Air suspension saga continues....
01-15-2006, 23:29
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@r...>
wrote: I went through all kinds of goofy stuff trying to get my 86 pt to stay level. After goat roping for a couple of years, including a couple of looks at the factory i was getting really frustrated. Took it to JoSam's in Orlando for an alignment. As they were checking everything out, they found the airlines hooked up improperly, i.e., backwards on the right rear leveling valve. Unlikely, but it is worth checking! Regards, Jim Scoggins |
01-16-2006, 03:37
And the plot thickens....
All weekend long I worked on this, running the suspension through at least 10 cycles of dump/refill, every time the same result of the front of the coach leaning left. Last night, I drove the coach down to drop off at the shop that is changing out my worn airbag (about a 12 mile trip). By the time I got down there, the suspension had leveled itself out perfectly. I believe I have a family of gremlins living in my suspension.... Scott --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > First of all you didnt say which side in the front is low? You need > to adjust the rear height adjusters to get the right and left front > at the same height and then adjust the front height adjuster to get > the front at the correct height. I think you will find that one of > the rear height adjusters is misadjusted. Remember that if the right > front is low, then you lower the right rear adjuster etc. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 07:40 PM 1/15/2006, you wrote: > >.> > >. of the front are controlled by one valve, I find myself at a > > > troubleshooting dead end here. > > > > > > Help? > > > > > > Scott Forman > > > 'Tiger Pride' > > > 82 FC35RB > > > Memphis > > > > > > >THEN trace out your ft copper lines and fix the 1 that is stopped up > >or pinched ................ > > > >pull them at the bags and measure psi at both points ....... > > > >IMO > > > >Woody 81fcrbsgd > > > > > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O bWmSYTw>Recreational > >vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34 cC1O9CxA>Automotive > >maintenance > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+ recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY HfELr6o72IW1A>Recreational > >vehicle dealer > ><http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlo dge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+r ecreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L- kXbDI4ZSadEw>Used > >recreational vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3 =Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreat ional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq _4GlXA>Automotive > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
01-16-2006, 03:46
One of the rear leveling valves is at fault....my guess. Happened to me
a few months back. First time at the garage the unit leveled so I look like a dummy...next day I look smarter, the coach leaned while at the shop. Changed out the valve and problem resolved. The shop manager said he sees this a couple time a year. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > And the plot thickens.... > > All weekend long I worked on this, running the suspension through at > least 10 cycles of dump/refill, every time the same result of the > front of the coach leaning left. > > Last night, I drove the coach down to drop off at the shop that is > changing out my worn airbag (about a 12 mile trip). By the time I > got down there, the suspension had leveled itself out perfectly. > > I believe I have a family of gremlins living in my suspension.... > > Scott > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > First of all you didnt say which side in the front is low? You > need > > to adjust the rear height adjusters to get the right and left front > > at the same height and then adjust the front height adjuster to get > > the front at the correct height. I think you will find that one of > > the rear height adjusters is misadjusted. Remember that if the > right > > front is low, then you lower the right rear adjuster etc. > > > > Tom Warner > > 1982 FC35 > > Vernon Center,NY > > > > At 07:40 PM 1/15/2006, you wrote: > > >.> > > >. of the front are controlled by one valve, I find myself at a > > > > troubleshooting dead end here. > > > > > > > > Help? > > > > > > > > Scott Forman > > > > 'Tiger Pride' > > > > 82 FC35RB > > > > Memphis > > > > > > > > > >THEN trace out your ft copper lines and fix the 1 that is stopped > up > > >or pinched ................ > > > > > >pull them at the bags and measure psi at both points ....... > > > > > >IMO > > > > > >Woody 81fcrbsgd > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w > 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea > tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O > bWmSYTw>Recreational > > >vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti > ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh > icles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge& > w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34 > cC1O9CxA>Automotive > > >maintenance > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderl > odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+ > recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY > HfELr6o72IW1A>Recreational > > >vehicle dealer > > ><http://groups.yahoo.com/gads? > t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlo > dge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+r > ecreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L- > kXbDI4ZSadEw>Used > > >recreational vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3 > =Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreat > ional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq > _4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
01-16-2006, 14:09
"found the airlines hooked up improperly" That reminds me that our mechanic
found one of our rear leveling valves had been plumbed out of the system. Apparently the previous owner, whom I know knew nothing about the coach mechanically, would let just about any RV shop work on it. (I found this to be true in lots of other areas as well). With only 2 leveling valves, one front and one rear, he said it was like trying to ride on a balancing beam. Anyway, not every RV shop or mechanic knows how to figure out the BB systems. I'm very careful who works on my bird now and I've learned to do much more of the stuff myself, which is what this forum is all about. Dick Hayden - '87PT38 ----- Original Message ----- From: scoggins_jim To: WanderlodgeForum@yahoogroups.com Sent: Monday, January 16, 2006 3:29 AM Subject: [WanderlodgeForum] Re: Air suspension saga continues.... --- In WanderlodgeForum@yahoogroups.com "Scott Forman" <sforman@r<mailto:sforman@r>...> wrote: I went through all kinds of goofy stuff trying to get my 86 pt to stay level. After goat roping for a couple of years, including a couple of looks at the factory i was getting really frustrated. Took it to JoSam's in Orlando for an alignment. As they were checking everything out, they found the airlines hooked up improperly, i.e., backwards on the right rear leveling valve. Unlikely, but it is worth checking! Regards, Jim Scoggins ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
01-16-2006, 16:30
Boy, you can say that again and not limit it to Bluebirds. When I
needed a mechanic for Bluebird systems, I used A - Z bus, a Bluebird distributor, or George Morris before he went to Bleakley. I have found that very few "auto mechanics or truck mechanics" know how the various systems that are used on RVs work or how to figure them out. George Lowry '95 WBDA 4203 going to an Alpine Apex Spearfish, SD Still in Indio, waiting for the USPO to go back to work. Richard Hayden wrote: >"found the airlines hooked up improperly" That reminds me that our mechanic found one of our rear leveling valves had been plumbed out of the system. Apparently the previous owner, whom I know knew nothing about the coach mechanically, would let just about any RV shop work on it. (I found this to be true in lots of other areas as well). With only 2 leveling valves, one front and one rear, he said it was like trying to ride on a balancing beam. Anyway, not every RV shop or mechanic knows how to figure out the BB systems. I'm very careful who works on my bird now and I've learned to do much more of the stuff myself, which is what this forum is all about. > >Dick Hayden - '87PT38 > ----- Original Message ----- > From: scoggins_jim > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, January 16, 2006 3:29 AM > Subject: [WanderlodgeForum] Re: Air suspension saga continues.... > > > --- In WanderlodgeForum@yahoogroups.com "Scott Forman" <sforman@r<mailto:sforman@r>...> > wrote: > I went through all kinds of goofy stuff trying to get my 86 pt to > stay level. > > After goat roping for a couple of years, including a couple of looks > at the factory i was getting really frustrated. > > Took it to JoSam's in Orlando for an alignment. As they were checking > everything out, they found the airlines hooked up improperly, i.e., > backwards on the right rear leveling valve. > > Unlikely, but it is worth checking! > > Regards, > Jim Scoggins > > > > > > >------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. > > >------------------------------------------------------------------------------ > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > > > |
