  • 1 Vote(s) - 2 Average
Is this a problem?
05-07-2014, 14:52
Is this a problem?
Out getting dirty today and noticed a treaded hole with no plug. Looks like its been out for a while?
8V92 just in front of oil drain
Gregg & Jane Gesse
1994 WLWB 40 Mid-Door
05-07-2014, 19:28
RE: Is this a problem?
that's a new one on me
05-07-2014, 20:33
Is that on the bell housing? It's hard to tell in the pic but if so, that's the drain in case the input seal or crank seal leaks. It's threaded so you can route the drain somewhere else if you want.
TOM
05-07-2014, 22:56
(05-07-2014 20:33)oldmansax Wrote:  Is that on the bell housing? It's hard to tell in the pic but if so, that's the drain in case the input seal or crank seal leaks. It's threaded so you can route the drain somewhere else if you want.
TOM
Yes, I believe that is called the bell housing. So it's not a problem. Thank for help!
Gregg
Gregg & Jane Gesse
