Should we even be looking at Old Birds?
06-23-2008, 16:47
My wife and I really like a lot of things about vintage birds,
including the safety, reliability, and durability. I think a mid 80s FC would be about the best fit for us and our budget. The one with a double bed in the back, and 2 couches up front. I dont mind tinkering and working on a lot of projects. Our current coach is a 1989 Class C, I had to rebuild the entire cab over on that. But I'm by no means a mechanic. I do consider myself to be very mechanically inclined though. I can follow directions really well, if there are procedures on doing projects though. And based on what I know or believe things to cost, I can't afford to have a mechanic do every bit of maintenance these things need. The electrical problems concern me much less than mechanical ones. My question is, should I steer away from these old birds? Is the majority of the work something that an average person could do given patience and research/reading? Don't want to get myself in over my head. I would DEFINATELY want to hire someone to look at a unit before purchasing, to make sure I understood what I was getting myself into. If I get to that point, I'll be asking here for recommendations on who. |
06-24-2008, 01:19
Leroy, I've had mine one year to date. The short answer is "go for
it". The nice thing is you can decide how much you want to do. It's very much like vintage cars. You can buy one which needs a frame up restoration or you that just needs cleaned up a little. You decide. I wanted a vintage "Bird" and I wanted a project. Sounds like you are cut from the same cloth. It's a buyers market and you can get into this without selling the farm. The FC's are less complex then the PT's and less money. The PT's are better for people who are traveling long distances and or spending long periods of time in them. I've done more on my coach then I thought I would be able to do. I have jokingly said I am not as smart as a fifth grader and often do things the hard way but for the most part I've been able to work through my issues (with the help of this forum). I have and will farm out the difficult stuff. The positive is that when you are finished you have something of quality. So I say jump into the pool with the rest of us. The water is fine. You'll meet some real nice people trust me. John Heckman central Pa 1973 FC > > My wife and I really like a lot of things about vintage birds, > including the safety, reliability, and durability. I think a mid 80s > FC would be about the best fit for us and our budget. The one with a > double bed in the back, and 2 couches up front. > > I dont mind tinkering and working on a lot of projects. Our current > coach is a 1989 Class C, I had to rebuild the entire cab over on that. > But I'm by no means a mechanic. I do consider myself to be very > mechanically inclined though. I can follow directions really well, if > there are procedures on doing projects though. And based on what I > know or believe things to cost, I can't afford to have a mechanic do > every bit of maintenance these things need. The electrical problems > concern me much less than mechanical ones. > > My question is, should I steer away from these old birds? Is the > majority of the work something that an average person could do given > patience and research/reading? Don't want to get myself in over my > head. > > I would DEFINATELY want to hire someone to look at a unit before > purchasing, to make sure I understood what I was getting myself into. > If I get to that point, I'll be asking here for recommendations on who. > |
06-24-2008, 04:39
> coach is a 1989 Class C, I had to rebuild the entire cab over on that. You'll be fine. A lot of the work on an old coach is fixing house systems. If you can do basic household repairs (and it looks like you can), you'll be able to maintain these. Don't be tempted to cut corners and buy a cheap coach. Get something that has been well maintained and doesn't need any repairs at the time of purchase. It will cost you a bit more but will save you a lot of headaches later. In my experience, a vehicle that has a lot of little things wrong has been generally neglected and will have more ongoing maintenance issues. If an owner can't be bothered to fix the musical horn, how do I know he could be bothered to change fluids & filters, or to do something about that slight over-temp issue? > But I'm by no means a mechanic. I do consider myself to be very > mechanically inclined though. Yeah - you'll be fine. If you consider yourself mechanically inclined, don't even worry about it. If you can and are willing to change oil and fuel filters, the rest will come naturally. Always have some money set aside for the inevitable - you ARE going to have things break that you can't or don't want to fix. I've spent a couple grand having my transmission looked at, several hundred dollars having my alternator replaced, and another grand having my compressor replaced. I could have taken care of the alternator and compressor myself, but really didn't feel like doing it. > My question is, should I steer away from these old birds? Not at all! The fact is, you can buy a brand new vehicle and things are still going to fail. Sure, you'll have a warranty for a brief period, but that will soon go away and you'll be in the same boat. The old birds are built like tanks. This is nothing like owning an old version of any other coach. These are built to last and if you buy a coach that doesn't have anything wrong with it, I don't believe your maintenance will be any more intense whether you buy an 80's or a 90's or a 2000's, of this or any other brand. Maintenance is maintenance, you'll always have it. It's been quite tolerable on my coach. > Is the majority of the work something that an average person could do given > patience and research/reading? I think it is. If you're currently doing basic repairs on your house, changing your car's own oil, filters, belts, etc, and if you can generally troubleshoot basic automotive problems, then you'll be just fine and I say, go for it! -Ryan '86 PT-40 8V92 |
06-24-2008, 05:05
Hi.
