TV Antenna
11-28-2005, 20:28
TV Antenna
Bill- send us a picture and we'll put it on home page. Ernie 83pt40 in Texas
[Non-text portions of this message have been removed] |
11-29-2005, 16:48
TV Antenna
I read some time ago that some one had the name of the company that was
make the antenna again. I looked in the files but I could not find it. Would appreciate it if someone could supply me with that name and phone number. Thanks again Joe 1984 1/2 PT40 |
11-30-2005, 12:04
TV Antenna
Joe,
I talked to BB Parts today and they are now using a new round, 360 degree coverage, antenna with an amp that tunes to the best signal electronically (that means the micro-lizards inside the dome rotate the coat hanger for you!), My original one came apart and the top (and several important internal components) departed the pattern! I may put stall generator strips on top of the new one. The new one is about $80.00 and does not use the rotor control we have. I should have it by next week and will tell you how it works. Bob & Judy Johannesen 91WLWB40 "Seldom Blue" Argyle, Texas mjzakowski <mjzakowski@...> wrote: I read some time ago that some one had the name of the company that was make the antenna again. I looked in the files but I could not find it. Would appreciate it if someone could supply me with that name and phone number. Thanks again Joe 1984 1/2 PT40 --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs. Try it free. [Non-text portions of this message have been removed] |
12-14-2005, 12:18
TV Antenna
Bob,
Did you get your antenna yet? If you did what kind is it? Does this replace the round one they have on the early model? send picture if possible. Joe 1984 1/2 pt 40 |
12-14-2005, 18:05
TV Antenna
Hi Joe,
Yes, the antenna came from BB several days ago. It is officially described as a "5MS921 Omni State, amplified (boosts up to 20 dB in both VHF & UHF) omni-directional (HDTV Ready)" round antenna that is 21" in Diameter (the original was 22" in Dia.) and 1 inch high at the edge. It was made by AntennaCraft, P.O. Box 1005, Burlington, Ia. 52601. It also mounts with four bolts or screws. BB sells it for $86.83 and refers to it as part #0081595 and it looks just like the original. I bought a cheaper one from Camping World that never really performed up to par. I will check the coax and amp. power leads before I finish the install. If I measure the resistance and compare it to a separate external cable, I should be able to rule out the original coax cable as a source of the weak signal. I have to repair the aluminum base brackets for the lift arms and make a few improvements, so I'll probably fire up the TIG welder after the holidays. We'll be in the Bird from 22 Dec - 2 Jan going from Texas to Iowa and back to South Padre and Kendalia for New Years (weather permitting). I have been just finished fixing my Primus heating system in preparation for the Iowa weather. Replaced one control panel and one pump relay and they work great!! So the antenna was pushed down the list. Was that more than you wanted to know? Bob & Judy Johannesen 91WLWB40 "Seldom Blue" Argyle, Texas Margaret M Zakowski <mjzakowski@...> wrote: Bob, Did you get your antenna yet? If you did what kind is it? Does this replace the round one they have on the early model? send picture if possible. Joe 1984 1/2 pt 40 SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Shopping Find Great Deals on Holiday Gifts at Yahoo! Shopping [Non-text portions of this message have been removed] |
02-09-2006, 13:26
TV Antenna
Hi,
When I saw the post about the replacement TV antennas, I ignored it because I had no use for it. Have someone parked next to me in an 67 BB at the Indio Elks that needs one and I can't find the source in the files or database. Would the person who has those available please contact me? Thanks, George Lowry '06 Alpine Apex formerly '95 WBDA 4203 Spearfish, SD Now in Indio, CA |
02-09-2006, 13:41
TV Antenna
George,
Stephen Birtles info @ capeinnovation . com is the guy. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. George Lowry wrote: > Hi, > > When I saw the post about the replacement TV antennas, I ignored it > because I had no use for it. Have someone parked next to me in an 67 BB > at the Indio Elks that needs one and I can't find the source in the > files or database. Would the person who has those available please > contact me? > > Thanks, > > George Lowry > '06 Alpine Apex formerly '95 WBDA 4203 > Spearfish, SD Now in Indio, CA > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
02-09-2006, 14:45
TV Antenna
Try http://www.starkelectronic.com Item # 5MS9000
Harry Saddock 83FC35 South Windsor, CT --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > > Hi, > > When I saw the post about the replacement TV antennas, I ignored it > because I had no use for it. Have someone parked next to me in an 67 BB > at the Indio Elks that needs one and I can't find the source in the > files or database. Would the person who has those available please > contact me? > > Thanks, > > George Lowry > '06 Alpine Apex formerly '95 WBDA 4203 > Spearfish, SD Now in Indio, CA > |
02-11-2006, 01:36
TV Antenna
Recently bought one from Stephen Birtles. Verrrry happy with it.
Steve Anderson 79 FC 35 Poulsbo, Wa. [Non-text portions of this message have been removed] |
04-29-2006, 12:15
TV Antenna
Jay we just replace ours in Jan. got it on e bay. There is one on
there now #9717656233 same place we brought ours. Joe 1984 1/2 PT 40 |
