Inverter main fuse
11-07-2014, 01:24
(This post was last modified: 11-07-2014 01:28 by Arcticdude.)
Inverter main fuse
I recently popped an inverter fuse. Turns out mine are a Shawmut Ampsurge A13X250 250a fuse. This crosses to a Bussmann 4XC83 from Grainger. $68 plus tax each. I haven't yet mounted the new one, but it appears to be very close in all dimensions and should be an easy replacement.
11-07-2014, 01:35
RE: Inverter main fuse
John,
What loads are you running that require over 3000W of power? david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
11-07-2014, 11:01
(This post was last modified: 11-07-2014 11:05 by rrueckwald.)
Again, while you are at it, install a rubber cover over the back of thee hot jump terminal. It is inviting a massive spark if you happen to ground it with a wrench. Ron & Dorinda Rueckwald 2000 LXi, Single Slide Summer in St. Joseph, MI Winter in St. Petersburg, FL |
11-09-2014, 15:45
(This post was last modified: 11-09-2014 15:47 by Arcticdude.)
(11-07-2014 01:35)davidbrady Wrote: John, Duh!! The margarita machine!! What else!! ![]() Good points, Ron. I'll have to study mine a little to see how to do that properly. John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
