Rubber Hinge
06-21-2005, 12:46
Rubber Hinge
Hi All,
Going to replace a few bay door hinges. Seems like the gas shocks were too strong and ripped the rubber, Rain water gets into the bay. Any tips on how to remove and insert the new rubber?? Don't want to drive around without bay doors. Bill 88 FC |
06-21-2005, 13:58
Rubber Hinge
Bill, I just did a couple of mine. Order the hinge from BB not very
expensive. You may need help those doors are very heavy especially the double ones!! I took the chrome strip loose from both sides (the door and the coach) cleaned the channel really well and used silicone spray to allow the new rubber hinge to slide in. There is a small screw that pierces the rubber to hold it in place gotta remove it and replace it..not too hard..For me the hard part was trying to replace the chrome strip since it is threaded as well!!(you might get the screw tight against the chrome but not against the body of the coach!) This has to be done with some care because the chrome strip must be very tight against the coach or door won't align when closing. Also there was some sealer (mastic??) that needs to be replaced in order to insure a good seal along the chrom to body seam..Very IMPT..get help holding the doors they are heavy and you don't want to drop one. (body work is expensive) Good luck not too hard of a repair..did mine in a campground! and it was one repair that did NOT lead to another!! lol Scott 86FC35 "RUBY" Murrells Inlet SC "right next to heaven" --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Hi All, > > Going to replace a few bay door hinges. > Seems like the gas shocks were too strong and ripped the rubber, > Rain water gets into the bay. > Any tips on how to remove and insert the new rubber?? > Don't want to drive around without bay doors. > > Bill 88 FC |
06-21-2005, 22:26
Rubber Hinge
Scott,
Thanks for the tip on the smaller screws. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > Bill, I just did a couple of mine. Order the hinge from BB not very > expensive. You may need help those doors are very heavy especially the > double ones!! I took the chrome strip loose from both sides (the door > and the coach) cleaned the channel really well and used silicone spray > to allow the new rubber hinge to slide in. There is a small screw that > pierces the rubber to hold it in place gotta remove it and replace > it..not too hard..For me the hard part was trying to replace the chrome > strip since it is threaded as well!!(you might get the screw tight > against the chrome but not against the body of the coach!) This has to > be done with some care because the chrome strip must be very tight > against the coach or door won't align when closing. Also there was some > sealer (mastic??) that needs to be replaced in order to insure a good > seal along the chrom to body seam..Very IMPT..get help holding the > doors they are heavy and you don't want to drop one. (body work is > expensive) Good luck not too hard of a repair..did mine in a > campground! and it was one repair that did NOT lead to another!! lol > Scott > 86FC35 "RUBY" > Murrells Inlet SC "right next to heaven" > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > > > Hi All, > > > > Going to replace a few bay door hinges. > > Seems like the gas shocks were too strong and ripped the rubber, > > Rain water gets into the bay. > > Any tips on how to remove and insert the new rubber?? > > Don't want to drive around without bay doors. > > > > Bill 88 FC |
06-22-2005, 21:45
Rubber Hinge
wrote: > > Hi All, > > Going to replace a few bay door hinges. > Bill: I did them on my PT40. I dont type very well so give me a call and i will share what i learned. 703 784 6633 (W) 540 752 1154 (H) Jim |
05-05-2009, 02:34
Rubber Hinge
Is there any call for the Rubber Hinge for compartment doors on older Bluebirds
Stephen 77fc35 |
05-05-2009, 02:59
Rubber Hinge
On those rubber hinges, yes! Art Weatherly Riverside Ca '85 PT36 -- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > Is there any call for the Rubber Hinge for compartment doors on older Bluebirds > > Stephen 77fc35 > |
05-05-2009, 06:30
Rubber Hinge
We could be interested soon... '86 PT40
Greg Young Each time you judge yourself you break your heart. -Kirpal Venanji From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 5, 2009 7:34:03 AM Subject: [WanderlodgeForum] Rubber hinge Is there any call for the Rubber Hinge for compartment doors on older Bluebirds Stephen 77fc35 |
05-05-2009, 06:45
Rubber Hinge
Stephen, Put me on the list.
Harold Prescot '85 FC35 Northern Ca. --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > Is there any call for the Rubber Hinge for compartment doors on older Bluebirds > > Stephen 77fc35 > |
05-05-2009, 11:24
Rubber Hinge
I'd buy them for spares.
Bob Lawrence 84 PT36 Boussard, La > > Is there any call for the Rubber Hinge for compartment doors on older Bluebirds > > Stephen 77fc35 > |
05-05-2009, 12:49
Rubber Hinge
Are these found on a 77FC35 ?
Dorn Hetzel Hogansville, GA On Tue, May 5, 2009 at 7:24 PM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
