PMMI Musical Horn manual
09-12-2014, 18:16
Does anyone have a manual/schematic for the PMMI Musical Horn in a 1990 BB? Trying to trace down the wiring.
Thank you. |
09-12-2014, 20:04
RE: PMMI Musical Horn manual
I believe the box and blue colored ribbon wiring is up in front of copilot lower dash area. Hard to see.
09-12-2014, 22:47
Thanks, Ernie. That is where I found it. You are right about the hard to get to!
THANKS. |
09-12-2014, 23:18
What is the problem with yours?
09-13-2014, 07:44
It was not working. Leroy said he was sure it was the computer brain, as he had checked everything else. Since I was not getting any display on the dash, I wanted to check the leads.
I bought the new old stock brain on line, installed it, and Leroy was right, it was the brain. It now works. Now, I need to go to a campground with a lot of people, and go thru the songs one by one to identify them! LOL The brain in my 90 had a little tag inside the box that said "BB 2-90". The new one has a tag that says "PM 5-94". So, it is a newer box. The old box also had a longer connection for the ribbon cable, with a "plug" in the excess connections. The new one the cable fits just right, without the plug. The new box might be one for the newer "Ultimate" horn? But, it works! PMMI will reprogram the brain with different songs, for a price of course. |
09-13-2014, 13:00
(This post was last modified: 09-13-2014 13:07 by GregOConnor.)
here is a list to start with
http://www.wanderlodgegurus.com/database...20List.pdf my Musical horn has an issue where it wont turn on and if you leave it switched on, it will blink on then off. seems like a broken wire some place. I have a new exterior sound system with 8 of 800 watt powered speakers 2 1000 watt powered and 3 subs. even with all that people still ask to hear the musical horn. We tailgate at the Rose bowl and get good use out of the college fight songs here is a scan of a list posted on the site WanderlodgeOwnersGroup.com by an approved poster - Jim D http://www.wanderlodgeownersgroup.com/fo...1371558040 Gregory O'Connor 2001 LXi43ss Romoland California 92585 951-830-5997 Rainbowrv.com |
03-08-2024, 21:47
I know this was 20 years ago. Anyone find a schematic? I got two brain boxes on my bench now. All I can do is test and replace components. I have an LX and tested the new style box. That is the problem. I like to buy an old and new style controller and test them. The old style box I feel is good. I can't find anything wrong component wise. Good news is I sourced all the components.
