Aqua hot instrument panel switch
01-25-2009, 12:37
Be aware that there is an "Aqua Hot Users" forum within Yahoo Groups.
Just like this forum, it seems to be pretty active. Not having the diesel portion of the Aqua Hot available during freezing weather is ugly. I hope you get it fixed quickly. One additional comment: The Aqua Hot/Vehicle Systems Inc. manuals are among the best I have encountered for my ride. If you don't have one run a Google search for Aqua Hot Manual. There are about three different manuals if I recall correctly. Just after I bought my bird I had a large dealer in OR repair my Aqua Hot. In a few words: It was a disaster. I learned from that one experience that I have got to learn the ropes on keeping this bird flying. I quickly learned that that silver box is just full of nuts, bolts and a few wires. With the aid of manuals I would be happy to tackle almost anything in this box. Good luck, Eric Perplies 96' 42' WBWL |
01-25-2009, 13:10
Not all Blue Birds are fortunate enough to use Aqua Hot products.
Some are Blue Bird built systems. Ross 2006 LXi |
01-26-2009, 00:47
01-26-2009, 05:56
Ernie, I called the Aqua Hot factory this past Monday and talked with
Tech Support. The guy I talked with said they were up and operating and were accepting parts orders. I didn't press for more info. Royal Washburn --- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg wrote: > > Does anyone have any more info on the Aqua Hot owners? > Ernie-83PT40 in Texas > > > > From: Ross > Subject: [WanderlodgeForum] Re: Aqua hot instrument panel switch > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, January 25, 2009, 7:10 PM > > > > > > > Not all Blue Birds are fortunate enough to use Aqua Hot products. > Some are Blue Bird built systems. > > Ross > 2006 LXi > |
01-26-2009, 06:22
01-26-2009, 09:54
Searching the Internet -- there doesn't seem to be any news beyond the initial reports, so far. Try searching Google on "Enander murder Colorado" ...
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Jan 26, 2009, at 4:47 AM, Ernie Ekberg wrote:
01-26-2009, 10:05
I looked, Pete, and there is no updates.
Ernie Ekberg 83PT40 Wanderlodge Weatherford, Tx http://autos.yahoo.com/group/erniesremodelingandrepair From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Monday, January 26, 2009 3:54:07 PM Subject: Re: [WanderlodgeForum] Re: Aqua hot instrument panel switch Searching the Internet -- there doesn't seem to be any news beyond the initial reports, so far. Try searching Google on "Enander murder Colorado" ... Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
01-27-2009, 06:42
Pete,
There was a time prior to Oct last year that I would have said the same thing. When my AH got intermittent, like Hish, and then failed to satrt on diesel at all, I went through the normal (by the manual) and even abnormal trouble shooting. I consider myself pretty knowledgeable on the AH. Thanks to Johnny at Bleakley in Unidilla, he fixed it in a relatively quick fashion. Turns out it *WAS* the dash switch. All measurements across it were good, it only failed after the purge cycle when switched on. The purge cycle doesn't draw as much current as the burner cycle so when the purge timed out and the controller called for ignition, the switch went high resistive and not enough voltage at igniter and faulting out. Replaced the $3.98 switch and all is and has been well. Paul 97WB43 Leaving sunny *warm* Florida tomorrow for the snow and cold at home ![]() --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > If the AquaHot fails to start, it will turn off the light and the > diesel won't run. Discuss this with your AquaHot technician. If the > switch is bad, the AquaHot won't cycle on at all. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 (For Sale) > <http://www.aeonix.biz/BBforsale.html> > El Sobrante CA > aeonix1@... > > > > > On Jan 24, 2009, at 5:12 AM, Hisham Amaral wrote: > > > My instrument panel switch goes dead (light goes out and the diesel > > does not run) after leaving it on for a couple of days. I usually rest > > set it and the diesel starts and runs for a couple of day then the > > switch goes dead again and must be reset. My question, is the switch > > bad or is there something else going on in the system? Any advise is > > welcomed. > > > > Hisham Amaral > > 97 Wanderlodge 43' > > Titusville,FL for the winter > |
01-27-2009, 07:29
Wow! ... one of those subtle things. I did have my dash switch go bad ... and the symptom was that the AquaHot (and the little green light) simply didn't come on. Before the switch completely failed, I had the green light goes out thing, too. I didn't realize that there was a low-amperage draw that was affected by resistance in the switch. The technician did a complete annual service on the A-H at the time he found and replaced the dash switch, so I assumed that the service had "solved" the quitting behavior -- it never occurred to me that it was (probably) the dash switch going bad....
One of the continuing headaches with the WL (and I suppose nearly every RV) is the very long runs of 12 vdc wires. Resistance and voltage drop becomes a significant factor. When I had my pilot's license, the small aircraft I rented almost always had 24 vdc wiring (unless they were very old) -- While 24 volt circuits cause some headaches with finding bulbs, etc. it's almost too bad that RVs didn't standardize at 24 so that some of these problems would be less... Indeed, most busses use 24 vdc instead of 12 vdc...
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Jan 27, 2009, at 10:42 AM, p_a_lazar wrote:
01-27-2009, 09:08
Hisham, there is a forum for hydronic heat on yahoo that has info if
you are not able to find your answer here. Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral" > > My instrument panel switch goes dead (light goes out and the diesel > does not run) after leaving it on for a couple of days. I usually rest > set it and the diesel starts and runs for a couple of day then the > switch goes dead again and must be reset. My question, is the switch > bad or is there something else going on in the system? Any advise is > welcomed. > > Hisham Amaral > 97 Wanderlodge 43' > Titusville,FL for the winter > |
