FYI - 3208 Lube Oil Leak Problem Solved
11-07-2010, 11:02
Few days back I was looking for info on source of lube oil leak I had on top of
our 3208. After checking on my own and replacing the lube oil hose to the air
compressor, the leak was still going. Finally decided to turn it over to a real
diesel mechanic. Turned out the lube leak was coming from a bad O ring where
the fuel injection pump shaft is inserted into the block. Mechanic had to open
up the front end to remove the fuel injection pump. Big job - beyond my
capabilities!
Regards, Eric
84FC35SBWL2
11-07-2010, 12:23
Eric
Happy you found your leak,sorry it was a big job to repair.
Some things are like that,but at least it's fixed.
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
11-07-2010, 12:56
Eric,
For future reference on my part, which diesel mechanic did you use?
Thanks,
1991 WB40 "Texas Minivan"
of our 3208. After checking on my own and replacing the lube oil hose to the
air compressor, the leak was still going. Finally decided to turn it over to a
real diesel mechanic. Turned out the lube leak was coming from a bad O ring
where the fuel injection pump shaft is inserted into the block. Mechanic had to
open up the front end to remove the fuel injection pump. Big job - beyond my
capabilities!
> Regards, Eric
> 84FC35SBWL2
11-07-2010, 14:40
Mike,
Work was done at Seguin DIesel. Clyde Schumman and his boys are top notch in my
book.
Regards, Eric
84FC35SBWL2
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote:
> Eric,
> Thanks,
> Mike Bulriss
> San Antonio, TX
capabilities!
> > Regards, Eric
> > 84FC35SBWL2
11-07-2010, 14:56
They will be servicing mine tomorrow morning!
Don Bradner
90 PT40 "Blue Thunder"
On 11/8/2010 at 2:40 AM bberic35 wrote:
>Mike,
>in my book.
>Regards, Eric
>84FC35SBWL2
>> Eric,
>> Thanks,
>> Mike Bulriss
>> San Antonio, TX
>on top of our 3208. After checking on my own and replacing the lube oil
>hose to the air compressor, the leak was still going. Finally decided to
>turn it over to a real diesel mechanic. Turned out the lube leak was
>coming from a bad O ring where the fuel injection pump shaft is inserted
>into the block. Mechanic had to open up the front end to remove the fuel
>injection pump. Big job - beyond my capabilities!
>> > Regards, Eric
>> > 84FC35SBWL2
>Yahoo! Groups Links
