3208 Starter Source
07-24-2011, 12:46
3208 Starter Source
Anyone know of a good source out west to pick up a new or rebuilt 3208 starter?
My service sheet says the original was a Delco 1114826. I can find that starter
with a Web search, but the source is on the east coast and says it is the
starter for some kind of 3208-powered industrial equipment.
Bob Griesel '84 FC31 WLII
07-24-2011, 13:31
3208 Starter Source
Hi Bob,
The little info I have says that part number is very common on Cat engines
I use this website a lot when I need information.
They show Caterpillar numbers to Delco numbers and a wealth of info.
I’m not certain how you source stuff,but any good truck electric should supply it,even NAPA
Fred Hulse
Morristown,Arizona
97 WLWB41
07-24-2011, 16:06
3208 Starter Source
Thanks Fred!
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Hi Bob,
> http://www.dixie-electric.com/catalog/Di...Series.pdf
supply it,even NAPA
> Fred Hulse
> Morristown,Arizona
> 97 WLWB41
07-26-2011, 15:06
3208 Starter Source
Hi Bob,
I'm not sure where you are located, but I had mine rebuilt last year here in
Dallas. I found the starter place that I've used for other starters could handle
the big Cat starter.
Anyway, I can look up the contact information if something here helps you.
Otherwise you might find out like I did that your local starter rebuilder can
help you out.
alan
87FC35 in Dallas
starter? My service sheet says the original was a Delco 1114826. I can find
that starter with a Web search, but the source is on the east coast and says it
is the starter for some kind of 3208-powered industrial equipment.
07-26-2011, 17:22
3208 Starter Source
Thanks Alan. NAPA fixed me up with a reman. Its in and working fine.
Bob Griesel '84 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "xz3kg7" wrote:
> Hi Bob,
help you out.
> alan
> 87FC35 in Dallas
