Water valve
07-08-2011, 02:33
Water valve
Ralph and Ernie,
Man, you guys are GOOD! That is exactly what it was. I would have never thought
that is what it could be. There was a extra(disconnected) sporlan valve running
along the side wall of the bus that I removed the diaphram from and changed it
out. Worked good. I could see through a clear filter housing before the pump
motor that I was getting a lot of air in the system. Anyhow, I am going to order
two new diaphrams and 1 of the coil and repair both. I am not sure what that
other copper line goes to but would like to get it fixed. It has been
disconnected and capped off. Thank you both for the help. That saved me a lot of
time.
Jeff Lawrence
Panama City Beach
07-08-2011, 04:12
Water valve
Glad we could help
88 PT40
817-475-3991
--- On Fri, 7/8/11, jepetto58 wrote:
Subject: [WanderlodgeForum] Water valve
Date: Friday, July 8, 2011, 9:33 AM
Ralph and Ernie,
Man, you guys are GOOD! That is exactly what it was. I would have never thought that is what it could be. There was a extra(disconnected) sporlan valve running along the side wall of the bus that I removed the diaphram from and changed it out. Worked good. I could see through a clear filter housing before the pump motor that I was getting a lot of air in the system. Anyhow, I am going to order two new diaphrams and 1 of the coil and repair both. I am not sure what that other copper line goes to but would like to get it fixed. It has been disconnected and capped off. Thank you both for the help. That saved me a lot of time.
Jeff Lawrence
Panama City Beach