Well, I purchased a FC, and although I aminclined to do most of my own work, I have found this forum as well as a few other forums of great help.
I also have had very good success in taking it to shops which allow me to work with the mechanic, and to get better knowledge of the coach.
In addition to this forum, there are two other forums to get help from:
My opinion, these machines drive like no other M/H, and when camping here in the north, I know the bears are going to have a hard time getting at me LOL. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada ----- Original Message ---- From: campingleroy To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 23, 2008 9:47:47 PM Subject: [WanderlodgeForum] Should we even be looking at Old Birds? My wife and I really like a lot of things about vintage birds, including the safety, reliability, and durability. I think a mid 80s FC would be about the best fit for us and our budget. The one with a double bed in the back, and 2 couches up front. I dont mind tinkering and working on a lot of projects. Our current coach is a 1989 Class C, I had to rebuild the entire cab over on that. But I'm by no means a mechanic. I do consider myself to be very mechanically inclined though. I can follow directions really well, if there are procedures on doing projects though. And based on what I know or believe things to cost, I can't afford to have a mechanic do every bit of maintenance these things need. The electrical problems concern me much less than mechanical ones. My question is, should I steer away from these old birds? Is the majority of the work something that an average person could do given patience and research/reading? Don't want to get myself in over my head. I would DEFINATELY want to hire someone to look at a unit before purchasing, to make sure I understood what I was getting myself into. If I get to that point, I'll be asking here for recommendations on who.
| [url=http://ca.toolbar.yahoo.com/]Yahoo! Canada Toolbar : Search from anywhere on the web and bookmark your favourite sites. Download it now!
06-24-2008, 05:10
LEROY:
I've had three birds; 77FC33...80FC31 and current 90SP36..... the first two are "bulletproof" and the SP is luxurious. Recommend u do your homework on what was added to birds each model year. For example 77 to early 80 was leaf springs and no airbags with the 210NA cat 3208. later 80 models had added weight, air bags, levelers, bath mod's 3208 mod's etc. If I was "starting over" I would seek an early 1980FC31 without airbags and levelers in good nic. hopefully the engine has been redone and the tranny is in good shape with no plate damage and the interior has been redone and it has been stored inside. How's that for a dreamlist?? LOL Regards, Hank 90SP36 --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > I dont mind tinkering and working on a lot of projects. Our current > > coach is a 1989 Class C, I had to rebuild the entire cab over on that. > > You'll be fine. A lot of the work on an old coach is fixing house > systems. If you can do basic household repairs (and it looks like you > can), you'll be able to maintain these. Don't be tempted to cut > corners and buy a cheap coach. Get something that has been well > maintained and doesn't need any repairs at the time of purchase. It > will cost you a bit more but will save you a lot of headaches later. > In my experience, a vehicle that has a lot of little things wrong has > been generally neglected and will have more ongoing maintenance > issues. If an owner can't be bothered to fix the musical horn, how do > I know he could be bothered to change fluids & filters, or to do > something about that slight over-temp issue? > > > But I'm by no means a mechanic. I do consider myself to be very > > mechanically inclined though. > > Yeah - you'll be fine. If you consider yourself mechanically inclined, > don't even worry about it. If you can and are willing to change oil > and fuel filters, the rest will come naturally. Always have some money > set aside for the inevitable - you ARE going to have things break that > you can't or don't want to fix. I've spent a couple grand having my > transmission looked at, several hundred dollars having my alternator > replaced, and another grand having my compressor replaced. I could > have taken care of the alternator and compressor myself, but really > didn't feel like doing it. > > > My question is, should I steer away from these old birds? > > Not at all! The fact is, you can buy a brand new vehicle and things > are still going to fail. Sure, you'll have a warranty for a brief > period, but