LXi Chassis Parrt Number List
10-13-2014, 23:25
Does anyone know the correct coolant tank cap part number for a Series 60? It would be handy if added to the LXi Chassis Part Number List. Lost mine. Don't ask how.
Ron & Dorinda Rueckwald 2000 LXi, Single Slide Summer in St. Joseph, MI Winter in St. Petersburg, FL |
10-14-2014, 09:28
(This post was last modified: 10-14-2014 09:33 by davidbrady.)
RE: LXi Chassis Parrt Number List
Stant 10229, 13psi automotive style vented radiator cap available at CarQuest and crossed at all the other stores including Napa. While you're at it pick one up for your Aquahot.
10-14-2014, 10:05
(This post was last modified: 10-18-2014 15:10 by timetravelers.)
WW Williams in AZ put a 13 psi cap on in 2009 and I have been running 13 psi on my S-60, Aquahot and Kubota ever since. [/size]Revised, original post had a memory glitch
Morey Zuber 99LXi41 |
10-14-2014, 13:00
Morey,
That's awful high to maintain in a system. While some pressure is a good thing in today's cooling systems, that much sure puts a lot of stress on things. The potential leak will be huge! John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
10-14-2014, 14:34
(This post was last modified: 10-14-2014 15:44 by travelite.)
30 psi would make sense in outer space, but here on earth we get the first 14.7 psi for free. I wonder if the tech saw a spec for absolute pressure which equals gauge plus atmospheric. With a 13 psi cap the absolute pressure would be 27.7 psi.
10-15-2014, 17:01
(10-14-2014 09:28)davidbrady Wrote: Stant 10229, 13psi automotive style vented radiator cap available at CarQuest and crossed at all the other stores including Napa. While you're at it pick one up for your Aquahot. John Wyatt referenced a BB drawing that called for a 10 psi cap, BB p/n 1325430. Holland had one on order, but not for days, so I went to NAPA for the Stant 10229 (13 psi). It crossed to a NAPA p/n 703-1697 (13 psi), but the guy searched further and found one of 10 psi. This is NAPA p/n 703-1708. That's what I bought. Thanks for the discussion. We now know more than we knew a few days ago. Ron & Dorinda Rueckwald 2000 LXi, Single Slide Summer in St. Joseph, MI Winter in St. Petersburg, FL |
10-15-2014, 17:55
(This post was last modified: 10-15-2014 17:57 by davidbrady.)
Ron,
Check this out: Wanderlodge Gurus->Document Library->Engines->Detroit Diesel->DD Series 60 Engine Manual.pdf Section 6.7.10 specs a minimum cap of 9 psi; figure 6-34 shows the effect of altitude on coolant boiling for a series of cap pressures: a 9 psi cap at see level yields the same boiling point as a 12 psi at 8000 ft. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
10-15-2014, 19:26
(This post was last modified: 10-15-2014 19:26 by rrueckwald.)
David,
I just saved that manual. Thanks. Now, to find the time to read it. Ron Ron & Dorinda Rueckwald 2000 LXi, Single Slide Summer in St. Joseph, MI Winter in St. Petersburg, FL |
10-15-2014, 19:53
guys I continue to have a issue with my leveling . On a hard R turn she will drop hard L side . On the L turn she drops R side .
all air bags are new ride height is 8"+-3/16 replaced panhard rod replaced all HCV the folks at Josams said they have no idea what the issue is . all thought and ideas will be appreciated . al perna 2000 LXI ormond beach fla |
10-15-2014, 20:04
(10-15-2014 19:53)al perna Wrote: guys I continue to have a issue with my leveling . On a hard R turn she will drop hard L side . On the L turn she drops R side . Al, maybe a couple of these will help http://www.supersteerparts.com/products/...suspension Curt Sprenger 1987 PT38 "MacAttack Racing" Anaheim Hills, CA cosresources@gmail.com |
