Losing coolant
10-23-2008, 13:17
Losing coolant
10-23-2008, 14:05
Losing coolant
The parts book that came with this coach calls for a 7 lb. I have no idea when
this one was changed to a 13 lb. There is a thread back in March of 2007 starting with post 20947 where Curt Sprenger said: "Coolant Pressure Control Cap...the 92 series manual recommends all series 92 on-highway vehicle engines use a minimum 9 psi control cap. My radiator cap is a 7 psi. Is this a Bluebird change? What are others using? Should I be concerned? The engine temperature runs at about 185 to 195." That thread ended up being more about alarmstats, misters, etc. but besides you (Leroy) mentioning that you had a 13, Pete posted in that thread that the shop that did his radiator replaced with a 15. I'm going to guess that a higher one gets used precisely because the 7 lb, as it loses strength, tends to let more slop out. If you think about it, a 7 lb with a boiling point somewhere above 230 degrees is into temperatures where the engine would be in real trouble anyway. Increasing the cap pressure to 13 takes boiling to 250, but does that really matter? I'm thinking I will go looking for a new cap tomorrow as an easy "maybe fix", and I will look for one around the same 13 lbs. On 10/23/2008 at 6:17 PM Leroy Eckert wrote: >I have a 13lb cap also and it is old. Same year. >Leroy Eckert >1990 WB-40 Smoke N Mirrors >Dahlonega, GA >Royale Conversion > >--- On Thu, 10/23/08, Joyce and Richard Hayden >From: Joyce and Richard Hayden >Subject: Re: [WanderlodgeForum] Losing coolant >To: WanderlodgeForum@yahoogroups.com >Date: Thursday, October 23, 2008, 8:32 PM > >Don, I would wonder why someone has put a 13 # cap on your cooling >system. The standard for these engines have been 7#. I haven't heard >of very many with anything above that. > >Dick Hayden - '87 PT 38 - Lake Stevens, WA - still in Medford, OR but on >the road again tomorrow after the tranny is fixed. |
10-23-2008, 14:07
Losing coolant
My 94 is a 7lb cap
2008/10/23 Don Bradner <"bluethunder@arcatapet.com">
-- Rob, Sue & Merlin Robinson 94 WLWB |
10-23-2008, 14:55
Losing coolant
10-23-2008, 15:20
Losing coolant
There are two springs in the cap a puke and a suck. when the rad
fluid cools it creates a vacumn and sucks the puked fluid out of the p tank and back into the system. Could be the return path (suck) is screwed and letting air enter on the path of least r theory some place. then when it pukes again the tank is overfilled. I think the suck is more of a check valve than a presssure thing???? I see your point about boil and 250 degree but I bet lots'a water up against the block gets close to 250 and sees greater expansion. we read 195 relative temp at a place remote to the heated area being cooled. I wonder if seven is the way to go but the puke tank is not sized properly considering the large volumn of fluid to displace in the Wanderlodge application. One of those places where fluid level wont prove a shutdown. if you are running the bus hot and pucking fluid in the tank that holds the level sender. may have been one of Rons lost chances for early shut down. Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The parts book that came with this coach calls for a 7 lb. I have no idea when this one was changed to a 13 lb. > > There is a thread back in March of 2007 starting with post 20947 where Curt Sprenger said: > > "Coolant Pressure Control Cap...the 92 series manual recommends all > series 92 on-highway vehicle engines use a minimum 9 psi control cap. > My radiator cap is a 7 psi. Is this a Bluebird change? What are others > using? Should I be concerned? The engine temperature runs at about 185 > to 195." > > That thread ended up being more about alarmstats, misters, etc. but besides you (Leroy) mentioning that you had a 13, Pete posted in that thread that the shop that did his radiator replaced with a 15. > > I'm going to guess that a higher one gets used precisely because the 7 lb, as it loses strength, tends to let more slop out. > > If you think about it, a 7 lb with a boiling point somewhere above 230 degrees is into temperatures where the engine would be in real trouble anyway. Increasing the cap pressure to 13 takes boiling to 250, but does that really matter? > > I'm thinking I will go looking for a new cap tomorrow as an easy "maybe fix", and I will look for one around the same 13 lbs. > > On 10/23/2008 at 6:17 PM Leroy Eckert wrote: > > >I have a 13lb cap also and it is old. Same year. > >Leroy Eckert > >1990 WB-40 Smoke N Mirrors > >Dahlonega, GA > >Royale Conversion > > > >--- On Thu, 10/23/08, Joyce and Richard Hayden wrote: > >From: Joyce and Richard Hayden > >Subject: Re: [WanderlodgeForum] Losing coolant > >To: WanderlodgeForum@yahoogroups.com > >Date: Thursday, October 23, 2008, 8:32 PM > > > >Don, I would wonder why someone has put a 13 # cap on your cooling > >system. The standard for these engines have been 7#. I haven't heard > >of very many with anything above that. > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA - still in Medford, OR but on > >the road again tomorrow after the tranny is fixed. > |
10-23-2008, 15:59
Losing coolant
I have trouble reconciling that with what I've seen - 15000 miles with virtually
