Starting Batteries
12-02-2005, 03:17
Post: #21
Starting Batteries
Hi All,
I haven't been able to be on the site much lately, but am also at the
point of replacing batteries. I have six Continentals that are about
three years old (group 27). They seem to have needed and excessive
amount of water and I have used distilled. My charger is a Xamtrex. The
setup is horrible. There are four on the bottom and a tray with the top
two a couple of inches above the four. To get to the lower batteries
the top tray has to be removed and all the bateries just about have to
come out to get to them, plus the terminals and battery tops are
usually filthy (lots of acid buildup on negative posts). It takes me a
good half day to take them all out and clean and water.
Should I got to Trojans, something maintanence free or what? Also, my
battery up front, I thought was for the generator, is not. It is just
an auxilary battery. You can completely disconnect it and start the
generator. However, you can tell it kicks in when you push the aux
switch. So, I guess I have several concerns. Thanks for any help.
Dave in Tulsa (84PT40)
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote:
> Thanks Hank, This is my first encounter with Continental batteries.
The owner
> of the battery shop says he can't keep enough of them on hand. Ernie-
83pt40
> in Texas
12-02-2005, 04:31
Post: #22
Starting Batteries
Steve,
If you used filtered well water would that be ok, or as safe as distilled water.
Thanks,
Howard Truitt
Camilla, Ga.
86 8V92 PT40
Sent: Thursday, December 01, 2005 11:23 AM
Subject: [WanderlodgeForum] Re: Starting Batteries
When adding water remember to use disstilled water, not tap. Will
help them last. Speaking from the school of hard knocks, with a
masters degree.
90wl40wb
Ponchatoula, La. presently in Boerne waiting for the rally to
start!!!
YAHOO! GROUPS LINKS
12-02-2005, 04:47
Post: #23
Starting Batteries
The Trojan maintenance guide says "Use only distilled or deionized water".
Dick Hayden '87PT38 - Lk Stevens, WA
Sent: Friday, December 02, 2005 8:31 AM
Subject: Re: [WanderlodgeForum] Re: Starting Batteries
Steve,
water.
Thanks,
Howard Truitt
Camilla, Ga.
86 8V92 PT40
To:
masters degree.
90wl40wb
start!!!
YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
"WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
WanderlodgeForum-unsubscribe@yahoogroups.com @yahoogroups.com?subject=Unsubscribe>
Service<http://docs.yahoo.com/info/terms/>.
12-02-2005, 15:34
Post: #24
Starting Batteries
At times during my years with Bell South I maintained strings of wet
cell batterys. The training we received advised not to use tap water
because the stuff that was in the water would settle in the bottom of
the case and would evenually cause it to short out. But hey these
cells were designed to last 50 years.
Johnny M Slone
Pikeville, Ky (Stompin ground of the Hatfield and McCoys)
84 PT35
-- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
water".
> From: Howard O. Truitt
> To:
WanderlodgeForum@yahoogroups.com om>
> Steve,
distilled water.
> Thanks,
> Howard Truitt
> Camilla, Ga.
> 86 8V92 PT40
> From: patticake592000
> To:
Will
> masters degree.
> Steve Gureasko
> 90wl40wb
> start!!!
> YAHOO! GROUPS LINKS
of Service.
> YAHOO! GROUPS LINKS
> a.. Visit your
group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum
>" on the web.
> WanderlodgeForum-
unsubscribe@yahoogroups.com unsubscribe@yahoogroups.com?subject=Unsubscribe>
of Service<http://docs.yahoo.com/info/terms/>.
12-03-2005, 14:04
Post: #25
Starting Batteries
> Should I go to Trojans... my battery up front, I thought was for the
generator, is not. It is just an auxilary battery. You can completely
disconnect it and start the generator. Dave in Tulsa (84PT40)
I recently installed 6 Trojan T105's in the rear of my '86 PT38. There
is plenty of room. Mine are all on one level though.
My genset can also be started with the front battery disconnected. I
added a battery disconnect near the main battery bank, so when dry
camping I can disconnect the front battery to prevent it from running
down. I also flip it when I disconnect the main battery bank when I
put the rig in storage, to prevent it from running down.
I can send you some pictures for ideas.....
Steve Harrie
'86 PT38
St. George, UT
12-10-2005, 09:01
Post: #26
Starting Batteries
Steve,
Thanks for the info. Sorry to be so long in getting back. If it is not too much
trouble some pictures might help. I don't think therte is any way I could get
six
Trogan batteries in.
--- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" <
> Steve Harrie
> '86 PT38
> St. George, UT
12-10-2005, 10:08
Post: #27
Starting Batteries
>If it is not too much trouble some pictures might help. Dave in Tulsa
(84PT40)
No trouble Dave. Yahoo cut your email off at the "@". Email me at
nicodemus815 at cs dot com and I'll send you some picts.
Steve Harrie
St. George
'86 PT38
12-11-2005, 14:59
Post: #28
Starting Batteries
Stephen,
I could not get your e-mail to send. Please give me the info again or different
e-mail.
> (84PT40)
> Steve Harrie
> St. George
> '86 PT38
12-12-2005, 00:09
Post: #29
Starting Batteries
or different e-mail.
nicodemus815@...
Steve
