Carbon Monxide Sensor
12-29-2005, 16:51
I'm getting ready to try the propane heaters to see if they work. Does
the 1987 PT38 come from the factory with a Carbon Monoxide sensor?
12-30-2005, 03:48
Yes and no. The sensor behind your breaker panel is listed as a CO
sensor, but it is intended to detect a fire in the breaker panel and
nothing else (assuming it is working properly), tied to the LP sensor
panel.
There is no original CO sensor for the heating system.
- Jeff Miller
in Holland, MI
Does
12-30-2005, 04:58
Thank you Jeff.
Next questions - Has anyone experience with the battery operated CO
sensor vs the hard wired? Wal-Mart sells a battery sensor. Camping World
sells a hard wired sensor. Is one CO sensor enough?
> panel.
> - Jeff Miller
> in Holland, MI
> Does
> YAHOO! GROUPS LINKS
12-30-2005, 05:57
The hard-wired doesn't need batteries every year, and some of them
allow dual-power sources (APU battery & engine batteries for
example). I don't know if it is still made, but I have installed a
combination LP/CO detector to replace the original one (I believe it
became factory/standard in '88) which included an LP shutoff.
LP and CO are both heavier than air, makes a good dual-sensor under
the refrigerator.
I also feel more comfortable with a digital-readout type (110vac +
internal battery) such as the NightHawk brand from Menards et al just
for a "warm fuzzy" feeling, as a back-up.
- Jeff Miller
in Holland, MI
> Thank you Jeff.
World
sensor
> > panel.
> > - Jeff Miller
> > in Holland, MI
work.
> > Does
sensor?
> > YAHOO! GROUPS LINKS
web.
> > subject=Unsubscribe>
