"TankEyes " on 450 LXi
08-06-2013, 09:02
Good Morning,
Anyone know of the manufacturer that supplied "TankEyes" which was used in the 450s' as the tank level indicators.
Thank you,
Ross
08-06-2013, 09:59
RE: "TankEyes " on 450 LXi
Hi Ross,
I'm sure one of the M450 guys will chime in soon. In the meantime I searched for "tank monitor" on ebay and an almost endless list of suppliers came up. Yours might be one of them. Do you have a pic of your control panel? There's some pretty cool technology out there.
08-06-2013, 10:58
Well I gave it a good solid 5 minute college try on Ebay, Google, and everything else and I can't find a panel that looks like that. (just trying to find something that has the same number of leds, location, and pattern)... nothing! Sad
08-06-2013, 13:21
The one in the galley is just a repeater from the one in the water bay. Switching to a different brand would be PIA as there are 9 "Levels" - Shame to lose that accuracy.
Ross
08-06-2013, 17:50
(08-06-2013 13:21)dentmac Wrote:  The one in the galley is just a repeater from the one in the water bay. Switching to a different brand would be PIA as there are 9 "Levels" - Shame to lose that accuracy.
Ross
Has anyone found out what the name is of the company of manufacture?
Dan Sunderland
2005 450LXi
San Marcos, CA
08-06-2013, 22:05
has anyone removed that item and see if there is a manufacturers mark on the reverse side?
08-06-2013, 22:37
(08-06-2013 22:05)ernie ekberg Wrote:  has anyone removed that item and see if there is a manufacturers mark on the reverse side?
Yes already done. Apparently the mfg name is not the same as the device. They have disappeared.
Dan Sunderland
2005 450LXi
San Marcos, CA
08-06-2013, 22:43 (This post was last modified: 08-06-2013 22:45 by dentmac.)
Removing both...No print or numbers.Nada. On the tank with the probs, there is a powered 'optitron" level switch by Dwyer Industries ,indiana. I took pics when i was at the coach.The site shows nothing like the Tankeyes.
08-07-2013, 17:33
(08-06-2013 11:45)Bird Owner Wrote:  Alan Barbee might know? Maybe Parliament's parts department/ Dan Hartley? Obviously made for Blue Bird with their logo. Are the same ones used on the M380?
No, the M380 uses a 4-level indicator identical to the one in my (your) '90.
Interesting that tankEyes shows "tm" because a trademark search doesn't turn it up, just Tankeye, belonging to the GOAD company and not related to this type of monitor.
Don Bradner
2004 M380 Double Slide
1990 WB "Blue Thunder" Sold
My Location
