Water Heater
08-22-2005, 04:46
Water Heater
Trying to find my waterheater....1988 40' wbwl..when plugged in to
electric my waterheater is not working help Jim |
08-22-2005, 06:19
Water Heater
Jim:
Your water heater is in the drivers side rear corner under the closet. There should be a hatch on the flooring of that closet for minimum viewing. There is a circuit breaker in the main electrical panel for the water heater and there should be a red switch located either in the right rear closet or the curb side rear closet that supplies the 110vac through a relay to the heating element on the water heater.. The relay is a 12 vdc coil and the ground is attached to a sensor in line on the output side of the shore water or fresh water tank, in an elbow (brass). This wire does corrode from time to time and detaches. This is the safety preventing 110 vac power to the heating element if no water is sensed in the piping. That relay is usually housed in a 4x4 electrical box with a raised bezel for clearance. So be sure the c/b is on in the electrical panel, then the red switch is in the on position. Then if no heating, you will need to put the leads of an VOM meter on the connections to the heating element to see if you have 110vac there. If not then you need to check the safety relay. If 110vac is present at the heating element then, of course, the element is bad and needs to be replaced. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:46 PM 8/22/2005 +0000, you wrote: >Trying to find my waterheater....1988 40' wbwl..when plugged in to >electric my waterheater is not working help > >Jim > > > > > |
08-22-2005, 09:59
Water Heater
Ralph -
Do you know how to access it? When Bird is running it has hot water ..heated from engine..but when on shore power no hot water...Maybe there is a switch that I have not located yet or I have a problem with the w/h any thoughts??? -- In WanderlodgeForum@yahoogroups.com, "jqrjr" > Trying to find my waterheater....1988 40' wbwl..when plugged in to > electric my waterheater is not working help > > Jim |
08-22-2005, 10:05
Water Heater
there are two switches, the one in the electric panel and one under the kitchen
sink jqrjr Do you know how to access it? When Bird is running it has hot water ..heated from engine..but when on shore power no hot water...Maybe there is a switch that I have not located yet or I have a problem with the w/h any thoughts??? -- In WanderlodgeForum@yahoogroups.com, "jqrjr" > Trying to find my waterheater....1988 40' wbwl..when plugged in to > electric my waterheater is not working help > > Jim --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
08-22-2005, 10:18
Water Heater
Jim:
Yes there is a switch, actually 2. One is in the main breaker box and should be marked water heater. The other should be in the curb side rear closet behind the mirror door and should have a tag saying "water heater." Some times there are 3 switches in a row in that area and usually the water heater is the center switch, but not always. If the water heater switch is not in the curb side rear closet then it's alternative site is in the drivers side rear closet area behind the mirrored door. Both of these places are in the rear of the Coach and on each side of the bed. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 09:59 PM 8/22/2005 +0000, you wrote: >Ralph - >Do you know how to access it? > >When Bird is running it has hot water ..heated from engine..but when on >shore power no hot water...Maybe there is a switch that I have not >located yet or I have a problem with the w/h any thoughts??? > >-- In WanderlodgeForum@yahoogroups.com, "jqrjr" > > Trying to find my waterheater....1988 40' wbwl..when plugged in to > > electric my waterheater is not working help > > > > Jim > > |
08-22-2005, 10:21
Water Heater
An after thought, a third alternative switch site is located on one side of
the bed or the other in the base board area. Ralph At 05:18 PM 8/22/2005 -0500, you wrote: >Jim: > >Yes there is a switch, actually 2. One is in the main breaker box and >should be marked water heater. The other should be in the curb side rear >closet behind the mirror door and should have a tag saying "water heater." >Some times there are 3 switches in a row in that area and usually the water >heater is the center switch, but not always. If the water heater switch is >not in the curb side rear closet then it's alternative site is in the >drivers side rear closet area behind the mirrored door. Both of these >places are in the rear of the Coach and on each side of the bed. > >Safe travels, > >Ralph and Charolette Fullenwider >Ralph's RV Solutions, Duncan, Oklahoma >http://home.swbell.net/rlf47/index.htm > >At 09:59 PM 8/22/2005 +0000, you wrote: > >Ralph - > >Do you know how to access it? > > > >When Bird is running it has hot water ..heated from engine..but when on > >shore power no hot water...Maybe there is a switch that I have not > >located yet or I have a problem with the w/h any thoughts??? > > > >-- In WanderlodgeForum@yahoogroups.com, "jqrjr" > > > Trying to find my waterheater....1988 40' wbwl..when plugged in to > > > electric my waterheater is not working help > > > > > > Jim > > > > |
08-22-2005, 11:10
Water Heater
Hi Bo:
The one under the kitchen sink is usually for the instant hot located on the sink. I have not seen the water heater switch mounted there, but it is certainly possible, of course. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:05 PM 8/22/2005 -0700, you wrote: >there are two switches, the one in the electric panel and one under the >kitchen sink > |
08-22-2005, 11:45
Water Heater
Ralph,
Under the kitchen sink is where it's at in my 91, along side the Instant Hot switch. Still has one of those red light up switches to let you know that it is on. I too had expected it to be where it is in the 83, back in a closet. Mike Bulriss 83 PT40 "Stagecoach" - FOR SALE 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > Hi Bo: > > The one under the kitchen sink is usually for the instant hot located on > the sink. I have not seen the water heater switch mounted there, but it is > certainly possible, of course. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 03:05 PM 8/22/2005 -0700, you wrote: > >there are two switches, the one in the electric panel and one under the > >kitchen sink > > |
08-22-2005, 13:23
Water Heater
Mike, Bo:
That is one of the many things about Bird's, always something new to learn. Thanks to both of you for another location alternative. I have recently been in an '88 and an '89 and both were in the rear closet. Funny how things can be on the print schedules and wired so differently from Coach to Coach. But then, they are hand made Coaches. Ralph At 11:45 PM 8/22/2005 +0000, you wrote: >Ralph, > >Under the kitchen sink is where it's at in my 91, along side the >Instant Hot switch. Still has one of those red light up switches to >let you know that it is on. I too had expected it to be where it is >in the 83, back in a closet. > >Mike Bulriss >83 PT40 "Stagecoach" - FOR SALE >91 PT40 "Texas Minivan" >San Antonio, TX |
08-22-2005, 13:55
Water Heater
--- In WanderlodgeForum@yahoogroups.com, "jqrjr"
> Trying to find my waterheater....1988 40' wbwl..when plugged in to > electric my waterheater is not working help > > Jim Jim, I am sure you probably have found the switch. I have a 85 pt40 and there is a heater switch located in the right rear closet behind the bed next to the engine heater and battery heater, also there is a breaker panel with a heater circuit. Mine are lighted switches in the closet. John Mann 1985 pt40 Granbury Tx |
