  • 2 Vote(s) - 3.5 Average
LXi Chassis Part Numbers
05-02-2013, 12:07 (This post was last modified: 08-31-2015 18:13 by travelite.)
Folks, if you have any LXi chassis part numbers to share put them here. Feel free to start a thread for other Wanderlodge models. At some point I'll collect them and put them in their own page:
1) Entryway air step norgren valve:
The original equipment Norgren 5/2 solenoid piloted valve is superseded by Norgren part number V61R511AA312JB available at Carolina Fluid Components, Charlotte, NC 704-588-6101.
2) Drive Axle MGM Brake Chamber
I put new brake chambers on my drive axle. The original part, MGM 4131213, is no longer available and has been superseded by MGM Magnum Performance Plus part number:
MGM: MJS3028ET051, The new part is a long stroke (3") model with 300# of additional parking brake force. Both new and old are piston style chambers.
3) Chelsea PTO Spline Grease
The spline grease Chelsea specifies is part number 379831 available at Fleetpride, Florig, and National Fleet. An even better choice is Klueber grease, Microlube GL 261, available here at Advanced Machine and Lubrications Services.
4) Hayden Hydraulic Fan Cooler
Drawings can be found in our trusty Document Library at Document Library->Models->LXi.
Hayden part numbers:
027026: cooler core
017048: fan plate
025576: fan assy
016945: cabinet
All available at most hydraulics supply vendors. Here in Charlotte NC we have:
a) Berendsen: 704-588-7723; $540.00 for 027026; 3 to 4 weeks,
b) Livingston & Haven: 704-525-7910; $340 for 027026; 3 to 4 weeks,
c) Sunsource: (800) 228-4831 (Pays to shop around).
5) Hydraulic Fan Pump and PTO
Please see this thread: Chassis Forum: LXi-and-WideBody-PTO-Pump-Splines.
6) Stainless Steel Exhaust System and Muffler
Please see this thread: Chassis Forum: Stainless-Steel-Exhaust-95-WB-thru-LXi.
7) Duralite Charge Air Cooler
Please see this thread: Chassis Forum: LXi-Duralite-Charge-Air-Cooler
8) LXi Slide Seal Part Numbers (Brady Seal)
Please see this thread: LX-and-LXi-Slide-Seal-Part-Numbers-Brady-Seal.
9) LXi Ridewell Suspension Air-Springs
Please see this thread: LXi-Ridewell-Susp-and-Air-Spring-Part-Numbers.
10) Koni Shocks
Steer (adjustable) 90-2497SP1, adjust one turn from full soft,
Drive (FSD, non-adjustable) 9005-1025, and
Tag (FSD, non-adjustable) 8805-1010.
11) Brake Shoes and Drums
Please see this thread: Steer, Drive, Tag Axle Shoes and Drums.
05-02-2013, 18:43
RE: LXi Chassis Part Numbers
(05-02-2013 12:07)davidmbrady Wrote:  Folks, if you have any LXi chassis part numbers to share put them here. Feel free to start a thread for other Wanderlodge models. At some point I'll collect them and put them in their own page:
Drawings can be found in our trusty Document Library at Document Library/Models/LXi.
027026: cooler core
017048: fan plate
025576: fan assy
016945: cabinet
LXI engine door latching gas spring:
Orr & Orr, Inc.
Stock no. H9516-100 (100 lb.)
2003 LXI dbl. slide
George & Norma Fox
Mexico in Winter
Alaska in Summer
http://www.doszorros.com
08-29-2013, 10:07
Thank you Chuck Millsap for this extensive list of LXi belt and filter part numbers. Tongue
(08-27-2013 17:49)cmillsap Wrote:  Here's a list of belt and filter part #s that I have compiled from several sources for an LXI.
It may be useful to others when trying to find a replacement for their bus.