that will soon go away and you'll be in the same boat. The > old birds are built like tanks. This is nothing like owning an old > version of any other coach. These are built to last and if you buy a > coach that doesn't have anything wrong with it, I don't believe your > maintenance will be any more intense whether you buy an 80's or a 90's > or a 2000's, of this or any other brand. > > Maintenance is maintenance, you'll always have it. It's been quite > tolerable on my coach. > > > Is the majority of the work something that an average person could do given > > patience and research/reading? > > I think it is. If you're currently doing basic repairs on your house, > changing your car's own oil, filters, belts, etc, and if you can > generally troubleshoot basic automotive problems, then you'll be just > fine and I say, go for it! > > -Ryan > '86 PT-40 8V92 > |
06-24-2008, 05:35
--- In WanderlodgeForum@yahoogroups.com, "campingleroy"
I have experience with quite a few mid 80s Birds, buying selling and "fixing on." My 83 rear bath suits the wife and I real well and I wouldn't trade it for a triple slide anything. Not even a Newell. That being said, I recommend 87 and newer FCs for those who wish to get into a vintage Bird. The engine and accessories are much easier to maintain due to improved design engine cover and swing radiator. 86 and older are a pain to adjust valves on, and that's not good. Moreover the 87 up has a charge air cooler and 300 hp., a very welcome feature when trying to get down the road. The ZF trans is a great piece and features OD. My 83 has been upgraded to 87 specs. Fiberglass engine cover, charge air cooler and inlet air enhancements. The Allison is backed by a drive line OD transmission in front of the Jake retarder. I was able to do all this 'stuff' to my Bird due the line of work I'm in. Much easier to just pay a little more and get the newer version, and it's all done for you. MH > > My wife and I really like a lot of things about vintage birds, > including the safety, reliability, and durability. I think a mid 80s > FC would be about the best fit for us and our budget. The one with a > double bed in the back, and 2 couches up front. > > I dont mind tinkering and working on a lot of projects. Our current > coach is a 1989 Class C, I had to rebuild the entire cab over on that. > But I'm by no means a mechanic. I do consider myself to be very > mechanically inclined though. I can follow directions really well, if > there are procedures on doing projects though. And based on what I > know or believe things to cost, I can't afford to have a mechanic do > every bit of maintenance these things need. The electrical problems > concern me much less than mechanical ones. > > My question is, should I steer away from these old birds? Is the > majority of the work something that an average person could do given > patience and research/reading? Don't want to get myself in over my > head. > > I would DEFINATELY want to hire someone to look at a unit before > purchasing, to make sure I understood what I was getting myself into. > If I get to that point, I'll be asking here for recommendations on who. > |
06-24-2008, 05:48
MIKE:
All the things u say are true AND I have all of that in my 90SP especially the GREAT ZF transmission...the largest transmission mmaker in europe..they make trannys for BMW's and Mercedes etc. As for my START recommendation at a low budget entry price, The 80FC31 is NOT underpowered and the valve adjust is not something the wife can do and I would hope the Swingout radiator mod has been made...maybe Leroy can find a 1980FC31 with a swingout radiator for less than 20 grand verses finding a 1987 of your recommedation for probably over 40 grand.....WE do not know his budget from what he wrote. LOL hope all is well in texas.....Naty & I will get to a Texas rally when Deisel drops below $3............."Dream...Dream..Dream!" Regards, Hank 90SP36 --- In WanderlodgeForum@yahoogroups.com, "michaelhohnstein" <MHOHNSTEIN@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "campingleroy" > > > I have experience with quite a few mid 80s Birds, buying selling > and "fixing on." My 83 rear bath suits the wife and I real well and > I wouldn't trade it for a triple slide anything. Not even a Newell. > That being said, I recommend 87 and newer FCs for those who wish to > get into a vintage Bird. The engine and accessories are much easier > to maintain due to improved design engine cover and swing radiator. > 86 and older are a pain to adjust valves on, and that's not good. > Moreover the 87 up has a charge air cooler and 300 