Jack Issue
02-11-2016, 13:14
Jack Issue
Hello WaGu,
When I retract the jacks , the motor runs and they attempt to Extend . I believe this a stuck solenoid , if so how do I determine which one , or am I wrong, and it is some other issue ? Thank you all in advance al perna 2000 LXI ormond beach fla |
02-14-2016, 12:41
RE: Jack Issue
There is a shuttle valve in the main manifold. It keeps the jacks from letting flow back thru the circuits to keep the coach level. I got caught sometime back with jacks the would not retract. I turned everything off, i tapped the main body between the frame rails. Restarted, everything worked fine. The shuttle valve was replaced that week. No problems since.
Charlie Vaughn 1999 LXi |
02-15-2016, 13:52
(This post was last modified: 02-15-2016 13:58 by al perna.)
RE: Jack Issue
thank you Charlie, how do I identify the shuttle valve ?
Guys , any idea which one I need ? VALVE - HYDRAULIC - MANUAL - MECHANICAL "SHUTTLE VALVES" PARTS MANUAL DIAGRAMS SHUTTLE VALVE RAP7964 ORDER RELATED PART: O-RING KIT R7430 ORDER SHUTTLE VALVE - TALL RAP6064 ORDER RELATED PART: O-RING KIT R7430 ORDER SHUTTLE VALVE RAP3623 ORDER RELATED PART: O-RING KIT R7430 ORDER al perna 2000 LXI ormond beach fla |
02-17-2016, 11:38
(This post was last modified: 02-17-2016 11:40 by cvaughn.)
RE: Jack Issue
The shuttle valve is is under a bolt head maybe 3/4" or 1". It is located near center of the manifold body. I would not remove it under pressure.I do not know if it is tall or not.
02-17-2016, 12:54
RE: Jack Issue
thank you Charlie , I was able to look up the part on HWH web site and plan to order it once they help me determine which one it is .
02-22-2016, 14:28
RE: Jack Issue
here is the link to the shuttle valve I ordered today . HWH not only answered the phone, but had the part in stock for a delivery today .
http://www.hwh.com/mi158813.pdf thank you for the info here , wagu is a great source for saving $$$$ and learning al perna 2000 LXI ormond beach fla |
03-04-2016, 03:22
RE: Jack Issue
