddy Gregg with the exact same issue on my 1988 WB40 and they replaced a bad relay which apparently is going to resolve the issue. > > --- On Tue, 6/17/08, Gregory OConnor Gregoryoc@... wrote: > > From: Gregory OConnor Gregoryoc@... > Subject: [WanderlodgeForum] Re: dump sensor light > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, June 17, 2008, 12:03 AM > > > > > > > The pressure switch is turning off the buzzer! If some on is in > their '88ish pt coach could you check to see what turns the light > on, is it a throw of the switch to dump???? or does it only come one > once the buzzer sounds???? > > I still think it is the relay and not a switch > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@ yahoogroups. com, jim riordan jqrjr@ > wrote: > > > > > > Greg thanks.. > > > > Jessie says.. there are three low pressure sensor switchs on my > coach. one is for steering and drive axle up front axle one is for > tag axle by tag axle. and another one apparently near the front load > by the generator fan there is supposed another sensor, something to > do with the brake system?? I will try to locate it tomorrow and > update.. > > > > Jim Riordan > > Gregory OConnor Gregoryoc@ ..> wrote: > > I think the light is a part of the suspension dump relay > and > > indicates that the relay is asked to dump????? The buzzer > indicates > > that the bags have dumped (a low pressure is achived). May be the > > relay has a fault and wont stop sending 12v to the light I tested > my > > light and it is grounded. on and off is the introduction of 12V+. > > The dump fuse is sk32 near the parklight fuse "lower front load > > center K38?????? It is some sort of timed relay and may look > > different. I realy have no Idea where it is these are just some > > hints from the plans I have yet sent to kinko's > > > > --- In WanderlodgeForum@ yahoogroups. com, jim riordan <jqrjr@> > > wrote: > > > > > > yup! > > > > > > Gregory OConnor <Gregoryoc@> wrote: > > > Does the buzzer go off when the bags air up but the > > light stays on? > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Jim Riordan" <jqrjr@> > > > wrote: > > > > > > > > 1988 WBWL > > > > I have been trying to resolve this problem. we got under the > > coach > > > > today and found.. > > > > > > > > Checked all three dump indicator pressure switches front and > tag > > > > switches have two electrical leads drive axle has only one > lead, > > a > > > > question mark. > > > > > > > > we aired up suspension tested each switch individually these > > > switches > > > > are normally closed..all showed open..however the indicator > > light > > > is > > > > still on. is there a relay for this system?? I am thinking > that > > > maybe > > > > it has gone bad.. > > > > > > > > Thoughts > > > > > > > > help > > > > > > > > suggestions (reasonable) > > > > > > > > would be greatly appreciated > > > > > > > > Jim Riordan > > > > 88 WBWL XXV > > > > stuart, fl > > > > 772-260-1328 > > > > > > > > > > |
06-17-2008, 14:10
dump sensor light
do you lnow where that relay is?? Jim Riordan 772 260 1328 Drew May
06-17-2008, 15:24
dump sensor light
