Seat on curb side 79 FC
11-10-2005, 20:03
Hi All When I had new carpet installed in my 79 FC 33' side bath I left
the side chair behind the copilots seat out. When I sold it the new owner wants to put it back in. My question is does any one have the exact location of it as he can't find the holes under the carpet. A dimension from the front kick by the copilots seat to the center of the base & does it fit tight to the wheel well. Thanks Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
11-10-2005, 20:14
Don, is this a swivel chair? He might look from underneath the coach and
maybe able to find the holes? ERnie-83pt40 in Texas [Non-text portions of this message have been removed] |
11-10-2005, 20:26
Ernie It is a swivel chair & if I were there I think I could find the
that way to but he said there was the foam insulation & he couldn't find them I though if he had a close dimension he might be able to find them with a sharp awl. Don 89 SP 36' Butler, PA Don is that a swivel chair? He might look from underneath the coach and maybe able to find the holes? ERnie-83pt40 in Texas [Non-text portions of this message have been removed] |
11-11-2005, 04:39
Don, (et.al.)
You mean the swivel chairs are supposed to be bolted down? I wondered about that before we removed the two in our 'Bird and replaced then with an oak roll-top desk and file cabinet. I've seen many SOB's with "loose" chairs, even another 'Bird.... Our 'Bird had two barrel chairs aft of the curbside wheelwell - the seatbelts were secured firmly but the chairs themselves weren't. Jim & Pam Owens 77 FC33SB (Gas) Lake of the Ozarks, MO --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > Hi All When I had new carpet installed in my 79 FC 33' side bath I left > the side chair behind the copilots seat out. When I sold it the new owner > wants to put it back in. My question is does any one have the exact location of > it as he can't find the holes under the carpet. A dimension from the front > kick by the copilots seat to the center of the base & does it fit tight to the > wheel well. Thanks > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > |
11-11-2005, 06:40
We have one of those barrel chairs. Its' so heavy it doesn't move. Ernie in
Texas -----Original Message----- From: Jim Owens To: WanderlodgeForum@yahoogroups.com Sent: Fri, 11 Nov 2005 16:39:42 -0000 Subject: [WanderlodgeForum] Re: Seat on curb side 79 FC Don, (et.al.) You mean the swivel chairs are supposed to be bolted down? I wondered about that before we removed the two in our 'Bird and replaced then with an oak roll-top desk and file cabinet. I've seen many SOB's with "loose" chairs, even another 'Bird.... Our 'Bird had two barrel chairs aft of the curbside wheelwell - the seatbelts were secured firmly but the chairs themselves weren't. Jim & Pam Owens 77 FC33SB (Gas) Lake of the Ozarks, MO --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > Hi All When I had new carpet installed in my 79 FC 33' side bath I left > the side chair behind the copilots seat out. When I sold it the new owner > wants to put it back in. My question is does any one have the exact location of > it as he can't find the holes under the carpet. A dimension from the front > kick by the copilots seat to the center of the base & does it fit tight to the > wheel well. Thanks > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > Yahoo! Groups Links [Non-text portions of this message have been removed] |
11-11-2005, 06:50
Hi Jim Both my seat are bolted down. With the base that is on them they
would not sit without being bolted through the floor. Don 89 Sp 36' Butler, PA You mean the swivel chairs are supposed to be bolted down? I wondered about that before we removed the two in our 'Bird and replaced then with an oak roll-top desk and file cabinet. I've seen many SOB's with "loose" chairs, even another 'Bird.... Our 'Bird had two barrel chairs aft of the curbside wheelwell - the seatbelts were secured firmly but the chairs themselves weren't. Jim & Pam Owens 77 FC33SB (Gas) Lake of the Ozarks, MO [Non-text portions of this message have been removed] |
