coolant leak
08-22-2008, 09:38
coolant leak
hello all,
Just moved the bird after a week or so of inactivity, and have a new problem. I
noticed
the low coolant light was on, and the stop engine light was lit. After a walk
around the
bus, I found a steady stream of coolant flowing out of my water bay. I'm
assuming a line
for the aquahot has failed, but havent verified this. Can anyone shed some light
on
making repairs in this area? I'm due to be leaving town on Wednesday, so I'm
somewhat
in a rush to get it repaired. Thanks again as always!
Corey and Jenni Graham
1996 PT 42 60series
Prosper, TX
08-22-2008, 09:46
coolant leak
Hi Corey:
First you need to indent where exactly the leak is, there is some lines
that are copper and some that are PEX, then you will know which line splice
to look for to do the repair, I am assuming it is a line, but there is a
good starting point. Or it could be as simple as tightening a connection,
but simple and Bluebird really don't belong in the same sentence.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 09:38 PM 8/22/2008 +0000, you wrote:
>hello all,
>problem. I noticed
>walk around the
>assuming a line
>light on
>I'm somewhat
>1996 PT 42 60series
>Prosper, TX
Safe travels,
Duncan, Oklahoma