hp., a very > welcome feature when trying to get down the road. The ZF trans is a > great piece and features OD. > My 83 has been upgraded to 87 specs. Fiberglass engine cover, > charge air cooler and inlet air enhancements. The Allison is backed > by a drive line OD transmission in front of the Jake retarder. > I was able to do all this 'stuff' to my Bird due the line of work > I'm in. Much easier to just pay a little more and get the newer > version, and it's all done for you. > MH > > > > > > My wife and I really like a lot of things about vintage birds, > > including the safety, reliability, and durability. I think a mid > 80s > > FC would be about the best fit for us and our budget. The one > with a > > double bed in the back, and 2 couches up front. > > > > I dont mind tinkering and working on a lot of projects. Our > current > > coach is a 1989 Class C, I had to rebuild the entire cab over on > that. > > But I'm by no means a mechanic. I do consider myself to be very > > mechanically inclined though. I can follow directions really > well, if > > there are procedures on doing projects though. And based on what > I > > know or believe things to cost, I can't afford to have a mechanic > do > > every bit of maintenance these things need. The electrical > problems > > concern me much less than mechanical ones. > > > > My question is, should I steer away from these old birds? Is the > > majority of the work something that an average person could do > given > > patience and research/reading? Don't want to get myself in over > my > > head. > > > > I would DEFINATELY want to hire someone to look at a unit before > > purchasing, to make sure I understood what I was getting myself > into. > > If I get to that point, I'll be asking here for recommendations on > who. > > > |
06-24-2008, 05:53
<MHOHNSTEIN@...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "campingleroy" > > > I have experience with quite a few mid 80s Birds, buying selling > and "fixing on." My 83 rear bath suits the wife and I real well and > I wouldn't trade it for a triple slide anything. Not even a Newell. > That being said, I recommend 87 and newer FCs for those who wish to > get into a vintage Bird. The engine and accessories are much easier > to maintain due to improved design engine cover and swing radiator. > 86 and older are a pain to adjust valves on, and that's not good. > Moreover the 87 up has a charge air cooler and 300 hp., a very > welcome feature when trying to get down the road. The ZF trans is a > great piece and features OD. > My 83 has been upgraded to 87 specs. Fiberglass engine cover, > charge air cooler and inlet air enhancements. The Allison is backed > by a drive line OD transmission in front of the Jake retarder. > I was able to do all this 'stuff' to my Bird due the line of work > I'm in. Much easier to just pay a little more and get the newer > version, and it's all done for you. > MH > > > > > > My wife and I really like a lot of things about vintage birds, > > including the safety, reliability, and durability. I think a mid > 80s > > FC would be about the best fit for us and our budget. The one > with a > > double bed in the back, and 2 couches up front. > > > > I dont mind tinkering and working on a lot of projects. Our > current > > coach is a 1989 Class C, I had to rebuild the entire cab over on > that. > > But I'm by no means a mechanic. I do consider myself to be very > > mechanically inclined though. I can follow directions really > well, if > > there are procedures on doing projects though. And based on what > I > > know or believe things to cost, I can't afford to have a mechanic > do > > every bit of maintenance these things need. The electrical > problems > > concern me much less than mechanical ones. > > > > My question is, should I steer away from these old birds? Is the > > majority of the work something that an average person could do > given > > patience and research/reading? Don't want to get myself in over > my > > head. > > > > I would DEFINATELY want to hire someone to look at a unit before > > purchasing, to make sure I understood what I was getting myself > into. > > If I get to that point, I'll be asking here for recommendations on > who. I would just say this and that is buy from a person who loves his old coach! Pay a little bit more but then most of the work has been done. As far as Vlv adjustment that only happens every 50,000 miles and my coach has only had that done two times. Yep and beside my old coach gets 10 mpg (1978) and the newer ones well we all know they were made for cheap fuel prices in mind. Jon > > > |
06-24-2008, 07:04