no coolant addition required (except the very short period after I worked on the heating system), then 550 miles with 5 quarts used. The 15000 included a lot of nights colder than anything I've experienced in the past couple of weeks. I see these possiblities: unlikely: flowing into the crankcase unlikely: flowing into the transmission unlikely: burped some long-standing air pocket possible: flowing into the cylinders and going out the exhaust higher possible: hose leak under pressure higher possible: pressure cap bad The last one is easy to preemptively fix, and if I still lose fluid it is on to the pressure tester you recommended. After that? If I replace the cap and then lose no fluid I will assume either 3 or 6 was correct, and I won't care which it was. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Hilton Head, South Carolina My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 10/23/2008 at 11:36 PM David Brady wrote: >Don, > >At some point I think you mentioned pre-warming your engine >to 100 deg F prior to start, otherwise you get tons of smoke >out the exhaust. Randy mentioned that the 2-stroke diesels >will leak coolant into the cylinders when cold due to o-ring >shrinkage on the liners. Maybe this is what your seeing. |
10-23-2008, 16:36
Losing coolant
Don, At some point I think you mentioned pre-warming your engine to 100 deg F prior to start, otherwise you get tons of smoke out the exhaust. Randy mentioned that the 2-stroke diesels will leak coolant into the cylinders when cold due to o-ring shrinkage on the liners. Maybe this is what your seeing. David Brady '02 LXi, NC Gregory OConnor wrote:
10-23-2008, 16:39
Losing coolant
Curious, I had to go look at the radiator cap on Indulgance. 7LBS. and old. Any recommendations? No know problem with it. In my quest for a SS exhaust I've discovered. Stainless ain't cheep! Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > I have trouble reconciling that with what I've seen - 15000 miles with virtually no coolant addition required (except the very short period after I worked on the heating system), then 550 miles with 5 quarts used. The 15000 included a lot of nights colder than anything I've experienced in the past couple of weeks. > > I see these possiblities: > > unlikely: flowing into the crankcase > unlikely: flowing into the transmission > unlikely: burped some long-standing air pocket > possible: flowing into the cylinders and going out the exhaust > higher possible: hose leak under pressure > higher possible: pressure cap bad > > The last one is easy to preemptively fix, and if I still lose fluid it is on to the pressure tester you recommended. After that? > > If I replace the cap and then lose no fluid I will assume either 3 or 6 was correct, and I won't care which it was. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting today by satellite from Hilton Head, South Carolina > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 10/23/2008 at 11:36 PM David Brady wrote: > > >Don, > > > >At some point I think you mentioned pre-warming your engine > >to 100 deg F prior to start, otherwise you get tons of smoke > >out the exhaust. Randy mentioned that the 2-stroke diesels > >will leak coolant into the cylinders when cold due to o-ring > >shrinkage on the liners. Maybe this is what your seeing. > |
10-24-2008, 01:18
Losing coolant
Mine is 7lb., old, but pressure tested good. Only leaks are temp
related(outside temp), and coming from clamps. I installed new rad last year. No lose after clamp tighting. Remember there is a torque rating on tighting the clamps and some clamps are made offshore. That throws the torque rating out the window. Steve Gureasko 90WBWL40 Jus Chillin Ponchatoula, La. currently in chilly Eureka Springs Ark. |
10-24-2008, 06:57
Losing coolant
I suspect that 13-15 psi caps are more common. A 7 psi cap might
actually prove to be hard to find. (I've never had a vehicle with such a low pressure cap, except for a Model A Ford (with original engine) I had years ago... that I don't think was pressurized at all. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Max Meadows, VA On Oct 23, 2008, at 10:05 PM, Don Bradner wrote: > The parts book that came with this coach calls for a 7 lb. I have > no idea when this one was changed to a 13 lb. > > There is a thread back in March of 2007 starting with post 20947 > where Curt Sprenger said: > > "Coolant Pressure Control Cap...the 92 series manual recommends all > series 92 on-highway vehicle engines use a minimum 9 psi control cap. > My radiator cap is a 7 psi. Is this a Bluebird change? What are others > using? Should I be concerned? The engine temperature runs at about 185 > to 195." > > That thread ended up being more about alarmstats, misters, etc. but > besides you (Leroy) mentioning that you had a 13, Pete posted in > that thread that the shop that did his radiator replaced with a 15. > > I'm going to guess that a higher one gets used precisely because > the 7 lb, as it loses strength, tends to let more slop out. > > If you think about it, a 7 lb with a boiling point somewhere above > 230 degrees is into temperatures where the engine would be in real > trouble anyway. Increasing the cap pressure to 13 takes boiling to > 250, but does that really matter? > > I'm thinking I will go looking for a new cap tomorrow as an easy > "maybe fix", and I will look for one around the same 13 lbs. > > On 10/23/2008 at 6:17 PM Leroy Eckert wrote: > >> I have a 13lb cap also and it is old. Same year. >> Leroy Eckert >> 1990 WB-40 Smoke N Mirrors >> Dahlonega, GA >> Royale Conversion >> >> --- On Thu, 10/23/08, Joyce and Richard Hayden >> wrote: >> From: Joyce and Richard Hayden >> Subject: Re: [WanderlodgeForum] Losing coolant >> To: WanderlodgeForum@yahoogroups.com >> Date: Thursday, October 23, 2008, 8:32 PM >> >> Don, I would wonder why someone has put a 13 # cap on your cooling >> system. The standard for these engines have been 7#. I haven't >> heard >> of very many with anything above that. >> >> Dick Hayden - '87 PT 38 - Lake Stevens, WA - still in Medford, OR >> but on >> the road again tomorrow after the tranny is fixed. > > > > ------------------------------------ > > Yahoo! Groups Links > > > |