LXI Filters & Belts Part #s
LXi Air Filter Part #s
ECOLITE 546895
WIX ECO-SM 46895
Baldwin # PA2723
Donaldson # P537449
Fleetgard # AH8505
Hastings # AF2269
Farr # 62891-3
LXi Oil & Fuel Filters Part #s
Detroit Diesel S60 500 HP- ECU DD111
Oil capacity = 39 Quarts Multi-Grade 15-40
Oil Filter #1 = FG: LF3620 or equivalent
Oil Filter #2 = FG: LF3620 or equivalent
Fuel Filter #3 = FG: FF5206 or equivalent
Fuel Filter #4 = FG: FS20203 or equivalent
Coolant Filter = Specific for Coolant Type =Use DDF60 with Power Cool Plus Coolant
LXi -DD S60 Serpentine Belt Part #s
Outside Circumference (in) : 72.632"
Top Width (in) : 1.647"
Part Number: NBH 25120720
Product Line: NAPA Belts & Hoses
DAYCO 5120720
Metric 12PK1830
Gates K120720
Napa 25-120720
Napa 25120720
Goodyear 4120720
Bando 12PK1828
VB Supply 720K12 K
DD 23521337
LXi- DDS60 A/C Compressor Drive Belts
Gates GT17672 Matched Pair (Discontinued)
Gates 9710 Single Belt (2 Required)
LXi Hydraulic Oil Reservoir Filter Part #s
• BALDWIN PT8487
• DONALDSON P55-0698
• FRAM C7058
• NAPA 7196
• WIX 57196
Powertech 15KW Filters & Belt Part #s
Fuel filter;
• BB #3970860
• NAPA #3390
• Powertech #08FF081
• Kubota #70000-43081
Oil filter;
• BB #3970878
• NAPA #1515
• Baldwin #B5
• Powertech #01FO091
• WIX #51068
• Kubota #70000-32091
Air filter;
• BB #3838158
• Donaldson #ECB05-5001
• Powertech #04FA080
• Kubota #70000-11080
Fan Belt;
• With Idler Pulley;
• Powertech #03BF9447 $22.97
• Kubota #15469-97010 or #15469-73010 (not specified idler or[/u] alternator)
• NAPA #XL 25-9447 Dimensions; 31/64"X44-7/8" (12.5/13mm X 1140mm)
• With Alternator;
• Powertech #03BF0203
LXi Allison 4060 Transmission Filter Part #
Allison Kit # 29548988
09-06-2013, 23:42
(08-29-2013 10:07)davidbrady Wrote:  Thank you Chuck Millsap for this extensive list of LXi belt and filter part numbers. Tongue
ECOLITE 546895
WIX ECO-SM 46895
Baldwin # PA2723
Donaldson # P537449
Fleetgard # AH8505
Hastings # AF2269
Farr # 62891-3
Parker/Racor # 099842007 18”long X 13.5” diameter
DAYCO 5120720
Metric 12PK1830
Gates K120720
Napa 25-120720
Napa 25120720
Goodyear 4120720
Bando 12PK1828
VB Supply 720K12 K
DD 23521337
• BALDWIN PT8487
• FRAM C7058
• NAPA 7196
• WIX 57196
Fuel filter;
• BB #3970860
• NAPA #3390
Oil filter;
• BB #3970878
• NAPA #1515
• Baldwin #B5
• WIX #51068
Air filter;
• BB #3838158
Fan Belt;
• With Alternator;
11-08-2013, 21:49
(05-02-2013 12:07)davidbrady Wrote:  Folks, if you have any LXi chassis part numbers to share put them here. Feel free to start a thread for other Wanderlodge models. At some point I'll collect them and put them in their own page:
027026: cooler core
017048: fan plate
025576: fan assy
016945: cabinet
10) Koni Shocks
Any information on the correct air springs for the bay doors and the engine cover door? I seem to have a mish-mash on mine and would like a little more force from the left engine cover. Mine may have some wrong parts.
Ron & Dorinda Rueckwald
2000 LXi, Single Slide
Summer in St. Joseph, MI
Winter in St. Petersburg, FL
11-09-2013, 12:34 (This post was last modified: 11-09-2013 13:46 by davidbrady.)
Hi Ron,
Engine deck lid locking gas spring: FAL22, and the ball studs.
Engine compartment side doors (radiator/CAC and battery): Stabilus 280N, 0703IM, 295400
Under Slide:
Bay door 1 and 2: FAN22E, 80 lb
Bay door 3: AVM SE1500M, 80 lb
Pantograph doors: (from the BB parts catog): 200 lb, Length: 11.81" to 19.69", small end.
11-10-2013, 00:47
(11-09-2013 12:34)davidbrady Wrote:  Hi Ron,
Under Slide:
Many thanks, David. It is one of the many "next" projects. That helps.
[+] 1 user Likes rrueckwald's post
08-18-2016, 15:58
are the king pin and tie rod ends here somewhere and I just missed them ?