Leroy, I think everything that has been said is on target. You
certainly want the best that you can buy. No doubt the later FC's are considerably improved and being newer should in theory at least be in better condition. That being said there is always the debate as to how much a guy should spend on an FC before he considers a PT. I have never ridden in or experienced a late model FC but my thoughts are if I was going to spend upwards of 50K would I add to it a little (or a lot) and go with a PT. These are things you have to decide. I was there a year ago and I am certain all of us would agree that you should invest in some travel and time to investigate a number of these coaches before you buy. I think personal preference and how you are going to use the coach are the critical things to consider. I love my old 1973 but if I was intending to make a lot of long runs I would consider moving up. My coach is also smallish for more then two. I consider it like buying any vehicle you want to match it to your use as well as your pocket book. John Heckman central Pa 1973 FC > > --- In WanderlodgeForum@yahoogroups.com, "michaelhohnstein" > <MHOHNSTEIN@> wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "campingleroy" > > > > > > I have experience with quite a few mid 80s Birds, buying selling > > and "fixing on." My 83 rear bath suits the wife and I real well > and > > I wouldn't trade it for a triple slide anything. Not even a Newell. > > That being said, I recommend 87 and newer FCs for those who wish to > > get into a vintage Bird. The engine and accessories are much easier > > to maintain due to improved design engine cover and swing radiator. > > 86 and older are a pain to adjust valves on, and that's not good. > > Moreover the 87 up has a charge air cooler and 300 hp., a very > > welcome feature when trying to get down the road. The ZF trans is > a > > great piece and features OD. > > My 83 has been upgraded to 87 specs. Fiberglass engine cover, > > charge air cooler and inlet air enhancements. The Allison is > backed > > by a drive line OD transmission in front of the Jake retarder. > > I was able to do all this 'stuff' to my Bird due the line of work > > I'm in. Much easier to just pay a little more and get the newer > > version, and it's all done for you. > > MH > > > > > > > > > > My wife and I really like a lot of things about vintage birds, > > > including the safety, reliability, and durability. I think a mid > > 80s > > > FC would be about the best fit for us and our budget. The one > > with a > > > double bed in the back, and 2 couches up front. > > > > > > I dont mind tinkering and working on a lot of projects. Our > > current > > > coach is a 1989 Class C, I had to rebuild the entire cab over on > > that. > > > But I'm by no means a mechanic. I do consider myself to be very > > > mechanically inclined though. I can follow directions really > > well, if > > > there are procedures on doing projects though. And based on what > > I > > > know or believe things to cost, I can't afford to have a mechanic > > do > > > every bit of maintenance these things need. The electrical > > problems > > > concern me much less than mechanical ones. > > > > > > My question is, should I steer away from these old birds? Is the > > > majority of the work something that an average person could do > > given > > > patience and research/reading? Don't want to get myself in over > > my > > > head. > > > > > > I would DEFINATELY want to hire someone to look at a unit before > > > purchasing, to make sure I understood what I was getting myself > > into. > > > If I get to that point, I'll be asking here for recommendations > on > > who. > > > I would just say this and that is buy from a person who loves his old > coach! Pay a little bit more but then most of the work has been done. > As far as Vlv adjustment that only happens every 50,000 miles and my > coach has only had that done two times. Yep and beside my old coach > gets 10 mpg (1978) and the newer ones well we all know they were made > for cheap fuel prices in mind. Jon > > > > > > |
06-24-2008, 08:29
I also agree with everything I've read here. I own a 63 Bluebird
conversion and just recently purchased a 78FC35. I choose this bus to upgrade to a diesel, leveling jacks, bigger generator, etc.. I did not want air bags as I like to go off road often with a trailer full of quads and dirt bikes. I wanted something tough with ground clearance. I had the pleasure of driving my friends 90SP36 from Texas to Arizona not long ago. It was very nice, plush, fancy, and strong with the 300 HP Cat. However, it was just not for me. So old or new.. you can't go wrong with these busses. I'm a "bang-for-buck" kind of guy on a small budget so the FC's were perfect! Just another 2 cents... Michael 78FC35 "Putz'n Around" Mesa, Az --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Leroy, I think everything that has been said is on target. You > certainly want the best that you can buy. No doubt the later FC's > are considerably improved and being newer should in theory at least > be in better condition. That being said there is always the debate as > to how much a guy should spend on an FC before he considers a PT. I > have never ridden in or experienced a late model FC but my thoughts > are if I was going to spend upwards of 50K would I add to it a little > (or a lot) and go with a PT. These are things you have to decide. I > was there a year ago and I am certain all of us would agree that you > should invest in some travel and time to investigate a number of > these coaches before you buy. I think personal preference and how > you are going to use the coach are the critical things to consider. > I love my old 1973 but if I was intending to make a lot of long runs > I would consider moving up. My coach is also smallish for more then > two. I consider it like buying any vehicle you want to match it to > your use as well as your pocket book. > John Heckman > central Pa > 1973 FC > > > > --- In WanderlodgeForum@yahoogroups.com, "michaelhohnstein" > > <MHOHNSTEIN@> wrote: > > > > > > --- In WanderlodgeForum@yahoogroups.com, "campingleroy" > > > > > > > > > I have experience with quite a few mid 80s Birds, buying selling > > > and "fixing on." My 83 rear bath suits the wife and I real well > > and > > > I wouldn't trade it for a triple slide anything. Not even a > Newell. > > > That being said, I recommend 87 and newer FCs for those who wish > to > > > get into a vintage Bird. The engine and accessories are much > easier > > > to maintain due to improved design engine cover and swing > radiator. > > > 86 and older are a pain to adjust valves on, and that's not good. > > > Moreover the 87 up has a charge air cooler and 300 hp., a very > > > welcome feature when trying to get down the road. The ZF trans > is > > a > > > great piece and features OD. > > > My 83 has been upgraded to 87 specs. Fiberglass engine cover, > > > charge air cooler and inlet air enhancements. The Allison is > > backed > > > by a drive line OD transmission in front of the Jake retarder. > > > I was able to do all this 'stuff' to my Bird due the line of work > > > I'm in. Much easier to just pay a little more and get the newer > > > version, and it's all done for you. > > > MH > > > > > > > > > > > > > > My wife and I really like a lot of things about vintage birds, > > > > including the safety, reliability, and durability. I think a > mid > > > 80s > > > > FC would be about the best fit for us and our budget. The one > > > with a > > > > double bed in the back, and 2 couches up front. > > > > > > > > I dont mind tinkering and working on a lot of projects. Our > > > current > > > > coach is a 1989 Class C, I had to rebuild the entire cab over > on > > > that. > > > > But I'm by no means a mechanic. I do consider myself to be > very > > > > mechanically inclined though. I can follow directions really > > > well, if > > > > there are procedures on doing projects though. And based on > what > > > I > > > > know or believe things to cost, I can't afford to have a > mechanic > > > do > > > > every bit of maintenance these things need. The electrical > > > problems > > > > concern me much less than mechanical ones. > > > > > > > > My question is, should I steer away from these old birds? Is > the > > > > majority of the work something that an average person could do > > > given > > > > patience and research/reading? Don't want to get myself in > over > > > my > > > > head. > > > > > > > > I would DEFINATELY want to hire someone to look at a unit > before > > > > purchasing, to make sure I understood what I was getting myself > > > into. > > > > If I get to that point, I'll be asking here for recommendations > > on > > > who. > > > > > > I would just say this and that is buy from a person who loves his > old > > coach! Pay a little bit more but then most of the work has been > done. > > As far as Vlv adjustment that only happens every 50,000 miles and > my > > coach has only had that done two times. Yep and beside my old coach > > gets 10 mpg (1978) and the newer ones well we all know they were > made > > for cheap fuel prices in mind. Jon > > > > > > > > > > |
User(s) browsing this thread: 10 Guest(s)
